In the lab...
Postovi: 929
Kopiranje u DOS-u?
Trebao bih jedan fajl sa diskete u DOS-u prekopirati u C:\Windows\system32, zanima me da li tko zna kako bi točno trebala glasiti naredba za kopiranje? Unaprijed zahvaljujem na odgovoru ![]()
** AMD FX-4300 @ 3.8 Ghz ** Asrock 990FX Deluxe 3 **16 GB G-Skill 1600Mhz ** Intel 545s 500 GB + 2xWD 1 TB ** MSI GTX 660 2GB ** DVD-RW LG H42N ** Corsair HX620 ** Logitech MX Master 2S ** Dell U2414 **SAMA Vulture |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,550
Loooooooooool, naredba glasi copy. Otprilike ovako copy a:\imefile.ext c:\windows\system32 P.S. Eh ti današnji klinci, dijete Windowsa ![]()
Expert from the shadow
Lokacija: Sibinj
Postovi: 696
COPY [/Y|-Y] [/A][/B] [d:][path]filename [/A][/B] [d:][path][filename] [/V] ili COPY [/Y|-Y] [/A][/B] [d:][path]filename+[d:][path]filename[...] [d:][path][filename] [/V] /Y - Causes COPY to replace existing files without providing a confirmation prompt. By default, if you specify an existing file as the destination file, COPY will provide a confirmation prompt. (In previous versions of DOS, existing files were simply overwritten.) /-Y - Displays a confirmation prompt before copying over existing files. /A - Used to copy ASCII files. Applies to the filename preceding it and to all following filenames. Files will be copied until an end-of-file mark is encountered in the file being copied. If an end-of-file mark is encountered in the file, the rest of the file is not copied. DOS will append an end-of-file mark at the end of the copied file. /B - Used to copy binary files. Applies to the filename preceding it and to all following filenames. Copied files will be read by size (according to the number of bytes indicated in the file`s directory listing). An end-of-file mark is not placed at the end of the copied file. /V - Checks after the copy to assure that a file was copied correctly. If the copy cannot be verified, the program will display an error message. Using this option will result in a slower copying process. |
#4 | |
aka Mali Mirko
Postovi: 3,138
2.selektiraš željeni fajl sa A: i odvučeš ga mišem u windows ekplorer di si otvorio C:\Windows\system32 i pustiš miša. ![]() ![]() :hoćuinternet: |
#6 | |
In the lab...
Postovi: 929
Ma znam i ja da je naredba copy, samo nisam bio siguran da li ide možda ime fajla u navodnike i ima li kakvih posebnih filozofija jer duuuuugo to nisam radio ![]()
Pink Floyd fan
Postovi: 5,550
aka Mali Mirko
Postovi: 3,138
od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
Ako imaš ntfs particiju, onda moraš dignut najprije ntfs dos driver... copy a:\file.dat c:\windows\system32\ ako ti ne radi AltGr+Q za kosu crtu onda drži lijevi Alt i utipkaj 092 na NumPadu
