Zaključane teme
Staro 18.01.2008., 18:56   #1
Rahonavis
Postovi: 1
DVD przilica ATAPI DVD A DH20A4P
Molim pomoc.. nova przilica nece radit ono za sto je napravljena.. PRZITI..
Hvala unaprijed...
Log od Nera mi je ostao ovakav...
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.7.5.1
Internal Version: 7, 7, 5, 1
Recorder: <ATAPI DVD A DH20A4P> Version: 9P53 - HA 1 TA 0 - 7.7.5.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <ATAPI DVD A DH20A4P >Version: 9P53 - HA 1 TA 0 - 7.7.5.1
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y200P0 YAR4 nvidesm Port 0 ID 0 DMA: Off
DiskPeripheral : QUANTUM FIREBALL EX6 A0A. nvidesm Port 0 ID 1 DMA: Off
CdRomPeripheral : ATAPI DVD A DH20A4P 9P53 nvidesm Port 0 ID 0 DMA: Off
CdRomPeripheral : HL-DT-STCD-RW GCE-8520B 1.02 nvidesm Port 0 ID 1 DMA: Off
CdRomPeripheral : RS7044S LSF243R 1.01 a3vpypxv Port 1 ID 0 DMA: Off
=== CDRom-Device-Map ===
ATAPI DVD A DH20A4P D: CDRom0
HL-DT-ST CD-RW GCE-8520B G: CDRom1
RS7044S LSF243R J: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 544MB (557396kB)
Memory in use : 46 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.1.2008
ISO compilation
17:36:11 #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
17:36:11 #2 Text 0 File Isodoc.cpp, Line 6527
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
17:36:11 #3 ISO9660GEN -11 File Geniso.cpp, Line 3334
First writeable address = 0 (0x00000000)
17:36:11 #4 Text 0 File Burncd.cpp, Line 3465
Turn on Disc-At-Once, using DVD media
17:36:12 #5 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 1724191 (383:09.16, 3367MB)
17:36:12 #6 Text 0 File DlgWaitCD.cpp, Line 318
Write in overburning mode: NO (enabled: CD)
17:36:12 #7 Text 0 File DlgWaitCD.cpp, Line 2912
Recorder: ATAPI DVD A DH20A4P, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
17:36:12 #8 Text 0 File DlgWaitCD.cpp, Line 490
>>> Protocol of DlgWaitCD activities: <<<
17:36:12 #9 Text 0 File ThreadedTransferInterface.cpp, Line 823
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1724192 (1724192) = #1724192/383:9.17
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1724192 blocks [D: ATAPI DVD A DH20A4P]
17:36:12 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1026
Prepare [D: ATAPI DVD A DH20A4P] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3531145216, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 1724192 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1724192 | 0 | 0x00
1724192 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
17:36:12 #11 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
17:36:12 #12 Phase 24 File dlgbrnst.cpp, Line 1760
Caching of files started
17:36:12 #13 Text 0 File Burncd.cpp, Line 4298
Cache writing successful.
17:36:12 #14 Phase 25 File dlgbrnst.cpp, Line 1760
Caching of files completed
17:36:12 #15 Phase 36 File dlgbrnst.cpp, Line 1760
Burn process started at 8x (11.080 KB/s)
17:36:12 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2764
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
17:36:12 #17 Text 0 File Cdrdrv.cpp, Line 9288
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: MCC.....
Media type ID: 004
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
17:36:12 #18 Text 0 File DVDR.cpp, Line 6833
Drive: ATAPI DVD A DH20A4P
Book Type request [LO], rev 3: DVD-ROM
Changing the Book Type was finished successfully, return code 0
17:36:12 #19 CDR -1207 File DVDR.cpp, Line 6212
Book Type automatically set to: DVD-ROM
17:36:12 #20 Text 0 File DVDPlusRW.cpp, Line 674
Start write address at LBA 0
DVD high compatibility mode: Yes
17:36:19 #21 SPTI -500 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x00) WinError(1117) NeroError(-500)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x22040040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
17:36:23 #22 SPTI -1033 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x01
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01
Buffer x08060080: Len x10000
17:36:23 #23 CDR -1033 File Writer.cpp, Line 301
Drive not ready
17:36:23 #24 SPTI -1033 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
17:36:23 #25 SPTI -1033 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
17:36:23 #26 Phase 127 File dlgbrnst.cpp, Line 1760
Generating DVD high compatibility borders
17:36:29 #27 Text 0 File DVDR.cpp, Line 6833
Book Type request [LO], rev 3: DVD+R
17:36:29 #28 CDR -1033 File WriterStatus.cpp, Line 162
Drive not ready
17:36:30 #29 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
17:36:31 #30 Phase 38 File dlgbrnst.cpp, Line 1760
Burn process failed at 8x (11.080 KB/s)
17:36:32 #31 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
17:36:34 #32 Text 0 File Cdrdrv.cpp, Line 10529
DriveLocker: UnLockVolume completed
17:36:34 #33 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Zadnje izmijenjeno od: Rahonavis. 18.01.2008. u 19:18.
Rahonavis je offline
Zaključane teme
