Staro 12.02.2004., 23:59   #1
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,317
ajmo ajmo novi Catalyst 4.2
...sve pise u naslovu ......
http://www.ati.com/support/drivers/w...eonwdm-xp.html
Fixed in this driver:
Running Celestia under Windows XP with an ATI RADEON™ 8500 series or RADEON™ 9100 series installed no longer results in a slow down of the performance
Enabling extended desktop mode with the display set to 1600x1200 and running Inventor 8 no longer results in display corruption when loading a sample
Performance losses noticed in Wolfenstein: Enemy Territory with the previous CATALYST™ display driver have been resolved in this release of CATALYST™
Logging on as an Administrator under Windows XP and doing a fast user switch to limited user no longer results in display corruption when playing a DVD using WinDVD version 4 or 5
User defined colour setting are now retained when exiting a 3D game or application
The ATI Control Panel no longer fails to launch when attempting to enter the Advanced options of the primary display adapter after disabling extended desktop support
The Cancel button found in the ATI 3D tab is now working properly when switching between a user defined profile and the default setting
Enabling the CRT as the primary display and turning the TV off in the Display page no longer results in a general protection fault under Windows ME
The Anisotropic Filtering custom setting is now retained under Windows XP with an ATI RADEON™ 7200 installed
The D3D panel now retains the user defined AA/AF setting under Windows XP when a RADEON™ 8500 series is installed and the main setting is set to High Quality
Launching the game Tron 2.0 under Windows XP no longer results in the game failing to respond after the game introduction is loaded
Launching the game Line of Sight: Vietnam and setting the graphics option to 800x600 16bpp no longer results in the game failing to respond when selecting a new game
Running the game Armed and Dangerous under Windows XP with an ATI RADEON™ 9200 series installed no longer results in the display image appearing corrupted when selecting Storm the Base mission in the game
The game Half-Life is now displayed properly under Windows XP when the game resolution is set to either 320x240 or 400x300
Playing the game Serious Sam 2 under Windows XP with an ATI RADEON&tdrade; 9500/9800 series installed no longer results in the game failing to run when the game option is set to OpenGL
Playing the game Unreal Tournament 2003 under Windows XP with an ATI RADEON™ 9600 series installed no longer results in texture corruption being displayed on the flag surfaces in the DM-Tokara Forest
Selecting the Optimum Quality setting in D3D control panel no longer results in a frozen frame when launching the game HALO
Setting the resolution in the game SpyHunter to 1280x1024 along with having the Use Recommended Settings slider set to balanced in the ATI 3D tab no longer results in some background images being missing while the game is loading
Setting the display option to 640x480 or 800x600 in the game Splinter Cell no longer results in the game menu flickering
Returning to the main menu in the game Counter-Strike no longer results in the game's refresh rate reverting back to 60Hz when resuming game play
Zadnje izmijenjeno od: joolka. 13.02.2004. u 00:29.
Staro 13.02.2004., 00:12   #2
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Zar vec?
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 13.02.2004., 00:20   #3
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
pa jebote, uranili su bar tjedan dana
http://www.ati.com/support/drivers/w...x=7&submit.y=3
Veky je offline   Reply With Quote
Staro 13.02.2004., 00:40   #4
vudu2
vudu2's Avatar
Lokacija: Sisak
Postovi: 1,058
A ja sam bio uvjeren da imam zadnje!
Imam 3.9 A sta ces, kada svako malo nešta ne radi.
vudu2 je offline   Reply With Quote
Staro 13.02.2004., 03:20   #5
Black Dragon
Black Dragon's Avatar
Lokacija: Agram
Postovi: 2,982
Znate vi onu, ako nešto radi ne diraj ... ja sam se vrnula na 03.10 i sve mi radei nema više one gluposti od VPU recover svakih 10 - 15 minuta, ili ako ga iskopčam da mi se desi freeeeeez kompa, sada sve dela bez greške ...
Staro 13.02.2004., 20:01   #6
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Originally posted by Black Dragon
ja sam se vrnula
Joj sunčica...a ja živio u zabludi da imam muškog kolegu na ATI forumu
Jel to ili si se urokao/la nečim egzotičnim...mislim...da se omakne prst na slovu pored-ali preko cijele tipkovnice
:burn:
Staro 13.02.2004., 20:01   #7
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Baš sam zvao Jelca da kak da on nezna, kad mali pobjegao ko zna gdje i loče , sunce mu njegovo
BTW, stavio sam nove i rade OK. Popravilo mi malo skor u marku, sredilo neke teksture u UT2k3 itd.... Zasad su odlični.
Staro 13.02.2004., 20:11   #8
Jelc
Super Moderators
Postovi: 17,485
Bilo je 20% posao-ostalo punica
A sa ovim drugim se nije za zajebavat....
Jedino kaj mi je žao je to da sam samo jedan dan bio gore solo, a to je premalo za kvalitetnu logistiku.
Treba ljubavnica ipak dogovoriti tko će vozit djecu na trening, skuhat za dva dana, namirit muža i smislit zakaj baš sad mora na put...drugi put budem pametniji...
Staro 13.02.2004., 20:15   #9
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Oho, vrnio se a? Ti čekaš omegicu, naravno....
Staro 13.02.2004., 20:18   #10
Jelc
Super Moderators
Postovi: 17,485
Je ...čekam Omegu.
Ali instaliram tu i tamo i ori-điđi...čisto da vidim kak to hoda, najvjerovatnije budem probal ove nove
Jesi probal i WDM???
A sad bu ko bog i novi MMC, ak već nije nisam ni gledao...
Staro 13.02.2004., 20:35   #11
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Jesam, sve zajedno ja to skinem. Znaš ono, posao, klik, save as
Ti ne hendlaš ICQ?
I da, novi MMC http://www.ati.com/support/drivers/w...x=9&submit.y=4
Staro 13.02.2004., 20:47   #12
Jelc
Super Moderators
Postovi: 17,485
Ti ne hendlaš ICQ?
Ma već neko vrijeme ne...postalo mi je malo naporno kad se u isto vrijeme jave 5-6 frendova/frendica pa moram tipkat ko blesav i još na kraju moram provjeravati kaj sam kom napisal
Staro 14.02.2004., 00:06   #13
Black Dragon
Lokacija: Agram
Postovi: 2,982
:burn:
U 02:20 ujutro i čaša toplog mlijeka sa otopljenih deci ruma čine čuda, s vremena na vrijeme vidim i Elvisa kako mi maše a ne da fulam pola tastature od N do A E i BTW ukoliko vam se jakoooo često javlja VPU recover ili vam se desk pukne u 4 bitnu boju, onda Vam je napajanje za Q. Treba vam još Watića u kompu, provjereno ... VPU recover čest gost + 4 bitna boja sa 8500/9100/9500/9700 = napajanje vam je preslabo.
