Staro 16.02.2008., 23:08   #1
Razer
Razer's Avatar
Postovi: 11,642
Memtest86+ 2.11/4.0
Dakle, izašla je nova verzija Memtesta.
Dobro poznati program za testiranje stabilnosti i ispravnosti memorije,
ostatak o istom se, vjerujem, već zna
Change log:
New Features:
  • Major Architectures changes
  • Modulo test now use random pattern for better accuracy
  • Added Advanced DMI Errors Reporting Mode
  • Added support for bus ratio changes on Intel Core CPU
  • Added support for non-integer bus ratio on latest Intel CPU
  • Added SPD Data Display for all Intel Chipsets (more to come)
  • Added serial support as a linux boot parameter (Thanks to Michal S.)
  • Added preliminary support for VIA CN Isaiah CPU
  • Added preliminary support for Intel Nehalem
  • Added support for VIA C7/C7-D/C7-M/Eden on Esther Core
  • Added support for AMD K10 (Phenom) CPU w/ timings detection
  • Added support for Intel Pentium E w/ 1 MB L2 Cache
  • Added support for Intel Core 2 45nm (Penryn)
  • Added support for FSB1333/FSB1600 Intel CPU
  • Added support for Intel 5400A/5400B w/ timings detection
  • Added support for Intel Q35/P35/G33/Q33 w/ timings detection
  • Added support for Intel X38/X48 w/ timings detection
  • Added preliminary support for Intel 5000P/V/Z
  • Removed on-fly memory timings change (unstable)
Bug Fixes:
  • Numerous (really) bug fixes
Instructions for use:
  1. Make bootable USB drive with Windows boot image
  2. The mt200b7.exe file put it on the USB drive
  3. Boot with USB drive
  4. At DOS prompt type = mt200b7 to load it
DL Link: 2.0
DL Link: 2.0 beta 15
Homepage
Staro 17.02.2008., 00:41   #2
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Bravo Razer, i hvala Razer...
Sad mogu izmucit Ballistixe jos malo vise.
Staro 22.02.2008., 20:58   #3
Denzil
Secret Undercover Agent
Denzil's Avatar
Datum registracije: Sep 2004
Lokacija: Parallel Universe
Postovi: 1,130
Evo vec ima i 2.01..
*** Enhancements in v2.01 : ***
* New Features
o Added support for 45 nm Mobile Core 2 w/ 3 Mo L2
o Added support for i945GM/PM/GME & i946PL/GZ
o Added support for iGM965/iGL960/iPM965/iGME965/iGLE960
o Added detection for SiS 649/656/671/672
o Added detection for i430MX/i430TX
o Added an optional beep mode (pass completed w/o error)
o Pass duration 20% reduced
o Removed the blinking cursor
o Reverted Test #0 to cached
* Bug Fixes
o Solved a major bug in Memory Address Errors Reporting
o Patched for Intel-Powered Mac
o Corrected Intel 3-Series (P35/X38) chipset init
o Corrected a bug with SPD Display and ESB6300
o Correct a detection bug on P965/G965 C-Stepping
o Solved a incoherency with pass progress indicator
o Patched Makefile to compile on x86_64
o Bootable Memtest86+ ISO more compatible
"I can resist everything except temptation"
Denzil je offline   Reply With Quote
Staro 23.12.2008., 04:50   #4
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Memtest86+ v2.11.iso
* New Features
o Added support for Intel Core i5 (Lynnfield) CPU
o Added support for Intel P55 Southbridge
o Added support for Intel PM45/GM45/GM47 Mobile chipset
o Added support for Intel GL40/GS45 Mobile chipset
* Bug Fixes
o Corrected DDR2/DDR3 detection on Intel x35/x45
o Corrected detection on some Core i7 CPU
o Fixed a bug with some AMI BIOS (freeze at startup)
o Various bug fixes
Need a Gigabyte latest BIOS?
GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz
G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2)
G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1)
Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD,
Corsair Hydro-H50 (MX-2)
Gigabyte Superb 720W,Windows 7 SP1
stasio je offline   Reply With Quote
Staro 23.12.2008., 14:17   #5
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
O, najz..hvala.
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Brown Acid je offline   Reply With Quote
Staro 23.12.2008., 14:32   #6
Melani
Lokacija: doma
Postovi: 964
Melani je offline   Reply With Quote
Staro 23.12.2008., 16:36   #7
Jablan
Jablan's Avatar
Datum registracije: Jul 2004
Postovi: 756
E ova USB verzija je odlična. Baš ono što mi treba, da ne moram nosati cd.
Jablan je offline   Reply With Quote
Staro 22.09.2009., 23:05   #8
Voorhees
Datum registracije: Jul 2003
Postovi: 167
Memtest86+ v4.00
*** Enhancements in v4.00 : ***
* New Features
o Major Architectural changes
o First pass twice faster (reduced iterations)
o Detect DDR2/3 brands and part numbers on Intel DDR2/3 chipsets
o Added detection for Intel "Clarkdale" CPU
o Added detection for Intel "Gulftown" CPU
o Added detection for AMD "Magny-Cours" CPU
o Added detection for Intel XMP Memory
o Added for CPU w/ 0.5/1.5/3/6/12/16/18/24MB L3
o Added "clean" DMI detection for DDR3/FBDIMM2
o Better detection of Integrated Memory Controllers
* Bug Fixes
o Corrected detection for Intel "Lynnfield" CPU
o Corrected detection for AMD 45nm K10 CPU
o Solved crash with AMD Geode LX
o Complies with SMBIOS 2.6.1 specs
o Fixed compilation issues with gcc 4.2+
o Many others bug fixes
PS : Memtest86+ "3.00" was skipped and renamed 4.00 in order to avoid confusion with the original Memtest.
Download
Voorhees je offline   Reply With Quote
Staro 05.05.2010., 09:11   #10
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Memtest86+ ver.4.10
* New Features
o Added support for Core i7 Extreme CPU (32nm)
o Added support for Core i5/i3 (32 nm)
o Added support for Pentium Gxxxx (32 mn)
o Added support for Westmere-based Xeon
o Added preliminary support for Intel Sandy Bridge
o Added support for AMD 6-cores CPU
o Added detection for Intel 3200/3210
o New installer for USB Key
* Bug Fixes
o Corrected a crash at startup
Pre-Compiled Bootable ISO (.zip)
http://www.memtest.org/download/4.10...+-4.10.iso.zip
Pre-Compiled Bootable Binary (.zip)
http://www.memtest.org/download/4.10...st86+-4.10.zip
Auto-installer for USB Key (Win 9x/2k/xp/7)
http://www.memtest.org/download/4.10/memte...b.installer.zip
Pre-Compiled package for Floppy (DOS - Win)
http://www.memtest.org/download/4.10/memte...4.10.floppy.zip
Staro 31.05.2010., 01:59   #11
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Memtest86+ ver.4.15 beta 2
Pre-Compiled Bootable ISO (.rar)
-internal release
