Staro 18.01.2008., 08:59   #1
Miha-Đakovo
Miha-Đakovo's Avatar
Lokacija: Đakovo
Postovi: 52
Kako dva HDD Seagete 320 GB (potpuno ista) narediti da radi u RAID polju 0?
Pitanje iz naslova.... Hvala!!
Evo u manualu piše ovako:
4-1-4 Configuring SATA Hard Drive(s)
To configure SATA hard drive(s), follow the steps below:
(1) Install SATA hard drive(s) in your system.
(2) Configure SATA controller mode and boot sequence in BIOS Setup.
(3)* Configure RAID set in RAID BIOS.
(4) Make a floppy disk containing the SATA controller driver.
(5) Install the SATA controller driver during OS installation.
Before you begin
Please prepare:
(a) At least two SATA hard drives (to ensure optimal performance, it is recommended that you use two
hard drives with identical model and capacity). If you do not want to create RAID, you may prepare
only one hard drive.
(b) An empty formatted floppy disk.
(c) Windows XP/2000 setup disk.
(d) Driver CD for your motherboard.
A. nVIDIA
® nForce 590SLI Southbridge
(1) Installing SATA hard drive(s) in your computer
Attach one end of the SATA signal cable to the rear of the SATA hard drive and the other end to available
SATA port(s) on the motherboard. If there are more than one SATA controller on your motherboard, you
may refer to the motherboard user's manual to identify the SATA controller for the connector. Then
connect the power connector from your power supply to the hard drive.
GA-M59SLI-S5/GA-M59SLI-S4 Motherboard - 80 -
English
Figure 1
Ensure that
NV SATA RAID function is enabled (Figure 2). For example, if you wish to create RAID
with hard disks on the SATAII0 and SATAII1 connectors, ensure that
NV SATA 1 Primary/Secondary
RAID
are enabled (Figure 2).
The BIOS Setup menus described in this section may not show the exact settings for your
motherboard. The actual BIOS Setup menu options you will see shall depend on the motherboard
you have and the BIOS version.
Figure 2
(2) Configuring SATA controller mode and boot sequence in BIOS Setup
You have to make sure whether the SATA controller is configured correctly in system BIOS Setup and
set BIOS boot sequence for the SATA hard drive(s)/RAID array.
Step 1:
Turn on your computer and press Del to enter BIOS Setup during POST (Power-On Self Test). In BIOS
Setup, go to
Integrated Periperals --> Serial-ATA RAID Config (Figure 1).
CMOS Setup Utility-Copyright (C) 1984-2006 Award Software
Integrated Peripherals
Serial-ATA RAID Config [Press Enter]
On-Chip IDE Channel0 [Enabled]
On-Chip MAC Lan [Auto]
On-Chip MAC1 Lan [Auto]
NV Serial-ATA Controller [All Enabled]
IDE Prefetch Mode [Enabled]
Onboard Audio Function [Auto]
SMART LAN [Press Enter]
Onboard 1394 [Enabled]
Onboard LAN Boot ROM [Disabled]
Onboard SATA/IDE Ctrl Mode
1 [IDE]
Onboard Serial Port 1 [3F8/IRQ4]
Onboard Parallel Port [378/IRQ7]
Parallel Port Mode [SPP]
x ECP Mode Use DMA 3
On-Chip USB [V1.1+V2.0]
USB Keyboard Support [Disabled]
USB Mouse Support [Disabled]
Legacy USB Storage detect [Enabled]
: Move Enter: Select +/-/PU/PD: Value F10: Save ESC: Exit F1: General Help
F11/12: Profile F5: Previous Values F6: Fail-Safe Defaults F7: Optimized Defaults
Item Help
Menu Level
Item Help
Menu Level
NV SATA RAID function [Enabled]
NV SATA 1 Primary RAID
[Enabled]
NV SATA 1 Secondary RAID
[Enabled]
NV SATA 2 Primary RAID
[Disabled]
NV SATA 2 Secondary RAID
[Disabled]
NV SATA 3 Primary RAID
[Disabled]
NV SATA 3 Secondary RAID
[Disabled]
- 81 - Appendix
English
Step 2:
To boot from Windows installation CD-ROM, set
First Boot Device under the Advanced BIOS
Features
menu to CDROM (Figure 3).
Step 3:
Save and exit BIOS Setup.
Jel to?
P.S. a+Ako je to molio bi nekog da mi prevede na Hrvastki ...
MOJ KOMP: CPU AMD Athlon64 X2 6000+, Matična : MB Gigabyte M59SLI-S4, sAM2, Mema: 1GB PC6400 (800MHz), Kingmax x2, HDD Seagate ST3320620AS, 320 GB 16MB, Grafička : Gigabyte 8800 GTS 320 MB, napajanje: OCZ 600W.
Miha-Đakovo je offline   Reply With Quote
Staro 18.01.2008., 09:03   #2
Miha-Đakovo
Lokacija: Đakovo
Postovi: 52
Ili je možda ovo:
(3) Configuring RAID set in RAID BIOS
Enter the RAID BIOS setup utility to configure a RAID array. Skip this step and proceed to Section 4 if
you do not want to create RAID.
Step 1:
After the POST memory test begins and before the operating system boot begins, look for a message
which says "Press F10 to enter RAID setup utility" (Figure 4). Hit the
F10 key to enter the RAID BIOS
setup utility.
Figure 4
Step 2:
The Define a New Array screen is the first option screen when you enter the NVIDIA RAID setup utility.
(Figure 5). You can press the TAB key to highlight through options.
Step 3:
In the RAID Mode field, use the UP or DOWN ARROW key to select a RAID mode. The supported RAID
modes include Mirroring (default), Striping, Stripe Mirroring, Spanning and RAID 5. The following is an
example of RAID 0 array creation.
Step 4:
If RAID 0 (Striping) is selected, you can manually set the striping block size. In the Striping Block field,
use the UP or DOWN ARROW key to set the Striping Block size. The
KB is the standard unit of Striping
Block size. We recommend you leaving it to the default setting--Optimal (64K). The size range is from
4K to 128K.
Figure 5
MediaShield IDE ROM BIOS 6.55
Copyright (C) 2006 NVIDIA Corp.
Detecting array ...
Press F10 to enter RAID setup utility ...
MediaShield Utility Mar 22 2006
- Define a New Array -
RAID Mode: Striping Striping Block: Optimal
Free Disks
Loc Disk Model Capacity
1.0.M ST3120026AS 111.78GB
2.1.M ST3120026AS 111.78GB
Array Disks
��] Add
��] Del
[ESC] Quit [F6] Back [F7] Finish [TAB] Navigate [
����] Select [ENTER] Popup
- 83 - Appendix
English
Step 6:
Press F7 after selecting the target hard disks. A message which says "Clear disk data?" will appear
(Figure 7). If you are sure to clear the data in the selected hard drives, press Y. (If the hard drives
contain previously created RAID array, you need to press Y to clear the data from the hard drives.)
Figure 7
Figure 6
Step 5:
Next, select the hard drives which you wish to be included in the disk array. The Free Disks section
displays the information about the currently installed SATA hard drives. Press the TAB key to move to
the Free Disks section. Select the target hard drives using the UP or DOWN ARROW key and use the
RIGHT ARROW key to add the hard drives to the Array Disks section (Figure 6).
��] Add
��] Del
Free Disks
Array Disks
Clear disk data ?
[Y] YES [N] NO
��] Add
��] Del
Array Disks
Free Disks
Clear disk data ?
[Y] YES [N] NO
GA-M59SLI-S5/GA-M59SLI-S4 Motherboard - 84 -
English
To read more information about the RAID array, press ENTER to enter the Array Detail screen (Figure
9), where you should see detailed information about RAID mode, disk block size, disk model name,
and disk capacity, etc.
Figure 9
Figure 8
After that, the Array List screen displaying the RAID array you created will appear (Figure 8).
If you want to set the disk array as boot device, use the UP or DOWN ARROW key to select the array
and press B. The
Boot section will show Yes.
To delete the array, press D in the Array Detail screen. When the "Delete this array?" message appears,
press Y to confirm or N to cancel. Press ENTER to return to the Array List screen.
To exit the Nvidia RAID utility, press ESC in the main menu or Ctrl+X in the Array List screen.
Now, you can proceed to install the SATA controller driver and operating system.
