Staro 13.12.2010., 13:15   #211
raliSHA
raliSHA's Avatar
Datum registracije: Feb 2010
Postovi: 974
hmm, ja sam igrao mass effect 2 na njemu i na ovom starom 226bw koji ima 2ms i nisam primjetio neku razliku bitnu, al ja nisam neki veliki fps-er
raliSHA je online   Reply With Quote
Staro 13.12.2010., 13:35   #212
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,505
bilo bi idealno da netko tko igra online recimo bad company 2 napiše iz prve ruke o ghostingu
Staro 13.12.2010., 13:43   #213
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,949
Ja isto nisan primjetio ništa neobično, a odigralo se dosta toga. Doduše ništa multiplayera, al je SP bilo i previše, Bad Company 2, zadnja 3 CODa, Mafia II, F1 2010, Medal of honow, HAWK, itd.
Mislim da takve teze plasiraju isti oni šta govore da osjete razliku između 300 i 280 FPS
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 13.12.2010., 14:00   #214
Mad_Duke
Da li je važno. Onaj kojem je stalo da ima nešto najluđe u svijetu kaj leti će ili igrati na CRT-u ili na nekoj novoj hd ready 3D plazmi (zbog 120 Hz-a).
Staro 13.12.2010., 14:32   #215
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,505
-For FPS gaming, ghosting will be more noticeable especially if you have a fast video card displaying high frame rates. With Overdrive off, the ghosting made me felt like I had a few drinks. When it's turned on, ghosting is reduced and games are much more playable. To me, the difference is big so Overdrive is a must for FPS. Due to this screen having great contrast and clarity, the details stood out and I was able to pick out enemies from the distance easier, this allowed me to get better scores despite not the best response time.
ovo je s amazona neki lik napisao, a razmišljam da uzmem ovaj monitor uskoro a igram pretežno FPS online pa se želim raspitat iz prve ruke
Staro 13.12.2010., 16:08   #216
raliSHA
raliSHA's Avatar
Postovi: 974
pa eto, overdrive on i ok
Staro 13.12.2010., 16:23   #217
zgmmax
zgmmax's Avatar
Postovi: 1,675
I've provided a comparison above of the ZR24W (overdrive = off) vs. the 24" Asus MS246H and 22" Samsung SM2233RZ. Both these other models are very fast TN Film based models, using aggressive and well controlled overdrive and even 120Hz technology in the case of the Samsung. As you can see, the ZR24W can't quite keep up with these fast TN Film models. I would still say the HP is adequate for average gaming, but if you want the best performance you will probably want to consider some of the 120Hz models emerging in the market.
Izvor
Ja ga isto razmisljam uzet, sam kaj nigdje nema videa kak to izgleda kada se igra na njemu
EDIT:
naso jednog, sam kaj se bas i ne vidi nesto pametno
http://www.youtube.com/watch?v=OtCrIWsvFzg
Zadnje izmijenjeno od: zgmmax. 13.12.2010. u 16:28.
Staro 13.12.2010., 19:33   #218
Mad_Duke
Stvarno. Iz videa da ćeš nekaj vidjet? Možda pred više od 5 godina, ali :P
Staro 20.01.2011., 20:34   #219
neumrli
Dubwise
neumrli's Avatar
Postovi: 307
Ovako, vec dva mjeseca pikiram neki 23/24" kvalitetniji monitor (citaj: ne-TN matrica). Krajem mjeseca u Hrvatsku bi trebao stici Dellov U2311H model za koji sam cuo dosta pohvala, doduse mislim da je bilo rijeci oko problema vezanih za backlight bleeding. E sada vidim da je ekipa koja je kupila ovaj monitor takodjer zadovoljna i da nemaju nikakvih znacajnijih primjedbi, pa sam htio pitati isplati li se dati 1000 kuna vise za ZR24w, da li se ta kvaliteta za tu cijenu moze osjetiti pri radu za monitorom (taj 1" mi bas ne igra neku veliku ulogu) ?
P.S. monitor bih koristio za svakodnevni rad, znaci nista strogo usmjereno poput obrade fotografija ili igranja FPS igara.
neumrli je offline   Reply With Quote
Staro 20.01.2011., 21:59   #220
w0lfram_
Rasvjetno tijelo
w0lfram_'s Avatar
Postovi: 374
Autor UnDeAd Pregled postova
po informacijama koje sam ja dobija u2311 nece prije sredine drugog miseca, ako i tad
s tim da je telebit pocea i zapisivat nekakave rezervacije, pa ako ce se drzat toga, onda vjerojatno da je prva tura tako rec rasprodana...
edit: @UnDeAd ma znam da nisam al rekoh cisto da znas, ako ti je hitno za monitor ili nesto
Pošteni trgovci: 1, 2, 3, 4, 5, 6, 7, 8, 9,10
Zadnje izmijenjeno od: w0lfram_. 21.01.2011. u 13:20.
w0lfram_ je offline   Reply With Quote
Staro 21.01.2011., 00:02   #221
neumrli
Dubwise
neumrli's Avatar
Postovi: 307
Nisi mi nazalost nista rekao u vezi isplativosti
A sto se tice cekanja, mogu pricekati jos mjesec dana, jer mi nije toliko hitno.
Staro 21.01.2011., 00:19   #222
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,472
Jesi pogledao Viewsonica VP2365wb?
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 21.01.2011., 00:34   #223
neumrli
Dubwise
neumrli's Avatar
Postovi: 307
Hm, evo bas malo gledam misljenja po netu i ljudi su podijeljeni oko njih. Vidim po postovima da ga ti imas, sto ti kazes na njega ?
Doduse ne bih htio da odemo u offtopic sa raznoraznim modelima
Zadnje izmijenjeno od: neumrli. 21.01.2011. u 01:19.
Staro 30.01.2011., 17:56   #224
Schtefek
Schtefek's Avatar
Datum registracije: Jun 2010
Lokacija: Križevci
Postovi: 172
Jel itko našao ovaj monitor u kojem od dućana, gdje god pitam
Nitko nema, a odličan mi je, niti mi treba toliko priključaka kao što ih ima njegov stariji i skuplji brat, a i to što ima malo slabiji gamut meni nebi smetao, i još k tome svatko tko ga je kupio samo ga hvali.
ako netko zna gdje se može nabavit nek javi što prije, jer idem u kupovinu ovaj mjesec (veljača)
Schtefek je offline   Reply With Quote
Staro 07.02.2011., 11:38   #225
kakt00s
Postovi: 52
To i mene zanima. Gledam po nabavi i sve rasprodano...
kakt00s je offline   Reply With Quote
Staro 07.02.2011., 15:18   #226
mrtvi
mrtvi's Avatar
Postovi: 183
i kad dođe će bit 400kn skuplji
mrtvi je offline   Reply With Quote
Staro 19.02.2011., 20:35   #227
Rista
Rista's Avatar
Lokacija: Ri
Postovi: 1,924
Evo ja vracam trecega ukupno i odustajem. Prvi je bio jako dobar, uniformnost dobra, malcice tamniji jedan rub ali potpuno normalno za ijedan LCD. Medjutim imao je nekakvu kontaminaciju tj prasinu ispod povrsine ekrana i plastika lijevog ruba okvira je maalo prekrivala sliku pa sam reklamirao. Drugi koji sam dobio imao je vertikalni "tint", dolje na crveno a gore na zeleno baca. Nakon toga stao, preispitao malo trziste i posto mi 16:9 1080p nikako ne odgovara odlucio okusati srecu jos jednom u nadi da dobijem primjerak barem kao onaj prvi. Proizveden Dec 2010 i opet tinting ali ovaj put horizontalno. Lijeva strana baca na crveno, desna na zeleno. Cisto iz znatizelje, kakva su vam iskustva sa uniformnosti na ovom monitoru?
Da se razumijemo, ovo je apsolutno nista u odnosu na bilo koji TN koji je po defaultu gore tamniji a dolje svjetliji cisto zbog uskog vertikalnog kuta gledanja. Kad TO vecina ljudi ne primjeti onda nece ni ovo tako da ne prestrasim nekoga od kupnje Taj problem na stranu, monitor je odlican. Kontrast nije tako los, boje su jako dobre, slika stabilna pa mozes komotno sjedit bez color shifta, IPS glow se ne primjeti kada je ikakav imalo osvjetljeni objekt u blizini ruba, matrica je dosta brza za vecinu igraca. Sama kvaliteta izrade kucista i postolja cini se vrlo dobra.
Za one poput mene koji zele IPS ali ih odvracaju bas problemi sa uniformnosti LG-ovih panela i nije im hitno, moj savjet je sacekati nove Samsungove modele sa novom PLS matricom. U biti Samsungova verzija IPS-a. Tvrde da ce imati bolje kuteve gledanja/manje glow-a i da ce biti 15% jeftiniji za proizvodnju. SA850, 27" 2560x1440 bi se trebao pojaviti vec za koji mjesec. Na sluzbenom siteu se takodjer navodi i 24" 1920x1200 PLS panel. Ne mora biti da ce i biti bolji od IPS-a ali ajde barem se nesto novo dogadja u svijetu monitora a da nije TN.
Staro 19.02.2011., 21:35   #228
Ranma 1/2
Anything Goes Martial Art
Ranma 1/2's Avatar
Lokacija: Tendo Dojo
Postovi: 542
jedno pitanje. nakon dva vraćanja monitora zašto se nisi okušao sreću sa LP2475w modelom? znam da je razlika 800njak kuna ali je li to vrijedno maltretiranja sa 3 vraćanja monitora i na kraju odustajanja?
"Water! Why does it always have to be water?!"
Ranma 1/2 je offline   Reply With Quote
Staro 19.02.2011., 22:38   #229
Rista
Rista's Avatar
Lokacija: Ri
Postovi: 1,924
Autor Ranma 1/2 Pregled postova
Wide gamut. sRGB mod je cini se poprilicno beskoristan na tim monitorima a i ZR24w bi kao trebao imati i bolju uniformnost. Bez problema bih dao i 1000kn vise za nesto takvo ali izgleda da to trenutno ne postoji. U2410 je ono, definicija zeleno/crvenog tinta, do te mjere da Dell to vise ne priznaje kao defekt vec navode kako se njihove specifikacije odnose samo na centar ekrana
Slazem se da 3 vracanja monitora stvarno zvuci ovako bezveze ali tako je ispalo. Prvi je bio dobar i sad bih ga uzeo natrag da mogu birat. Tad mi je smetala ta prasina ali se u biti manje vidi nego mrtvi piksel. Sljedeca dva, po meni neprihvatljiva uniformnost. I to uopce se ne radi o distribuciji svjetlosti, tu su sva tri bila vrlo dobra, nema probijanja pozadinskog osvjetljenja i slicno. Nego jednostavno temperatura boje varira u jednom smjeru. Na onom proslom to je bilo vertikalno a horizontalno je bio odlican. Ovdje suprotna stvar. Vertikalno bez zamjerke, a kad stavim dva dokumenta jedan pored drugoga jedan baca malo na crveno a drugi na zeleno. Iritantno. Mozda nisam imao srece i mozda ih je vecina kao onaj prvi ali vec i ova 3 vracanja su previse
Staro 20.02.2011., 00:23   #230
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,164
Autor Rista Pregled postova
Po vracanju te jedino Costa nadmasio. No on mi kaze, kako je uspio "umasirati" pixel, koji ga je tjerao na ocaj, i sad je konacno sretan vlasnik ZR24-e.
Stoga ne krivite model nesretnim odnosem HP-a prema trenutnoj kontroli kvalitete.
Cak si ne mozemo tepati kletvom trzista, jer istu stvar mozemo naci u komentarima vlasnika bilo gdje u svijetu. Cini se da svaki treci kupac, jednostavno mora barem 2 komada vratiti, dok ne onaj dobije pravi. HP ovakvu igru ne bi mogao igrati da mu potraznja nije OdLiCnA !
Ima dobar proizvod, ali kontrola kvaliteta i kolicina izbacivanja, jednostavno ne moze zadovoljti potrebe. Kad bi barem postojao netko voljan i sposoban unutar HP-a, uspostaviti jedan HP ducan u HR, koji bi onda barem donekle kordinirao stetom kao Dell. I dalje ostaje mjesta za dilere i dobavljace, te i dalje im ne opada znatno potraznja. Samo bi barem znalci imali laksi posao u kupovini i brzoj zamjeni monitora.
Ponovo se vracam na Costu. On je upravo masiranjem pixela "ubijao vrijeme" cekajuci da ponovnu zamjenu. I bas ga je cekanje natjeralo da se vise pozabavi naizgled besmislenim angazmanom. Ali eto, na kraju je zavrsio neplaniranom odlukom, ali barem postao sretan modelom. Bas kao tvoj "prasnjavi" model, koji si nazalost zamijenio losijim.
Model u zdravom dolasku i dalje ostaje odlicna kupovina i veselje na stolu. Samo ne kilavite s provjerom i ne odustajte od inzistiranja. Isli smo i za vec stvari u inozemstvo. U ducanu ili centru s mogucnoscu provjere, ne vidim problema u kupovini, ili razlog da to bude naporna kupovina. Posebno ako se budu kilavili domacom nabavkom.
>>>> PCE kante 2012 <<
>>>>>>>>> PCE & ostalo <<<<<
>>>>>>> Što sam Slušao? <<<<<<
>>>>> Gimnastika za Okulare & LCD Addendum<<<<
>>>>> P o s t ... M j e s e c a <<<<
______________________________
Zadnje izmijenjeno od: Visage. 20.02.2011. u 00:28.
Staro 20.02.2011., 03:33   #231
Rista
Rista's Avatar
Lokacija: Ri
Postovi: 1,924
Autor Visage Pregled postova
Hmm, zanimljivo. Za onaj prvi sam 100% siguran da je na kutiji bila naljepnica Recro. Na ovome nije.
Kod mene je ta prasina izgledala kao mrtvi piksel. Onda sam lagano lupnuo okvir s gornje stranje i "mrtvi piksel" je pao 5cm nize dolje. I to tocno negdje izmedju podpiksela da je bio dosta slabo vidljiv. Ali eto plastika okvira je doslovno djelic milimetra prekrivala lijevi rub ekrana, i onda kad aplikacija ima bijelu crtu sirine 1px na rubu, ta crta je bila gore bijela i prelazila u plavu jer je RG stupac bio "otkinut". Cak ga nisam ispocetka ni mislio reklamirat nego nazvao servis da pitam moze li se sta napraviti u vezi icega ovog na sto su rekli da ga donesem i uvjerili me kako drugi moze biti samo bolji Steta, jer monitor je jako dobar za svoju cijenu. 1920x1200 na 24" je bas super pogodjeno i za rad i za igre i sve.
Sto se kontrole kvalitete tice, cini mi se da je tu najvise kriv LG. Gotovo da nema tog monitora sa IPS panelom koji nema ovakav ili onakav problem sa tim tintom. Moguce je da Dellu ili HPu prodaju panele nize klase u usporedbi sa NEC monitorima sa "istim" panelom npr. ali opet kako objasniti masovne probleme sa zutilom na iMac i Cinema 27" ekranima. Zbog toga me najvise i veseli Samsungov PLS. Ne sto je samo ime Samsung pojam za nekakvu kvalitetu nego sto ce LG tu konacno dobiti konkurenciju.
Staro 20.02.2011., 06:13   #232
Index
Postovi: 142
Trebao bi pogledati neki Eizo. Mislim da nema dileme o kvaliteti kod tog proizvodjaca.
Index je offline   Reply With Quote
Staro 20.02.2011., 12:23   #233
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,828
Samo kaj Eizo monitor nemaš ispod 5 soma, 24".
Staro 20.02.2011., 15:38   #234
Rista
Rista's Avatar
Lokacija: Ri
Postovi: 1,924
Autor Index Pregled postova
Autor zvonac Pregled postova
Mislim da si malo i rekao, a i Eizo i nije bas dobavjliv kod nas zar ne? 5000 do 6000kn mi ne bi bio problem dati za monitor ali nijedan PVA po meni ne vrijedi toliko, da je ne znam koji brand. Taj gamma shift i nestabilnost slike je glavni razlog sto sam pokusao preci na IPS. Za NEC 2490WUXi bih dao te novce ali to je vise nemoguce naci. A Dell U2711 i slicno je isto lutrija kao HP, samo jos i veca.
Staro 20.02.2011., 20:12   #235
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,164
Ne cini ih Recro boljim ili losijim, samo je pozeljno u ovakvoj situaciji od njih uzimati, dokle god imaju najvece skladisno zaprimanje modela.
Kod nas, uz spomenutu preporuku pregleda, ili vani u susjedstvu, ili u jednako opremljenom centru/ducanu.
Proizvodjac proizvodi u zadanim specifikacijama, uz poznate nesavrsenosti uopce prozvodnje LCD-a kao takvog. Skuplja selekcija kosta, a njoj nije mjesto u masovnom izbacivanju na tisuce i tisuce monitora tjedno. Neke stvari su se popravile a neke unazadile u procesu. Ali kolicina potraznje svakako ne pomaze u segmentu koji cijenom mora biti super atraktivan.
Naravno da je. Ako pretrazis forum uz spomen Eizoa, pronaci ces sve odgovore na svoja pitanja. Ukljucujuci gdje, kako i zasto. Ali i odgovor na lovacke price o Eizo monitorima, koji se pocesto svode na nevidjenu raspravu o bolidima koje nitko nije vozio, ali svi "znaju" najvise o njihovim manama. Iz forumski novijeg Eizo datuma.
Dok drugi segment Spectre i malobrojne ekipe ima vecu toleranciju primanja matrica, ali i drugaciju politiku vracanja i zamjene. Izuzetak je HP Dream, koji ima identican tretman kao i ostali HP monitori po pitanju zamjene. No to sam vec par puta spominjao pa pretrazi ako te zanima vise.
Iz vana se i dalje moze pronaci. Samo i on ima storiju iz pera vlasnika, po pitanju vracanja. Tako da ga je isto pozeljno isprobati, posebno uz poznati Nec-ov (opet velicina) povratni US refurbished program.
Jednostavno. Proces nije savrsen a potreba trzista ogromna. Razocarani uvijek pisu vise od onih zadovoljnih. Apple je po pitanju naplate ionako prica za sebe i nadilazi problem monitora. Najveci problem su imali s 23" Cinema modelima, koji su se najvise ozloglasili reputacijom medju graficarima. Unapredjenu verziju te matrice imam u svom monitoru, ali i ona je mogla zavrsiti kao manjkavi model kod nekog vlasnika. Kao i prve 20"-ce, ili kao bilo koja druga serija Samsung/LG. Danas je vise prica o losim primjercima a manje o seriji. Samo kad se ponovo vratimo na brojku potraznje i prodaje onda se sve ponovo pomijesa
PCE je pun prica o dojmovima te kvalitete Odnosno,moze ici u oba smjera kao i kod LG-a. Tako da ne treba generalizirati iskljucivoscu odabira. Konkurencija je svakako odlicna, a nova izdanica IPS-a pokretacki inovativna. No tek imamo vidjeti sud prakse.
Staro 24.02.2011., 21:19   #236
Rista
Rista's Avatar
Lokacija: Ri
Postovi: 1,924
Autor Visage
Da, samo kod nas nije bas uvijek moguce napraviti tu provjeru prije kupnje nazalost. Vec sam pisao kako su me u Linksu lagano otkantali i nisam vise bio zanimljiv kao kupac kad sam pitao moze li se monitor upaliti...
Autor Visage
U pravu si naravno da skuplja selekcija kosta, ali uzmimo za primjer Dell U2410. Meni je recimo neshvatljivo da takav monitor moze imati tako cest i izrazen tint problem a s cijenom od 4000kn je daleko od super atraktivnog kad se uzme u obzir da se U2311H moze dobiti za, koliko, 1700kn? Svaki kojeg sam vidio je bio uzasan u odnosu na HP, a samog HPa sam vec 2 vratio zbog toga a taj jedan iako prihvatljiv, da je imao uniformnost mog PVA monitora, nije. Ili LG prodaje Dellu, HPu i slicnima "skart" panele ili je kontrola kvalitete samog LGa losa. Vjerojatno oboje pomalo.
Autor Visage
Naravno da je. Ako pretrazis forum uz spomen Eizoa, pronaci ces sve odgovore na svoja pitanja...
Hmm, vidis to nisam znao da se Eizo moze nabavit kod nas. Kao sto rekoh, ne sumnjam u kvalitetu ali tako velike novce ne bih dao za ijedan PVA monitor. Eventualno bi me zanimalo nesto poput EV2333 ali opet radije onda uzmem puno jeftinijeg Samsunga F2380M. I tu se onda vracam na pocetak da mi je 1920x1080 malo i neprakticno.
Uopce mi ne treba monitor za profesionalni rad s fotografijom. Jedino trazim uniformnu, stabilnu sliku vece rezolucije. Ocito je to za do 5000kn gotovo nemoguca misija osim da dobijes na IPS lutriji
Staro 26.02.2011., 14:35   #237
Danko86
Danko86's Avatar
Datum registracije: Jul 2009
Postovi: 600
evo ja igram bc2, ne na ovom modelu, ali na istoj kategoriji IPS, samo philips. pw240e, mislim da se tako zove.
monitor je bog. di god da nesto gledam/radim/drkam po kompu, a da nisam doma, razlika je megavidljiva...
ghosting ne postoji. to je takva izmisljotina da ju nije vrijedno spominjat.. postoji, ali u tako malim mjerama da je neprimjetan.. npr kad crtam u 3ds maxu, pa je pozadina siva i onda neki model povlacim po pozadini, vidi se mali ghosting, ali samo tu. u nekoj igri di je vise boja nema teorije da se to skuži..
ovi novi IPS-i imaju i kratak odaziv, sto je dobro za igre. ali imaju i nesto sto nitko od proizvodjača ne spominje.. a to je input lag..
po meni je on najveci problem u IPS-ima, ali ako si malo duže za njih se priviknes i nebude vise problema.
znam da me to jebalo prvih nesto vremena, tipa 2-3 tjedna jer sam presao sa 19'' crt samsunga na ovog i nikako se nisam mogo priviknut.. sad kad sam se priviko ouopce ne vidim problem, jedino kad kod mame na kompu idem radit nesto na crtu, vidim da je razlika
ali osim tog (na sta se vrlo brzo priviknes) IPS je takav ZAKON da se o tom može pricat. jest malo skuplji, moj je bio 3600kn, al istini za volju pol dana sjedino na kompom i mislim da se u tako nesto isplati investirat..
eto mamute, nadam se da sam ti bio od pomoci
dankojunasevic.tk
Danko86 je offline   Reply With Quote
Staro 27.02.2011., 19:51   #238
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
Postoji više IPS vrsta matrica i nemaju sve jednaki input lag. Prema tftcentral-u ZR 24w ima jedan od najkraćih odaziva.
Nisam uspio guglanjem pronać ovaj tvoj gore navedeni model "pw240e", najbliže tome su "240PW" modeli (IPS matrica). E sad, koliki je njima input lag to mi se neda tražit. Ali lako moguće da je veći od ZR 24w pa te zato smetalo u startu.
S obzirom da također razmišljam o kupnji dotičnog monitora volio bih čuti iskustva od korisnika isključivo tog modela.
Staro 28.02.2011., 11:55   #239
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,505
hvala danko, ja sam još u fazi razmišljanja, i nekako sam prekrižio zr24w jer dok sam ga guglao naišao sam na brdo nezadovoljstava na temelju ghostinga pa neznam ni sam više i počeo sam razmišljat o dell u2410 ili hp LP2475w
Staro 28.02.2011., 18:04   #240
Rista
Rista's Avatar
Lokacija: Ri
Postovi: 1,924
Autor T}{OR Pregled postova
Tako je. Cak ni razliciti modeli sa istim panelom nemaju svi isti input lag.
Za ono vrijeme sto sam ga/ih imao meni se ZR24w cinio solidan za igranje. Sa ukljucenim overdriveom vrijeme odziva je dosta dobro bez vidljivih artefakata tijekom brzih scena. Input lag bi trebao biti oko jednog framea sto je opet dosta dobro.
Problem je sto je to sve dosta subjektivno. Ako trazis, naci ces motion blur i na najbrzem 120Hz TN LCD-u pa ima ekipe kojima nista osim CRT-a ne valja. Na IPS-u je dobro sto je vrijeme odziva svih tranzicija tu negdje ujednaceno za razliku od *VA panela gdje su neke vrlo brze a druge vrlo spore pa u odredjenim scenama dobijes ociti ghosting.
Po testovima cini se da su U2410 i LP2475w nesto malo brzi ALI ja bih na necijem mjestu ako je ikako moguce to prvo isprobao. Jer LP2475w je wide gamut sa losim sRGB modom. Inace bih rekao ni U2410 ali vidim da su cijene pale na nekim mjestima a ZR24w porasle pa je tu vec dilema ovisno gdje kupujes iako Dell ima taj najzloglasniji panel po pitanju tintinga.
