Staro 12.07.2010., 10:45   #4771
Dottore
Dottore's Avatar
Postovi: 7,668
Autor Mansky Hunt Pregled postova
opako.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Dottore je online   Reply With Quote
Staro 12.07.2010., 11:42   #4772
thesekiman
Pr0d1gy
thesekiman's Avatar
Postovi: 288
Ako se samo 'srušiš' mrtav,ali te nitko nije zapravo ubio,to te admin ubija iz admin tool-a,no svejedno piše da te netko ubio,izbaci nekakvo random ime.
Provjereno,doživio sam to,pošto smo ih rasturali,pa je admin uzeo stvar u svoje ruke.
Mislim da ti piše da te admin ubio: "You were killed by an admin for blablabla"
Barem preko ProCona tako nekako piše. Ja to koristim da napravim malo reda ako je baserape u pitanju, prvo čekam da attackeri sami očiste bazu, ali ako se nađe neki ninja koji ostane sakriven onda ga killnem. On se premjesti u svoju bazu, ne broji mu se death, nije dobio kick i mirna bosna
thesekiman je offline   Reply With Quote
Staro 12.07.2010., 14:47   #4773
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor thesekiman Pregled postova
Trebalo bi pisati,ali ne piše uvijek.Puno puta mi se dogodilo da piše npr.
'thesekiman death manhunt1986'.Naravno,u ovom slučaju ti si admin,ali izbaci to prvo neko random ime,nema veze sa administratorom.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 12.07.2010., 14:57   #4774
hobitxxx
hobitxxx's Avatar
Datum registracije: Jul 2009
Lokacija: Koprivnica
Postovi: 412
ljudi addajte me tOm[CrO] neam puno prijatelja da bar imam s nekim igrati na serveru e da i xfire hobbitxxx dosadno je ovak...
hobitxxx je offline   Reply With Quote
Staro 12.07.2010., 15:49   #4775
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,811
Ma samo se pojavi na teamspeaku i uvijek ćeš imati dovoljno prijatelja
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 12.07.2010., 22:51   #4776
hobitxxx
hobitxxx's Avatar
Postovi: 412
e da jos jedno pitanje jel se kome događalo da mu se na battlefieldu nakon nekog vremena slika zamrzla i zvuk samo TRRRRRRRRRRR onak dost glasno i onda bsod ili restart?
Staro 12.07.2010., 22:55   #4777
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Autor hobitxxx Pregled postova
e da jos jedno pitanje jel se kome događalo da mu se na battlefieldu?
Jok
Samo jedno trečina igrača to dobije bar 2 puta dnevno
blaa
Staro 13.07.2010., 02:04   #4778
Constantine
Constantine's Avatar
Postovi: 668
Think your accuracy in #BFBC2 is poor? The US Army estimates they fire 250,000 bullets for every insurgent that was killed. 0.0004% accuracy
:O
Constantine je offline   Reply With Quote
Staro 13.07.2010., 04:03   #4779
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Da li je netko imao problem da mu FPS najednom padne na 5-10 na oko 5 sekundi i onda se sve vrati u normalu?Ovako nešto http://forums.amd.com/game/messagevi...hreadid=134131
Još dosta ljudi ima taj problem ali nigdje nisam našao rješenje,isprobao par drivera,overclock,downclock,uvijek mi se dešava sada sa 5850,oko 2 puta po rundi mi tako bude.
Staro 13.07.2010., 09:41   #4780
jurbAs
jurbAs's Avatar
Postovi: 2,583
Autor Veki-os Pregled postova
meni se isto to dogodilo sad ovih dana par puta ali nije bas toliko strasno al ono zna tak neki put neobjasnjeno zatrzat
btw primjetio sam da mi je ping ispod 100 kako sam promjenio proc???? nisam znao da i proc ovisi o pingu....
Staro 13.07.2010., 12:13   #4781
CyCl0p$
pa ping u igri ovisi, jer ne racuna samo latenciju mreze nego cijelog sistema.
Staro 13.07.2010., 13:23   #4782
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,422
@veki da meni se to zna dešavat, onako samo na 5 sekundi imam 1 fps nemogu ništa, i to se nekad dešava nekad ne, neam pojma do čega je
Staro 13.07.2010., 13:34   #4783
PointDexter
Lokacija: Éire
Postovi: 1,811
Mislim da je to to servera, jer dešava mi se jako rijetko i samo ne pojedinim serverima
Staro 13.07.2010., 14:25   #4784
noxyxxx
Datum registracije: Dec 2009
Postovi: 20
Addajte me u igri i u xf -> BBC2 = NoX {CrO} a XF = noxycroatia ...
igra mi ide savrseno sa HD3870 i AMD 4800 x2..... oko 40-50 FPSa......a nekad se samo spuste ispod 20....kak to rijesiti ?
noxyxxx je offline   Reply With Quote
Staro 13.07.2010., 14:37   #4785
zgmmax
zgmmax's Avatar
Postovi: 1,674
Autor noxyxxx Pregled postova
Kaj u LOW postavkama dobivas takve rezultate
Mansky ima jaci komp od tvoga pa skoro pa ima slide show kak mu igra ide savrseno.
EDIT:
Sada sam malo gledo filmice u vezi trace darta i lik je pokazo da se trace dart moze skinut pomocu smoke nade-a
Netko vas trejsa i u timu imate assaulta sa smoke nade-om on ispuca smoke u crvenu tockicu i trace nestane, obrnuto ne radi (ak se prvo baci smoke i netko ide traceat ce uspjeti)
Zadnje izmijenjeno od: zgmmax. 13.07.2010. u 15:27.
Staro 13.07.2010., 22:06   #4786
noxyxxx
Postovi: 20
Ne igram na LOW nego na MEDIUM postavkama s rezom 1280 x 1024 ..... i radilo je ok sa High ali sam smanjil zbog FPSova....
Staro 13.07.2010., 23:41   #4787
PointDexter
Lokacija: Éire
Postovi: 1,811
Staro 14.07.2010., 00:06   #4788
Paxton
Expert from the shadow
Paxton's Avatar
Lokacija: Sibinj
Postovi: 696
Tko je postavljao admine na PcE serveru? Zamolio bi nekog da me kontaktira, trebam par informacija.
Paxton je offline   Reply With Quote
Staro 14.07.2010., 00:25   #4789
PointDexter
Lokacija: Éire
Postovi: 1,811
Nisu se postavljali admini posebno, nego je određenim ljudima dan pass za procon.
Inače server je platio i odredio glavni password Aerendyl
Staro 14.07.2010., 00:36   #4790
Paxton
Paxton's Avatar
Lokacija: Sibinj
Postovi: 696
moze vise informacija? trebali bi na jednom serveru rijesit admine, da imaju prisptup 24/7. Znaci, trebalo bi samo instalirat Procon na svakom od racunala, i dobit pass za rcon od admina?
Staro 14.07.2010., 00:38   #4791
Veki-os
Veki-os's Avatar
Postovi: 3,996
Autor Paxton Pregled postova
Da.
Staro 14.07.2010., 01:35   #4792
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Brate,reci da se šališ.
Staro 14.07.2010., 02:09   #4793
black35
Semper Fi
black35's Avatar
Lokacija: Neutraubling, Germany
Postovi: 292
LP svima
Imam problem sa instalacijom igre BF BC2, imam original cd key, skinuo sam igru preko EADM, i nakon sto se igra u cijelosti skinula ne mogu pokrenuti instalaciju iz EADM-a, skinuo sam Battlefield: Bad Company™ 2 limited edition (PC Downloadable). Kada rucno pokusam pokrenuti instalaciju napise mi slijedecu poruku:
"The version of this file is not compatibile with the version of windows you're running. check your computer's system information to see whether you need an x86 or x64 version of the program, and then contact the software publisher"
Driver za graficku je 191.07
Sad meni nije jasno kako igra nije kompatibilna sa win 7 x64 ultimate??
Molim pomoc!
Member of PCE 120+kg demolition squad
Zadnje izmijenjeno od: black35. 14.07.2010. u 02:15.
black35 je offline   Reply With Quote
Staro 14.07.2010., 02:21   #4794
Veki-os
Veki-os's Avatar
Postovi: 3,996
Jesi probao pokrenuti kao Admin?
Staro 14.07.2010., 02:24   #4795
black35
Semper Fi
black35's Avatar
Postovi: 292
Pokusao sam i to i isti je problem....
Staro 14.07.2010., 09:55   #4796
zgmmax
zgmmax's Avatar
Postovi: 1,674
vis da je neki lovac u mutnom
ja sa svojom konfom, sve na high na toj istoj rezi i jos 4xAA i 4x(onaj drugi) pa mi se vrti oko 55fps-a
a mozda i on sporo kopca neke stvari pa mu se i slide show cini ko akcijski film
Staro 14.07.2010., 10:51   #4797
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Autor PointDexter Pregled postova
zh1nt0
The article published by PC-Gamer is not accurate. We are currently researching if Onslaught will be available for PC. No release date.
viper je offline   Reply With Quote
Staro 14.07.2010., 12:17   #4798
noxyxxx
Postovi: 20
Trenutno sam sve smanjil do kraja i sad je reza 1024 x 768 bez AA i sve LOW na 50 fpsa..... fakat nezz zakaj je prije bilo vise ali skuzil sam da mi se proc pocel zagrijavati na 69 stupnjeva....to nije normalno ha ?
Staro 14.07.2010., 13:31   #4799
PointDexter
Lokacija: Éire
Postovi: 1,811
Kod ove igre uopće nije problem grafička kartica, barem ne kod nekih normalnih rezolucija i detalja. Upgradeo sam sa e5200@3200 na q8400@2600 i gameplay je postao neusporedivo bolji. Jest da sam i prije imao kojih 40-50fps-a ali npr nisam prije mogao pročitati imena clanova tima kada bi prolazili pored mene, tako da to fraps možda računa kao 50fps-a, ali koliko je konstantan taj framerate to je upitno...
EDIT: i otkako sam se privremeno vratio na dual core K/D ratio mi je u konstantnom padu
Staro 14.07.2010., 14:41   #4800
roflcopter000
roflcopter000's Avatar
Datum registracije: Aug 2009
Lokacija: Vukovar
Postovi: 54
Jel ima tu netko da je kupio igru ili cd key preko enabave ?
Small words from a small mind. The even now your demons think of nothing but how best to cook you when you have outlived your usefulness. You are a fool among untold numbers of fools. The Imperium will show you no mercy, only death Heretic.
roflcopter000 je offline   Reply With Quote
