Lokacija: VG
Postovi: 1,758
XFX to Enter Power Supply Market with 850 W Black Edition
XFX to Enter Power Supply Market with 850 W Black Edition 'XFX are getting ready to announce their first power supply line at Computex Taipei 2009 next month. The first of which has been dubbed the 850 W Black Edition (XPS-850W-BES), which follows suit of many of their Black Edition graphics cards. It is a modular PSU featuring 88% effeciency and sports a 70A single 12v rail capped at 840 W. It would seem XFX are taking this seriously as the combined output across all of the wattage caps is in excess of 1,000 W. According to the slides the PSU features 105°C Japanese brand capacitors, +/-3% voltage regulation, solid polymer caps, and a 135mm ball bearing fan. Using a combination of fixed and removable cables the XFX 850 W Black Edition has 4 PCI-E 6+2 Pin connectors, 11 SATA connectors and 8 Molex connectors.' ![]() ![]() Izvor:www.techpowerup.com |
Postovi: 7,504
+12V sa 70A ![]() Izgleda strava, ali me zanima i možebitna buka. Inače svi proizvođači sada ulaze u neke druge vode, XFX napajanja, Ati grafike .... Još malo pa ćemo imati Zalman MBO ![]() |
Agent 0
Lokacija: Kutina - ZG
Postovi: 4,309
Agent 0
Postovi: 4,309
Postovi: 7,504
Agent 0
Postovi: 4,309
#9 | |
Postovi: 7,504
![]() ![]() Ma glavno je da bude tiho, a ova 135ice će biti teško zamjenjiva ako bude puno buke ![]() |
Postovi: 33,926
Nije Sapphire jedini. Mogu se kladiti da i Mushkin samo lijepi svoje naljepnice na tuđa napajanja.
Agent 0
Postovi: 4,309
its slightly turbocharged
Postovi: 5,430
Izgleda vrlo lijepo, klasična XFX zelena i crna kombinacija. Zna li se koja bi mogla biti očekivana cijena. Makar mi ovo 88% izgleda malkoc prenapumpano...
blaa |
Bill Gates
Lokacija: Vukovar
Postovi: 1,983
Izgleda sexy ![]() Al ne svida mi se to sto je na jednom railu +12V, pa makar i tolke snage. |
#18 |
Postovi: 12,425
#19 |
Lokacija: doma
Postovi: 964
#20 |
Agent 0
Postovi: 4,309
#23 |
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Posto je Seasonic u pitanju, odnosno X900 (ilitiga PC P&C Silencer 750), vrlo vjerojatno ce biti debelo iznad 1k kn ... neisplativo, bez obzira na izgled i originalnost ![]()
The Secret ... |
#24 |
Lokacija: VG
Postovi: 1,758
XFX Black Edition 850W review 'XFX entrusts the cooling of their first PSU to an Adda 135mm ball bearing fan. Adda’s fans are amongst the most reliable you can use nowadays, which justifies XFX’s selection. The 135mm ball bearing fan has a maximum rotational speed of 2050RPM, at which speed it creates air flow equal to 89.3 CFM and noise equal to 37.8dB(A). That would be a lot of noise for home systems but this fan is controlled by a logic circuit inside the PSU and should never rotate anywhere near its actual maximum speed.' 'XFX chose Seasonic to be their OEM partner and it appears that Seasonic have returned with one of their finest base designs. After opening the chassis of the Black Edition we easily noticed that it is based on the same design as the extremely popular M12D unit.' (@žile, pogodio si ![]() 'The primary capacitors both are industrial grade Nippon Chemi-Con KMR series products, covered by a very sophisticated filtering stage. All of the capacitors over at the secondary side are industrial grade Nippon Chemi-Con products, making this unit an all-Japanese affair. The heatsinks of the unit appear to be rather basic, but larger heatsinks won’t be necessary if this unit is able to perform at its advertised electrical efficiency.' 'Summary: By teaming up with Seasonic, XFX have released one of the most impressive products we have ever tested in our labs. Due to the class leading electrical performance, creative design and eye catching styling it is deserving of our most coveted award.' Izvor: driverheaven |
#26 |
Agent 0
Postovi: 4,309
#28 |
Lokacija: Krapinske Toplice
Postovi: 695
Izgledom paše u HAF škatulje. |
