Staro 29.02.2004., 20:36   #1
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Unreal 2 problem
DObijam ovu poruku istu dobijem u i UT2K3
General protection fault!
History: UALAudioSubsystem::PlaySound <- APlayerController::execClientHearSound <- (U2PlayerNetTestController Save0.U2PlayerNetTestController3 @ Function U2.U2PlayerController.ClientHearSound : 00C8 line 206) <- UObject::ProcessEvent <- (U2PlayerNetTestController Save0.U2PlayerNetTestController3, Function U2.U2PlayerController.ClientHearSound) <- UObject::execClassContext <- (AssetsHelperGeneric None @ Function U2.AssetsHelperGeneric.HandleMovingOnTexture : 0028 line 85) <- UObject::execClassContext <- (U2PlayerTutorial Save0.U2PlayerTutorial0 @ Function U2.U2Pawn.PlayMovementSound : 00C6 line 712) <- UObject::ProcessEvent <- (U2PlayerTutorial Save0.U2PlayerTutorial0, Function U2AI.U2PawnBase.PlayMovementSound) <- SendNotification <- TickerTick <- (U2PlayerTutorial0[0]) <- ULegendMeshInstance::UpdateAnimation <- AActor::UpdateAnimation <- AActor::Tick <- (U2PlayerTutorial Save0.U2PlayerTutorial0) <- TickAllActors <- ULevel::Tick <- (NetMode=0) <- TickLevel <- UGameEngine::Tick <- UpdateWorld <- MainLoop
WTF??
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 29.02.2004., 20:48   #2
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
nesto sa zvukom ocito
Veky je offline   Reply With Quote
Staro 29.02.2004., 20:48   #3
IceFisherman
Magister Mundi sum!
IceFisherman's Avatar
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
Gledal sam po internetu i nekima se je to događalo zbog nekompatibilnog Rama , pa kad su ga zamjenili je normalno delalo.
Neki su to tak popravili da su najonvije drivere za grafulju skinuli a veliju da 100% pomaže
go into your bios : bump up the AGP Voltage from Auto to 1.7 or 1.8
Pa sad ti probaj
Sapphire radeon x1650PRO
2x512mb 433mhz Kingmax
AOC 17", LCD, LM760
Win XP PRO SP2 & SUSE 10.1
www.crazywarriors.com
Staro 29.02.2004., 20:52   #4
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Bilo i sa straim RAMom i starom pločom i starim driverima. fakat neznam koji je to bog
Grunf je moj idol!
Staro 29.02.2004., 22:09   #5
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
Ja sam par navarata imao par vrsta takvih poruka i sve su bile povezane sa OC. dakle kad sm spustil klok sve je delalo.
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 29.02.2004., 22:17   #6
komer
motocross
komer's Avatar
Lokacija: Kutina
Postovi: 2,438
evo ti moj ut2k3.ini pa probaj sa njim a probaj nove drivere od zvuka i grafulje ili reinstaliraj dx9
komer je offline   Reply With Quote
Staro 29.02.2004., 22:44   #7
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Istina, malo sam se igrao s FSBom bio je na 167 i nije delalo spustio sam na 160 pa polako dizao do 166 i dela stabilno.
Grunf je moj idol!
