Staro 21.03.2004., 12:02   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radeon Omega Drivers v2.5.30 for WinXP/2k
Evo-čovjek je imao puno posla,usporedno je radio i na Nvidia driverima, a kak sam veli"Sorry for the delay, too much work and I used my free time to play and finish Gothic II (BTW, Awesome RPG"
Uglavnom driveri su gotovi i možete ih skinuti tu:
http://www.driverheaven.net/downloads/index4.htm
http://206.172.2.40/~judas/Downloads...omega_2530.exe
hat's New? (2k/XP 2.5.30)
* Based on the Official Catalyst 4.3 drivers.
* Updated the Omega version of RadLinker. Many thanks to ChrisW!
* Now that the FW issue seems to have been solved for 9600 cards, forced
Fastwrites OFF for ALL cards.
* Fixed installation issue for FireGL cards.
* Added support for Mobility 9700.
* Updated the Omega logo in the options screen.
Important Notes:
1. If you are using an Omega soft-mod and you are experiencing crashes, black screens,
artifacts or the "check board effect" during gameplay, re install the drivers using
the normal option, the reason is your card is not accepting the soft-mod due to
broken/incompatible hardware.
REMINDERS:
1- If you have the normal ATI drivers installed, uninstall the ATI Control Panel
BEFORE upgrading to these drivers, the Omega Drivers already have the CP integrated
and another CP will cause conflicts or other problems.
2- There is no need to uninstall ANY previous drivers (ATI or OMEGA) when
installing these, they will override any previous settings.
3- In Windows 2k/XP, ALWAYS disable DDC in the ATI "Displays/Monitor" CP after
installing drivers to be able to use ALL the refresh rates and resolutions
your monitor supports, also this is the best way to avoid the 60Hz RR bug.
4- The WDM drivers for VIVO and AIW cards are not included, but they can be
downloaded separately from a link in my drivers page.
5- The Radeon cards do support FastWrites and they will work with it on
(on some machines), but it is not recommended, there is NO SPEED gain
when using FW, and this option will affect your PC's stability a LOT,
most game crashes and problems are because FW is enabled.
I don't recomend the use of ANY external tweakers with my drivers (specially Rage3D
tweaker), as they override my special settings and will make my work useless. The only
time I recommend a tweaker is when you have a specific problem with a specific tweak
and need to change it in order to make the drivers work correctly. Also if you use
a tweaker for overclocking, FSAA, Gamma or Aniso settings, is just fine, but you'll
be better off using the integrated ATI CP for that (which is ok by me if you change
any setting in it).
If you have any problems with this drivers please go to my webpage
and look in the ATI help section for answers. If still have problems
look for the drivers thread in www.driverheaven.net forums and let me know
what is going on.
If you happen to find a new tweak or fix for a specific game or many games
and it proves that it works then drop me an E-Mail (don't post it in the
forums), I'll make sure credit will be granted to that person in this INFO file.
Staro 21.03.2004., 12:37   #2
ßellerophon
Sannin
ßellerophon's Avatar
Datum registracije: Jun 2003
Postovi: 1,568
jel ima softmod 9700 ->9800?
YES - BUT /
Staro 21.03.2004., 12:53   #3
Jelc
Super Moderators
Postovi: 17,485
Mislim da je samo maknuta opcija 9700-9800, ali da istu stvar dobiješ odabirom pri instalaciji 9800SE-9800
Samo odabereš tu opciju pri instalaciji drivera i to ti je to
Staro 21.03.2004., 12:54   #4
Mailman
Mailman's Avatar
Postovi: 1,606
Nema.
9500->9700 i 9800se->9800
Mailman je offline   Reply With Quote
Staro 21.03.2004., 13:23   #5
Jelc
Super Moderators
Postovi: 17,485
Originally posted by Mailman
Nema.
Pa dobro-da li itko čita napisano???
Pa on sam je rekao da je samo maknuo 9700-9800 iz izbornika pri instalaciji i da istu stvar dobiješ sa 9800SE-9800.
Pisalo je lijepo i u objašnjenju zadnjih drivera, samo se nikom izgleda ne da pročitati...
Staro 21.03.2004., 23:37   #6
ßellerophon
Sannin
Postovi: 1,568
prije sam citao... i sve sam sam pratio...
sad kad imamo tebe... koji dobije emailom poruku od omege da ce izdat nove.. pitamo tebe...
YES - BUT /
Staro 22.03.2004., 00:10   #7
Jelc
Super Moderators
Postovi: 17,485
prije sam citao...
"I just removed the installer option for the 9700->9800 soft-mod, but if you still want it, just use the 9800SE soft mod instead, it's THE SAME"
To bi trebalo svatkom biti jasno...valjda
Staro 22.03.2004., 01:05   #8
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Idem i ja instalirat te omega drivere da vidim sta tu sve ima i kako to radi .
Staro 22.03.2004., 13:03   #9
ßellerophon
Sannin
Postovi: 1,568
jesam li rekao da mi nije to jasno? confused:
samo komentiram... zasto ne idem na njegove stranice citat...
YES - BUT /
Staro 22.03.2004., 13:49   #10
Jelc
Super Moderators
Postovi: 17,485
Skinuo noćas, sad sam ih instalirao i odvrtio par testova.
Rade fino, za sad nikakvih problema, nadam se samo da ću danas moći isprobati i Far Cry , da vidim i ja konačno to "čudo od grafike"
Sad je FW konstantno isključen u driverima za sve grafe, ako netko baš hoće to koristiti mogu mu hitit link kako ga ponovno aktivirati.
Staro 22.03.2004., 16:21   #11
ZMAJ
Postovi: 2,937
super.
cekam "vec" tjedan/dva te drivere da ih sprzim pa formatiram disk...
odlucio sam sve fino nanovo instalirati...
ZMAJ je offline   Reply With Quote
Staro 22.03.2004., 18:36   #12
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
uhh..... Sami problemi... Prvo su mi usporili komp do brzine puza... zatim ih deinstaliram i nakon restarta samo povavlja instalaciju onog programa za OC.... u nedogled.... zatim i to nekako uspijem uninstall... al opet sve sporo...jedva namjestim... naljutio se ko..... sta ja znam... da sam lijepo poludio od glasnoce kompa.. pa sam ugasio komp, izvadio napajanje (codegen300W), modao vent da radi na 7v (sad se necuje, al slabo puse ), skinuo 60mm vent sa CPU coolera (glasan ko avion) i stavio 80mm vent (necuje se, radi na 12v). Vent na grafickoj sam iskljucio a stavio sam 80mm na 7v ... jedino sto se cuje je HDD a cuje jaaaaaako )
Eto sta mogu driveri uradit covjeku
:burn:
Staro 22.03.2004., 20:25   #13
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Cudno meni normalno dela.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 22.03.2004., 21:12   #14
ZMAJ
Postovi: 2,937
ja sam imao problema sa omegom 4.2 zato sam jedva cekao ove...
Staro 22.03.2004., 23:24   #15
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Staro 23.03.2004., 00:12   #16
Jelc
Super Moderators
Postovi: 17,485
Originally posted by MadBoY
uhh..... Sami problemi... Prvo su mi usporili komp...
Da li si deinstalirao CP prije instalacije Omege?
Ako usporava-onda istaliraš AGP driver NAKON instalacije Omega drivera.
Ili driver cleaner pa sve počistiti,nove drivere za ploču, novi DX pa drivere od grafe.
Meni delaju super
Staro 23.03.2004., 00:40   #17
ThIeF
ThIeF's Avatar
Datum registracije: Feb 2004
Postovi: 218
e sad skidam te omega drivere! sta cu ja postic s 9700 ak instaliram one drivere za modanje 9700 u 9800???
ThIeF je offline   Reply With Quote
Staro 23.03.2004., 01:20   #18
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Meni delaju super
naravno dam sam deinstalirao CP prvo. Neznam u cem je problem.
Staro 23.03.2004., 02:55   #19
ßellerophon
Sannin
Postovi: 1,568
100% su ti ostali neki orig. driveri - upotrijebi driver cleaner
mislim da imas previse slobodnog vremena... D
usput kako te sluzi to napajanje (codegen300W)?
YES - BUT /
Staro 23.03.2004., 03:40   #20
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
10-15%, za točne brojke pitaj prof.dr.ATi Jelca
Grunf je moj idol!
Staro 23.03.2004., 15:07   #21
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Po cem si zakljucio da imam previse slobodnog vremena?
Napajanje je dobro... al previse buke proizvodi (bar za moje usi ).
Staro 23.03.2004., 16:26   #22
Jelc
Super Moderators
Postovi: 17,485
Barem 10% u AA, a to i nije baš malo
Staro 23.03.2004., 20:26   #23
ThIeF
ThIeF's Avatar
Postovi: 218
e neš mi bolje radi far cry!!! sve je na very high osim aa koji je na normal!!! e morate nabavit cijelu igru, demo je sranje!! sam da imam onaj cd-key pa da prek neta mogu igrat!!
Staro 23.03.2004., 21:43   #24
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
) sam da imam onaj cd-key pa da prek neta mogu igrat!!
Samo ga nemoj ovdje trazit .
Staro 23.03.2004., 21:45   #25
ZMAJ
Postovi: 2,937
pazi kaj pricas jer su ti moderatori ovdje vrlo opasni
Staro 23.03.2004., 23:00   #26
ThIeF
ThIeF's Avatar
Postovi: 218
da procito sam tam o ponašanju na forumu!! heheh!!
a dobro nisam vas tražio to! :burn:
e igrate kaj vi prek neta???
Staro 24.03.2004., 17:33   #27
Jelc
Super Moderators
Postovi: 17,485
uhh. i nakon restarta samo povavlja instalaciju onog programa za OC.... u nedogled.... zatim i to nekako uspijem uninstall... al opet sve sporo...
:burn:
Izgleda da vas je više imalo slične pizdarije
Zadovoljni korisnici su se pobunili pa je ponosni autor programa brže-bolje ispravio stvar.
"I think I found the problem with the installer that causes it to loop over and over. Try the new version (1.006) and let me know if it fixes the problem."
www.RadLinker.com
Staro 24.03.2004., 22:55   #28
ZMAJ
Postovi: 2,937
Ja igram Age of empires II: The Conquerors vec preko dvije godine tak da sam jako dobar...
Igrao bi ja neki UT ili Quake3(presao sam na nightmare) ali imam 56k a kad sam probao sa 56k quake na netu onda posaljem raketu a ping je tolko sjeban da ona izade nakon 2/3sec i pogodi mene!!!! LMAO
Staro 25.03.2004., 01:01   #29
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
www.RadLinker.com
Mogu ti rec da mi je drago sto mi se to desilo jer sad imam dosta tisi komp .
Staro 25.03.2004., 13:30   #30
ßellerophon
Sannin
Postovi: 1,568
po onome da si isao promjenit drivere pa promjenio pola kompica...
imam i ja codegen 400W , ne koristim ga ali kad sam ga isprobao bi je stvarno tih...
trebam zapamtit da ima novi radlink probleme... kad formatiram...
YES - BUT /
