Staro 08.01.2010., 14:16   #91
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Vidjet cemo sto ce stici iz Japana sa rasprodaje, ili HD4890 ili ta HD5750
Staro 08.01.2010., 14:53   #92
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
PowerColor Go! Green HD 5750 set for February arrival
TUL Corp. has revealed that its December-announced Go! Green HD 5750 card will get the green light and start shipping next month. The soon-to-be-release model features stock frequencies - 700 MHz for the GPU and 4600 MHz for its 1GB of GDDR5 memory, has DirectX 11 support, 720 Stream Processors, a 128-bit memory interface, a pretty large quad-pipe passive cooling solution and dual-DVI, HDMI, plus DisplayPower outputs.
The Go! Green HD 5750 has pretty much reference specs so what makes it special is the power consumption, 21% lower than stock models. To achieve this, the card makes use of a digital power solution with an efficiency of up to 90%.
"We're all looking to do our part for the environment. Less power, less carbon produced. And that's why we developed the Go! Green series," says Ted Chen, TUL CEO. "The PowerColor Go! Green HD5750 is designed to provide outstanding graphics performance you need but protects the world at the same time. Go! Green the world with PowerColor!"
The Go! Green HD 5750's pricing has not been revealed but it should hover in the 100 - 120 Euro zone.
http://www.tcmagazine.com/comments.p...ighlight=green
Staro 08.01.2010., 15:00   #93
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Bas me zanima jel ima dodatni prikljucak za napajanje...
Staro 08.01.2010., 15:42   #94
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Koji marketing
Da je 4870x2 ili 5970 u pitanju onda bi već tih 21% i značilo nešto
D-I-A-B-L-O je offline   Reply With Quote
Staro 08.01.2010., 21:15   #95
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Smirite strasti...
Staro 15.01.2010., 18:25   #96
kassad
marked one
kassad's Avatar
Lokacija: ck
Postovi: 220
razlika izmedu v1 i v2 5770 coolera..
http://www.overclock.net/hardware-ne...st-second.html
kassad je offline   Reply With Quote
Staro 16.01.2010., 22:07   #97
Enter Sandman
dark paradise
Enter Sandman's Avatar
Postovi: 551
Tak sam si i mislio, uvijek su mi se ta zatvorena rješenja činila gorim
Evo došao sam u posjed jedne 5770 sa v2 hlađenjem i samo pohvale, temp su odlične s tim da vent nikad nije prešao 36% brzine..
Enter Sandman je offline   Reply With Quote
Staro 17.01.2010., 13:29   #98
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
To je možda moja cura. Odličan hladnjak,da.
Staro 21.01.2010., 21:07   #99
Goranbm
Goranbm's Avatar
Postovi: 1,238
Zanim me da li je netko mozda kupio XFX 5770 grafu i to onu sa v1 hladnjakom uz koju se dobije battle forge... Mene zanima da li se uz nju dobije VGA na DVI adapter ????
Goranbm je offline   Reply With Quote
Staro 21.01.2010., 21:29   #100
Speedbreaker
Postovi: 545
Autor Goranbm Pregled postova
Ne, ali se dobije DVI na VGA.
link...ako je to ta na koju misliš.
@matthew
isti link hehe
Speedbreaker je offline   Reply With Quote
Staro 21.01.2010., 21:30   #101
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Matth€w je offline   Reply With Quote
Staro 21.01.2010., 22:13   #102
Goranbm
Goranbm's Avatar
Postovi: 1,238
a naručio sam u ADM-u, ta grafa je na slici u web shopu, valjd je to ta
Staro 22.01.2010., 12:55   #103
Goranbm
Goranbm's Avatar
Postovi: 1,238
ipak sam dobio ovu sa v2 hladnjakom nadam se da je to bolje.... koje bi mi drivere preporucili da stavim ????
Staro 22.01.2010., 13:03   #104
thedream
thedream's Avatar
Postovi: 5,458
Stavi prvo drivere s CD-a da povuče,i pregazi ih slobodno sa 9.12 onda..radilo je odlično.
Staro 22.01.2010., 19:57   #105
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
nevidim u gpu-z na senzorima rpm od gpu radi se o 5750 s zadnjim atijevim driverima
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 23.01.2010., 01:26   #106
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
evo xfx 5750
http://www.imagesforme.com/show.php/...screanshot.jpg
iskreno necujem ju, no na 50% se vec li la cuje, na 80% je za mene buka jer sam navikao na tisinu
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 23.01.2010., 01:38   #107
Goranbm
Goranbm's Avatar
Postovi: 1,238
meni je ista situacija na 5770 verzija 2..... radi na 35% , temp mi j oko 30 C, ali RPM se ne vide
Staro 23.01.2010., 12:52   #108
D-I-A-B-L-O
Bannija :D
Lokacija: Sisak
Postovi: 1,098
Vjerojatno vam se nevide rpm zato što idu samo 2 žice iz ventilatora, dok se na onima sa 3 žice vide.
Na nijednoj sa 2 žice nisam mogao vidjeti rpm, premda ni neznam zašto bi to trebalo biti bitno.
Dok god je kartica hladna i tiha, uopće me ne zanima na koliko se okretaja vent vrti
Staro 23.01.2010., 12:53   #109
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
a doro mozda jos nije ta opciaj podrzana nisam ada pratio kat je taj gpu-z 0.3.8 izdan, mozda "0.3.9." bude to podrzavao nije mi tolika sila traziti rjesenje vazno da je necujna
EDIT: dns stavio cod4 osto sam zapanjen daleko bolje mi gura nego hd4850 na 4850 kad sam izgasio AA i AF i nek sitne detalje tipa water detail na low ili bullets impact, imo sam ajmo reci 70-100 znalo je kroz smoke past i na 40-60...uso u cod 4 ostavio na svemu najacem samo sam stavio bez af i AA 90-130FPS-a na onoj mapi mislim broadcast 130-240FPS-a reza je 1680x1050 nisam stigo na 1920 x 1080 budem kasnije grafa je mislim max bila na 69C* no budem opalio jos strest test pa cemo viditi dokle ce dourati inace tko kupi nece pogrijesiti i mogu u potpunosti reci da je UZASNO tiha ja imam XFX verziju za 1000kn nikad bolju grafu nisam kupio
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Zadnje izmijenjeno od: fre@k. 23.01.2010. u 14:01.
Staro 23.01.2010., 14:56   #110
Goranbm
Goranbm's Avatar
Postovi: 1,238
ima li mozda neko onaj battle forge kupon, da bi htio udjeliti ???
EDIT: Maloprije pokrenuo DIRT 2 , i na uvodnoj animaciji, mi se odjednom, pojavio skroz smeđi ekran sa okomitim crtama, isto smeđim... da li ima nekog razloga za zabrinutost??? jučer sam igrao DIRT 2 bez problema....
Zadnje izmijenjeno od: Goranbm. 23.01.2010. u 15:20.
Staro 23.01.2010., 15:40   #111
Metamphetamine
Flaccitra
Metamphetamine's Avatar
Lokacija: Vinkovci
Postovi: 276
Restartaj Windowse pa probaj, možda nešto sa driverima. Naravno ako se ponovi nakon restarta, probaj deinstalirat pa instalirat drivere nanovo.
Metamphetamine je offline   Reply With Quote
Staro 23.01.2010., 20:14   #112
D-I-A-B-L-O
Bannija :D
Lokacija: Sisak
Postovi: 1,098
Meni je taj smeđi ekran označio kraj moje hd4870, pokušaj sa driverima se malo zezat i prati temparature, skini neki od programa za testiranje kartice tipa OCCT ili furmark pa ga pusti na par minuta, ako prođe 5 minuta bilo kojega onda je najvjerovatnije driver, ako se opet pojavi smeđi ekran ili ako se jednostavno isključi monitor, furaj karticu na reklamaciju.
Staro 23.01.2010., 21:49   #113
Wolverine
Wolverine's Avatar
Postovi: 12,429
Uninstaliraj drivere, dobro očisti driver Cleanerom iz Safe moda i ponovno instaliraj drivere.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 23.01.2010., 22:40   #114
Goranbm
Goranbm's Avatar
Postovi: 1,238
Istestirao sam ju prvo u OCCT v3.0.0 i to 10 minuta, nije bilo errora, i zatim 10 minuta u Furmarku, i također je sve bilo u redu, budem onda danas još napravio ovo sa driverima, dovoljno da instaliram samo 9.12, jel?? ne moram stavljati nikakve fixeve ????
Staro 24.01.2010., 00:28   #115
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
koliko ja znam netrebas nikakve fixeve, sve bi trebalo sljakati uredno sam naglasak ti ide na SAFE MODE, ak radis iz windowsa nikad neobrise kak treba
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 24.01.2010., 02:04   #116
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 918
Kupio sam Sapphire 5770, 1Gb za 145e. Odlična karta.
Zadnje izmijenjeno od: Jelc. 24.01.2010. u 02:26. Razlog: Slike u thumb :-)
Staro 24.01.2010., 02:33   #117
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
evo na xfx-ovoj 5750 sam dobio u cod 4 max temp 74C* jednostavno neide preko a hladnjak je vrtio mislim na 40%
EDIT: evo igro maloprije cod 4, na 1920 x 1080 s 4AA, full sve...FPS je izmedju 60-120...ja super zadovolljan temperatura se nije mjenjala
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Zadnje izmijenjeno od: fre@k. 24.01.2010. u 02:53.
Staro 24.01.2010., 22:42   #118
Goranbm
Goranbm's Avatar
Postovi: 1,238
Da li je netko možda se malo igrao sa OC ove 5770... ??? i do koje granice???
Staro 28.01.2010., 17:41   #119
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 918
Code:
http://www.xtremesystems.org/forums/showthread.php?t=237414
Staro 28.01.2010., 20:22   #120
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
pitanje kolika je razlika izmenđu 5770 i 4890 i koju uzeti 5770 je kolko sam se raspitao 1030kn a 4890 1060kn, monitor je 19' a u nekih 6mj ce bit zamjenjen nekim 22' najvjerojatnije
i ako ima netko nekakvu stranicu sa perf jedne protiv druge
VoodooRain je offline   Reply With Quote
