Staro 23.04.2009., 17:44   #4321
Facelessone
Facelessone's Avatar
Postovi: 4,204
smanji detalje i rezoluciju onda
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 23.04.2009., 17:51   #4322
luckyluke
Datum registracije: Mar 2009
Postovi: 21
kad bi smanjio rezu da bih lijepo mogo igrati(to bi bilo 800x600)ne bih vidio 5 m ispred sebe tak da mi se to ne isplati.ceka se 2.svibnja kada dobivam grafulju
luckyluke je offline   Reply With Quote
Staro 23.04.2009., 19:38   #4323
luckyluke
Postovi: 21
sada imam wireless od 54 mbps bili sta pomoglo da nabavim od 108 mbps??
Staro 23.04.2009., 19:40   #4324
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
nebi... predaleko ti je router, jedino da nabaviš bolju antenu za router il jednostavno da spojiš žično
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 23.04.2009., 19:41   #4325
Facelessone
Postovi: 4,204
nebi, pomoglo bi ti da smanjiš rezu i podesiš detalje u igri. Isto tak kabel, ne wireless. Isto tak, možeš clockat komp, na vlastitu odgovornost, naravno.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 23.04.2009., 23:19   #4326
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor luckyluke Pregled postova
ma necu se ja igrat s IP.ima.ako ti nesto znaci zastitio sam wireless lozinkom sad neznam ima li to kakve veze...kako ne razumjes?igrica mi se spusti na 15 fpsa kad uđem u dim...kako mi onda komp nije preslab?
Wireless i MP jednostavno ne idu zajedno! To ti ljudi pričaju.
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO!
1oo1
NOOB - POWER IN NUMBERS!
Good judgment comes from bad experience and a lot of that comes from bad judgment.
MisterM je offline   Reply With Quote
Staro 24.04.2009., 12:18   #4327
luckyluke
Postovi: 21
e ovako...dali su druge online igrice poput counter strikea,wowa tako zahtjevene za network?dali bih mogao "u miru"igrati cs i wow??i dali ce cod6 ispraviti taj connection interrupted?
Zadnje izmijenjeno od: luckyluke. 24.04.2009. u 15:55. Razlog: Zabrljo sam!!:D
Staro 24.04.2009., 23:46   #4328
ThePornstar
Postovi: 4,403
koji si ti lik :S
to NEMA VEZE sa igricom itd, nego samo s tvojom konekcijom, odnosno s tvojim wirelessom. Očito imaš neke prepreke u kući (tipa zidovi) i konekcija je nikakva.
Najjednostavnije ti je žično spojit router s kompom.
A sad odi guglaj il tako nešto
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 24.04.2009., 23:49   #4329
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
aj definiraj to zahtjevne...
Staro 25.04.2009., 00:03   #4330
ThePornstar
Postovi: 4,403
ma zabrijo je da je cod4 tolko zahtjevan što se tiče veze da mu izbacuje connection interupted, što nema logike ali nemožeš mu objasnit
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 25.04.2009., 00:07   #4331
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
on misli da mu zbog veze dolazi do laga...pa neka spoji zicno je i on zabrijo...
Staro 25.04.2009., 00:21   #4332
ThePornstar
Postovi: 4,403
to mu tupimo cijelo vrijeme :S
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 28.04.2009., 10:15   #4333
Šegrt
Out Of Control
Šegrt's Avatar
Lokacija: Poreč
Postovi: 7
Za to mi se javite na PM ili MSN.
THX
Pozz svima...
Dakle, imam jedan problem. Radi se o stazi "Pipeline". Kad igram CoD4 Mp i kad na red dođe ta staza mene jednostavno izbaci sa servera. A to se isto događa mojim frendovima kojima sam posudio igricu. Zna li tko kako riješiti taj problem? I da li bi mi netko kome radi pipeline mogao iz Program Filesa poslati datoteku pipeline_mp pa da je provam replace-at sa svojom. --> Za to mi se javite na PM ili MSN.
THX
Šegrt je offline   Reply With Quote
Staro 28.04.2009., 14:41   #4334
Atrax
Atrax's Avatar
Postovi: 553
THX
http://rapidshare.com/files/226710013/english.7z.html
digo sam na rapidshare, pa eto....
obje datoteke iz zipa copy-pejstaj, al moguće da ti samo fali mp_pipeline_load.ff, mala datoteka, 1KB, a ona zapravo podiže tj loada mapu. Tak je kompić imo problem sa overgrown, falio mu je samo taj file i nije mu podizalo mapu, to je kopirao od mene i proradilo.
Kopiraj oboje pa vidi.
Autor Šegrt Pregled postova
Pozz svima...
THX
Atrax je offline   Reply With Quote
Staro 28.04.2009., 21:48   #4335
Šegrt
Out Of Control
Šegrt's Avatar
Lokacija: Poreč
Postovi: 7
THX @ Atrax
Sve radi...
Staro 01.05.2009., 17:47   #4336
Izet Fazlinovic
Izet Fazlinovic's Avatar
Lokacija: Osijek-Zagreb
Postovi: 336
jel netko zna radit u rconu10 za cod4? ja napravim profil, spoji mi se na server, maknem hely, bla bla bla.....i stisnem save, i onda kad izadem i ponovno pokrenem rcon opet mi sve po starom i opet moram micat hely itd..! i jel netko zna kako napravit da ako netko koristi zabranjena oruzja da ga pb kika! radim na default modu!?!? tek sam poceo radit sa rconom i nesnalazim se bas najbolje! please help!
Zadnje izmijenjeno od: Izet Fazlinovic. 01.05.2009. u 18:03.
Izet Fazlinovic je offline   Reply With Quote
Staro 01.05.2009., 21:12   #4337
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
Autor Izet Fazlinovic Pregled postova
Mora biti negdje tipka da on pokupi postavke sa servera. Onda ce ti biti postavke koje si zadnji puta namjestio.
I ja imam na ploci.
Staro 02.05.2009., 01:58   #4338
robert7
robert7's Avatar
Postovi: 1,711
najbolje je da si napravis server config koji ces uploadati na ftp. najbolji,najlaksi i najbrzi nacin
http://eu.prepsafe.com
robert7 je offline   Reply With Quote
Staro 02.05.2009., 13:43   #4339
brodjo
Playmaker
brodjo's Avatar
Lokacija: Osijek/Wien
Postovi: 1,660
cini mi se da on pravi od kuce server pa ce ipak morati svaki put podesavati u rconu
brodjo je offline   Reply With Quote
Staro 02.05.2009., 14:26   #4340
robert7
robert7's Avatar
Postovi: 1,711
Autor brodjo Pregled postova
a koja je razlika izmedu kucnog servera i onog kojeg kupis?
Sve je identicno,samo napravi ti server.cfg i miran si
Staro 02.05.2009., 16:19   #4341
Izet Fazlinovic
Postovi: 336
placam server, naso sam taj server.cfg! tamo sam poveco vrijeme igranja, mape koje da se vrte,, al nenadem gdje gasim helice, perkove neke, vote, itd...jel mi moze netko poslat svoj il nest, a promod mi ne odg jel nema bombi! ona tipka ocita sta je na serveru al uvjek isto, kad mi neusnimi!
Staro 02.05.2009., 17:41   #4342
robert7
robert7's Avatar
Postovi: 1,711
stavi si modwarfare,sve isto ko i unranked samo nema rankova i klasa,svi mogu birat sve.
Tam imas default_Server.cfg sa stvarima koje ti zelis palit i gasit.
Staro 02.05.2009., 19:33   #4343
Izet Fazlinovic
Postovi: 336
koji kod mod da stavim server.cfg mi je isti...
Staro 02.05.2009., 20:28   #4344
brodjo
Playmaker
brodjo's Avatar
Postovi: 1,660
lol pa nek stavi promod. ko kaze da na promodu nemaju bombe xD to mozes ukljuciti i iskljuciti.
Staro 02.05.2009., 22:06   #4345
robert7
robert7's Avatar
Postovi: 1,711
gle stavi fs_game "mods/modwarfare", u mods/modwarfare nadi default_server.cfg i tam promjeni UAV na 0,airstrike 0 itd itd
Staro 02.05.2009., 23:13   #4346
ivanb
Lokacija: Sukošan
Postovi: 214
Evo da vas pitam: da li je normalno da s ovim kompom sto mi je u profilu nemam 250 fpsa konstantno, naravno mislim s promodom, grafika naravno na najmanje.
ivanb je offline   Reply With Quote
Staro 02.05.2009., 23:22   #4347
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,400
Autor ivanb Pregled postova
A zašto bi imao?
Pa nije to neznam kakva pila.
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Amdejac je online   Reply With Quote
Staro 02.05.2009., 23:31   #4348
ivanb
Lokacija: Sukošan
Postovi: 214
Pa skoro svi imaju sa 250 s ovakvom konfom.
Staro 02.05.2009., 23:43   #4349
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
A ti vidiš naravno ogromnu razliku sa 125 i 250...
Dobro, sa nekim minimalni postavkama i 1024x768 morao bi imati 250 sa 4850
Šta se svi furaju na te FPSe ja ne vjerujem... ja sam na 7600GS sa 40 FPSa igrao jednako kao na 125 FPSa sa 8800GT
IMHO bolje da ti igra iole liči na nešto i imaš 125 (a to ti je previše) nego da gledaš cigle od pixela sa 250 FPSa...
blaa
Staro 03.05.2009., 00:03   #4350
ivanb
Lokacija: Sukošan
Postovi: 214
Ma nevidi se baš razlika, ali mi je malo čudno kako neće 250. Ma nema veze.
