Staro 24.08.2004., 13:57   #1
ljekra
ljekra's Avatar
Datum registracije: Dec 2003
Postovi: 391
Hitachi sata - power cable
Zanima me dali nakraju moraju biti oba power cable-a spojena ili ne smiju da bi dobili na performansama ili samo sata power cable?? nekuzim????
Moze li mi to neko objasniti? Pise na naljepnici, na straznjoj strani diska
I JOS OVO!
As you can see in the picture Hitachi attached a sticker with a warning label on it. It states you should only connect one power cable and not one to each of them as this might result in unwanted effects. This should be present on all drives with dual power connectors but it's always nice to see an effort taken in order to make the customer aware of this in order to minimize the risk of damage to the drive.
Toshiba U400 - 1.86GHz, 3Gb, 250Gb, 13.3''
HP NX7300 - 1.66GHz, 2Gb, 80Gb, 15.4''
Intel Server Board, XEON 2.0GHz, 1Gb ECC, 2x18.1Gb 10000rpm raid, 3x250Gb. 2x320Gb, 1x120Gb
ljekra je offline   Reply With Quote
Staro 24.08.2004., 14:13   #2
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Spoji ili jedan ili drugi, to nema veze sa performansama, stavili su oba tako da ne moraš mijenjati napajanje ili kupovati konvertore da bi ga spojio na napajanje.
Staro 24.08.2004., 14:16   #3
ljekra
ljekra's Avatar
Postovi: 391
Ma to kuzim, a sta bi trebalo znaciti -
Using both sata power connector and legacy power connector may cause UNPREDICTABLE RESULTS
Staro 24.08.2004., 14:33   #4
mitzek
Prigorec po defaultu
mitzek's Avatar
Lokacija: Pušća Gornja
Postovi: 1,410
Talking
neopisivo zadovoljstvo plavicastog dima i laganog srotanja u beskraj........
pitaj Raka,on je mislim to testiro...sa gore navedenim nuspojavama...
slikce:http://my.opera.com/Mitzek/blog/
sig na dijeti..,bolje on nege JA......
mitzek je offline   Reply With Quote
Staro 24.08.2004., 14:34   #5
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
ukopčaj oba pa vidi
jednostavno moraš ukopčati samo jedan od ta dva, nikako oba dva skupa...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 24.08.2004., 20:05   #6
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Bit ce onak kak je Mitzek opisao. Disk se "pali" na tu foru, WUSH!:burn:
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 25.08.2004., 00:00   #7
Tooma
Tooma's Avatar
Lokacija: malo st, malo vz
Postovi: 2,043
ljudi pokusavaju rec da to vridi za diskove koji na sebi imaju uticnicu i za novi sata utikac i za stari molex kakav imas na paralelnim diskovima
znaci ne smijes koristiti obe uticnice odjednom
Untitled Document
2x IBM Deskstar 40 GB
Pioneer DVD+-RW DVR-107D
Cretaive Live Player 5.1
Staro 25.08.2004., 18:03   #8
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Da, baš to. Ima oba priključka na disku i normalno da ne trebju oba dva za napajanje nego jedan.
