Staro 18.04.2004., 21:39   #1
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Drajveri za Radeonku
Evo nabavio sam fala bogu konačno novu grafu(look at sig).Nikad nisam imao Ati grafu,pa možete mi preporučit drivere,kako ih instalirat,neke tweakove ili nešto takovo.Kakvi su Omega drajveri,jel imaju kakve posebne zahtjeve?Fala unaprid
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 18.04.2004., 22:14   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
http://www.omegacorner.com/index_ati.html
REMINDERS:
1- If you have the normal ATI drivers installed, uninstall the ATI Control Panel
BEFORE upgrading to these drivers, the Omega Drivers already have the CP integrated
and another CP will cause conflicts or other problems.
2- There is no need to uninstall ANY previous drivers (ATI or OMEGA) when
installing these, they will override any previous settings.
3- In Windows 2k/XP, ALWAYS disable DDC in the ATI "Displays/Monitor" CP after
installing drivers to be able to use ALL the refresh rates and resolutions
your monitor supports, also this is the best way to avoid the 60Hz RR bug.
Samo pukni gore Omegu i uživaj
