Staro 30.09.2007., 20:33   #1
vinja
vinja's Avatar
Postovi: 788
pomoc sa speedtouchom
pozdrav!
evo dobio sam konacno (nakon pustih obecanja o brzoj dostupnosti metroneta i amisa) Iskon Duo, a s njime i Thompson Speedtouch ST780.
Kako sam poprilicno njub sto se tice ADSL modema/routera, jel bi mi tko mogao reci jesu ove vrijednosti u granicama normale (i na sto trebam obratiti paznju):
Link Information
Uptime: 0 days, 5:58:00
Modulation: G.992.5 annex B
Bandwidth (Up/Down) [kbps/kbps]: 1.023 / 9.998
Data Transferred (Sent/Received) [GB/GB]: 1,79 / 5,16
Output Power (Up/Down) [dBm]: 12,0 / 17,5
Line Attenuation (Up/Down) [dB]: 8,0 / 12,0
SN Margin (Up/Down) [dB]: 14,5 / 18,5
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 4.160 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 276 / 20
HEC Errors (Up/Down): 2.836 / 6
Naime, veza mi svako malo "steka". Dugo mu treba da pocne ucitavati stranice, dobijem timeout pri skidanju maila itd...
Btw spojen sam UTP kabelom na uredjaj, a isti problem imaju i podstanari s kojima djelim vezu.
Pretpostavljam da je broj error seconds nekako prevelik?
Ima tko kakav prijedlog? (naravno zvat cu SZK,al volim znati sto se dogadja kad s njima razgovaram)
Hvala
vinja je offline   Reply With Quote
Staro 30.09.2007., 21:24   #2
Xan
networking wannabe guru
Xan's Avatar
Datum registracije: Sep 2002
Postovi: 1,001
hmm, Line Attenuation je odličan, a SN Margin dobar, tako da ne mislim da je do Iskona, tj. tvoje parice...
jesi ukucao DNS servere na svakom od računala?
Quotation from the Bhagavad Gita famously quoted by J. Robert Oppenheimer upon witnessing the detonation of the first atomic bomb.
Also quoted numerous times by overly melodramatic players of Unreal Tournament upon detonation of the Redeemer weapon.
"Now I have become death, the destroyer of worlds who has come to annihilate everyone."
Xan je offline   Reply With Quote
Staro 30.09.2007., 23:13   #3
vinja
vinja's Avatar
Postovi: 788
ne... pustim DHCP. Mislis da bi rucno unosenje pomoglo??
Staro 30.09.2007., 23:23   #4
Postovi: 23,534
Normalno da pomaže, zato ti je i sugerirano. Unesi Iskon - ove DNS - ove u router i na properties od mrežne na kompovima. Također na kompovima stavi fiksni IP pa ćeš vidit da ti je net brže dostupan. Jedina razlika kod tebe u odnosu na Sticky je da je tvoj Gateway: 192.168.1.254 (IP adresa ST780).
Staro 30.09.2007., 23:52   #5
vinja
vinja's Avatar
Postovi: 788
ne, adresa mu je 192.168.100.1
192.168.1.254 je od Amisovog Netgeara iirc...
podesio sam rucno DNS (prvi 192.168.100.1, zatim dva iskonova), no ipak ne vidim razliku...
na samom routeru pak ne mogu pristupiti System Configuration dijelu. Trazi mi dodatni login koji ne uspjeva, ni sa defaultnim "Administrator" accom...
Staro 02.10.2007., 16:35   #6
Zvone2772
interferometar
Zvone2772's Avatar
Postovi: 768
Local Area (ili kako već imaš nazvano)--->Properties--->TCP/IP--->Properties--->(General)Advanced--->Default Gateways--->Add--->192.168.100.1
Javi je li pomoglo.
Ista stvar je mučila i mene.
Probaj napraviti sljedeće:
Network Connections-->Local Area (ili kako već imaš nazvano)--->Properties--->TCP/IP--->Properties--->(General)Advanced--->Default Gateways--->Add--->192.168.100.1
Javi je li pomoglo.
Zvone2772 je offline   Reply With Quote
Staro 02.10.2007., 16:42   #7
vinja
vinja's Avatar
Postovi: 788
yup... vec sam prije to napravio kad sam dodavao Iskonove DNSove u postavke lan kartice...
nesto od tog je upalilo, uglavnom evo 2 dana radi k'o zmaj
RJESENO
