Staro 23.11.2007., 19:16   #1
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
AC Alpine 7 cooler?
Jel ima tko iskustva s doticnim? Koliko je tisi od vulgaris intelovog? Treba mi za neki HTPC, a ne bih htio dat vise od 100kn
Staro 25.11.2007., 09:51   #2
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Nasao...a jeste lijeni ko' batine, hehe...Uglavnom, kuler je slabiji 25% od Intel stocka, ali je tisi 75%. Idealno za HTPC Sutra stize iz Linksa pa cemo vidjeti score.
PC-Modders: Alpine 7
Arctic Cooling's Alpine cooler is incredible silent. The perfect balance between necessary cooling and noise. A wonderful choice if you're bothered with noise from your computer. Within a nice package, you get an easy installable cooler. The special fan feature sound absorbing rubber suspensions, which takes care of much irritating noise. Alpine gave us a bit hotter CPU o*n idle than the boxed cooler, but inchange of much lower noise we like it. And as we can see, o*n the illustrated image, the fan blows air over other components as well. A great low noise CPU cooler. Thumbs up.
Arctic Cooling realizes that not everyone shopping for a processor heatsink is looking to overclock their CPU to extreme frequencies. Some people are just looking to upgrade the stock cooler to a more efficient and quiet cooler for peace of mind, equipment longevity, and peace and quiet.
Introducing the Alpine 7 CPU Cooler from Arctic Cooling! The Alpine 7 is over 75% quieter then the stock Intel 775 Box Cooler yet is almost 25% more efficient! Featuring a 92mm 2000RPM fan, the Alpine 7 flows 36CFM through all 4 directions in order to also help cool the voltage converters and chipset. Patented rubber vibration dampeners absorb the vibration of the running fan preventing vibration transfer to the heatsink and case.
While most aftermarket coolers lighten your wallet while heavying up your computer, the Alpine 7 weighs in at 486g taking it easy on your back and your children's college funds. Installing within seconds, the Alpine 7 is easy to install and comes with pre-applied ARCTIC MX-1 thermal compound. So if you are looking for a better performing, quieter then stock CPU cooler that won't break your budget, pick up the Alpine 7 from Arctic Cooling today!
Specifications:
* Compatibility:
o Intel:
+ LGA775
* Rated Fan Speed: 300-2000RPM
* Power Consumption: 0.15A
* Air Flow: 36 CFM
* Noise Level: 0.6 Sone
* Thermal Resistance: 0.26°C
* Thermal Interface Material: Pre-applied MX-1 Paste
* Weight: 486g
* Dimensions: 113 x 101 x 91.7mm (L x W x H)
* Manufacturer Warranty: 6 Years
Evo i malo slikica...
http://www.newegg.com/Product/Produc...82E16835186009
