Staro 23.04.2008., 00:31   #1
Phylip
Phylip's Avatar
Postovi: 256
Emulirani chrono trigger
Imam problem u tvornici kada dođem do računala i pritisnem šifru XABY
trebala bi se otvoriti vrata, ali kod mene se računalo samo ugasi
Šta je to?Skoro sam popizdio
Phylip je offline   Reply With Quote
Staro 23.04.2008., 02:26   #2
ejSid
Lunatic
ejSid's Avatar
Postovi: 213
Ja bih ti preporučio da se javiš sistemskom administratoru i da ništa ne diraš po firminim računalima.
ejSid je offline   Reply With Quote
Staro 23.04.2008., 08:14   #3
DevNull
Spam Witch
DevNull's Avatar
Lokacija: Belišće
Postovi: 94
Autor ejSid Pregled postova
Hahahahaha ... nisam se ovak dobro nasmijao skoro.
@Phylip: Ocito ti je rom los.
DevNull je offline   Reply With Quote
Staro 23.04.2008., 08:32   #4
Odojak
Odojak's Avatar
Postovi: 267
LOLČINA na prvi odgovor
Ni drugi nije točan :P, nije do roma već do tipkovnice. Nije da ne valja ali tipkovnica ne podržava toliko stisnutih tipki odjednom. Nisi naveo koji emulator koristiš ali općenito za sve njih vrijedi isto pravilo. Moraš mapirati XABY na jedan gumb
Evo citat za Snes9x:
Q: I come to some point in the game where I must press 3 buttons at the same time to continue, but when I do, nothing happens.
A: This is a keyboard limitation. Often kayboards don't recognize combos of 3 or more keys. To fix this, go into the Input menu and the Joystick config. For those 3 buttons you need to press, just assign them one key on the keyboard, any key not reserved by the emulator or your operating system. When you press that key now, it'll input those 3 buttons for the game, allowing you to continue. Now just reset the buttons to whatever keys they were assigned before and play as usual.
I citat iz zsnes FAQ-a
How do you get past the part in Chrono Trigger where you have to press the
L, R, and A buttons?
Assign two or all three of these SNES controller buttons to the same keyboard
key. You can do this under Config Menu -> Input. Please read the note about
keyboard limitations in the Input section [GUI.txt].
Odojak je offline   Reply With Quote
Staro 23.04.2008., 08:39   #5
DevNull
Spam Witch
DevNull's Avatar
Lokacija: Belišće
Postovi: 94
Autor Odojak Pregled postova
Ni drugi nije točan :P, ... Moraš mapirati XABY na jedan gumb
Odakle ti to da moras mapirat XABY na 1 button? Ja to nikad nisam morao raditi, mapirati XABY na 1 button ... doduse moguce da je do emulatora buduci da ja koristim Zsnes i radi mi sve odlicno.
Staro 23.04.2008., 09:22   #6
Odojak
Odojak's Avatar
Postovi: 267
Onda mi objasni otkuda mi onaj citat? Iz zsnes dokumentacije .
Games.txt
5. Individual Game Issues
Chrono Trigger
Staro 23.04.2008., 12:31   #7
Phylip
Phylip's Avatar
Postovi: 256
Games.txt
Taj dio sam prošao gdje treba stisnuti tri gumba da dobiš tajni prolaz,
ovo se odnosi na računalo u kojem moraš utipkat četiri gumba da
se otvori prolaz za završetak levela, mogla bi bit potpuno identična stvar,
samo kako da confam 4 gumba na jedan jednini.
Koristim snes
Staro 23.04.2008., 12:38   #8
Phylip
Phylip's Avatar
Postovi: 256
Staro 23.04.2008., 12:50   #9
Odojak
Odojak's Avatar
Postovi: 267
Sad sam izgubljen . Jel to onaj komp u onoj tvornici? Ako je onda je ovo gore sve ispalo nepotrebno.
Kad upališ komp on te traži password. Kad ukucaš X, onda trebaš čuti nekakav pisak / zvuk pa tek onda sljedeći gumb A itd.
Ako je to riješenje onda VELIKA isprika DevNull
Ako ni to nije onda ili čekaj da ti netko drugi pomogne jerbo bilo je daaaaaaaaaaaavno od zadnjeg igranja CT-a
Staro 23.04.2008., 14:21   #10
Phylip
Phylip's Avatar
Postovi: 256
[QUOTE=Odojak;1009515]Sad sam izgubljen . Jel to onaj komp u onoj tvornici? Ako je onda je ovo gore sve ispalo nepotrebno.
Ako ni to nije onda ili čekaj da ti netko drugi pomogne jerbo bilo je daaaaaaaaaaaavno od zadnjeg igranja CT-a[/QUOT
Da to je to treba stisnut gumb za pisak i tek onda napisat
Hvala
Staro 23.04.2008., 16:28   #11
DevNull
Spam Witch
DevNull's Avatar
Lokacija: Belišće
Postovi: 94
XABY je to o cem si sad rekao a ono o na sta si mislio gdje moras pritisnuti 3 gubma od jednom (navodno, dio gdje ti onaj ruzni parcov kaze password - squeek ) ne moras, pritisnes ih redom jedan za drugim malo brze nego obicno i otvori se normalno bez obzira na sve, meni taj dio radi ok kao sto sam vec napisao.
Staro 23.04.2008., 18:12   #12
Phylip
Phylip's Avatar
Postovi: 256
Moj problem je sto sam mislio da onaj beep znači da si dobro upisao šifru a zapravo znači da je tek trebaš upisat
Staro 28.04.2008., 18:44   #13
Phylip
Phylip's Avatar
Postovi: 256
Imam još jedno pitanje u vezi igre?
Di je "Deaths peak"?
Staro 29.04.2008., 08:12   #14
DevNull
Spam Witch
DevNull's Avatar
Lokacija: Belišće
Postovi: 94
Buducnost, gdje pronadjes onog robota. Malo trazi po mapi, vidjet ces ga kao nekakav ulaz u planinu.
Staro 29.04.2008., 14:32   #15
Phylip
Phylip's Avatar
Postovi: 256
Autor DevNull Pregled postova
Thanks
