Staro 02.10.2007., 02:08   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radeon Omega Drivers 3.8.413 (Cat 7.9.1)
Omega se vratio iz mrtvih
Kaj WoW radi ljudima...
What's New in Omega Drivers?
v3.8.413[*] Based on the Catalyst 7.9 Hotfix drivers.
[F] Fixed support for pixel perfect 1366x768 for TV LCD users. (1360x768 was also re-added)
[+] Added new resolutions to fill the 16:9 gap between 1366x768 and 1920x1080 (1600x900@60hz and 1776x1000@60hz)
[+] Added a new pixel perfect 4:3 resolution for 1080p LCDs (1440x1080@60hz) for those games/companies that offer no widescreen support. *cough*EA*cough*
[+] Removed Overscan from DVI port, this means no more black borders when using DVI->HDMI cables/adapters to connect to an LCD TV.
Known Issues:
1) Since Overscan will be removed from now on from the drivers, if you need to connect your PC to a regular TV that DOES need overscan in order to view it properly, you need to install the official 7.9 CCC Control Panel from ATI after my drivers so you have access to the new "scaling" feature and scale the overscan to fit your needs.
What's new for ATI Tray Tools?
1.3.6.1047
[F] Fixed localization for CrossFire dialog window.[*] Updated ini files handling procedures to be more compatible with Windows Vista.[*] Improved compatiblity with IE7 under Vista with UAC enabled???
http://www.omegadrivers.net/ati/win2k_xp.php
Staro 02.10.2007., 15:38   #2
Jelc
Super Moderators
Postovi: 17,485
Instalirao i isprobao.
(samo COD2 i Enemy Territory: Quake Wars)
COD2 ide ko gluha svinja, Enemy Territory: Quake Wars mi se sa službenima znao rušit-sad je ok.
Navečer budem probal i ostale igre.
Staro 02.10.2007., 16:39   #3
vorda22
fuj, alliance :S
Staro 02.10.2007., 18:45   #4
ChP3
Postovi: 432
Glupo pitanje ali ...jel podržavaju ovi Omegini driveri X1950GT, jer sam prije par minuta pokušavao bezuspješno staviti neku verziju Omega drivera.
ChP3 je offline   Reply With Quote
Staro 02.10.2007., 21:29   #5
Jelc
Super Moderators
Postovi: 17,485
Sa ovim zadnjim ne bi trebalo biti problema...
Staro 03.10.2007., 00:20   #6
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
pozdrav
ja sam bogme imao problema skinio sa gore navedenog linka instalirao i cijeli sistem se srušio(po...io sam)to mi je donijelo lijepog posla cca 2h pa sam imao poslijepodnevnu zabavu reinstalcije winsa.Komp se uredno podigne sa win. logom i nema slike na monitoru(probao 2-3 puta restart)ali ništa slike nema i nema kad se sistem podigne u pozadini čujem blop!!! ko da pecam somove sa bučkalom.Skidao sam sve po s....ku i sad sve OK.
Pogledaj grafičku(moj komp) u svezi prethodnog posta.
Staro 03.10.2007., 00:39   #7
Jelc
Super Moderators
Postovi: 17,485
Meni je sve prošlo normalno (X1900 AIW)
Obrisao stare drivere, restartao, raspakirao Omega drivere, pokrenuo instalaciju 7.9WDM i bez restarta na to lupio Omegu.
Staro 06.10.2007., 13:49   #8
CountZero
What does the scanner see
CountZero's Avatar
Lokacija: Sprawl
Postovi: 99
hvala bogu i novim omega driverima !
sad je to prava stvar ! jos kad taj prasac nebi rokao stalno WoW i cesce radio update... al nije lose ni ovako jer se vise onda veselimo !
_________________________________________
"Time moves in one direction, memory in another ..."
-William Gibson
CountZero je offline   Reply With Quote
