Staro 05.08.2007., 23:53   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Vista x64 i T-com ADSL
Kojim uredjajima je moguce spojiti Vistu x64 na T-com/Iskon ADSL?
Ako su to kao i kod x86 viste (oni routeri Siemens C-010-I i Elcon 2253 EU), jel' moguce njih pokrenuti pod vistom x64. Jel' moguce pokrenuti LAN sa ASUS MB pod x64? Jel' moguce spojiti LAN i te mrezne modeme?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 06.08.2007., 00:12   #2
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Pretpostavljam da možeš normalno spojiti sve ethernet uređaje..usb sumnjam..znaš ono Vista+driveri=problemi
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Brown Acid je offline   Reply With Quote
Staro 06.08.2007., 00:19   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Nista od ponudjenih USB uredjaja koliko ja znam defintivno ne radi ni na 32bitnoj visti. Znam da na njoj rade ti neki routeri modemi, ali pitam za Vistu x64...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 06.08.2007., 02:33   #4
SPLiFF
SPLiFF's Avatar
Postovi: 2,078
ne vidim razlog zasto bilo koji ethernet modem/router ne bi radio na bilo kojem operativnom sustavu?
Staro 06.08.2007., 08:57   #5
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Svaki router koji je u routing modu i ima pravilno podešen PPPoE protokol može routati bilo koji komp neovisno o OSu koji je na njemu...
win 3.11 ili Vista, Linux, Unix ili FreBSD svjedno...
Samo trebaš pravilno znati iskonfigurirati mrežu između kompda i routera, ako se ne kužiš puno u to najbolje ti je ostavit DHCP u routeru upaljen i u kompu isto tako sve ostavit na automatici...
Have a nice day...
Staro 06.08.2007., 10:19   #6
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Moze li se kojim od ova 3 uredjaja spojit na t-com adsl pod vistom x64:
(znam da se teoretski moze, pitam one koji su vec spojili - i u praksi )
1. Zyxel ADSL2+ P-660RU EE
2. Ericsson ADSL modem HM220dp (ethernet + USB)
3. Elcon, kakvog prodaje mdodig
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 06.08.2007. u 13:45.
Staro 06.08.2007., 13:55   #7
SPLiFF
SPLiFF's Avatar
Postovi: 2,078
omg
ne mozes optickim kablom, niti telepatskom vezom. Ethernet (mreznim) kabelom mozes.
Staro 06.08.2007., 14:44   #8
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Spliff, jesi li ti spojio?
Mislim jasno mi je to sto kazes. Cuo sam, kao i vecina, da to radi, ali umjesto sarkasticnih primejdbi imao bih puno vise koristi od savjeta.
Recimo;
Vidim da ti imas vistu x64. Jesi li spojio t-com adsl? Kojom lan karticom? Kojim mreznim modemom? To bih volio znati.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 06.08.2007. u 15:19.
Staro 07.08.2007., 03:16   #9
SPLiFF
SPLiFF's Avatar
Postovi: 2,078
ajde kad si takav pesimist A i dobro si skulirao moje provokacije
Imam t-com adsl, kasda modem u bridge modu (znaci ne radi kao ruter) spojen na Linksys BEFSR41 router spojen na integriranu mreznu na kompu i laptopu
Staro 08.08.2007., 15:13   #10
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Ja imam ovo;
1. DESKTOP: Vista x64 Ultimate desktop sa Asusovom maticnom koja ima 2 LAN ulaza
2. LAPTOP: Xindows XP SP2 Home 32bit sa klasicnim LANom, koji zbog drugih mreza mora imati fiksni IP XXX.XX.XX.XX5 (Desktop mi sada ima IP XXX.XX.XX.XX6 i fino se vide u mrezi iako je mreza u Visti "Unidentified".
3. MODEM: Siemens C-010-I mrezni modem
4. Iskon ADSL, ali to je kao T-com...njihovo je sve.
E sad evo sto ja hocu.
1. Imati pristup na T-com ADSL preko spomenutog Siemens mreznog modema na Visti x64.
2. Umreziti laptop (XP Home 32bit) sa desktopom, s tim da laptop moze na na Internet preko desktopa (ne wireless nego obicnim LANom) i mora ostati fiksna IP adresa.
Moze li se? Zna li tko kako?
Pomoc molim...
BTW Vista Ultimate x64 je killer sad kad sam nabavio kompatibilni hardver. Jednom kad se slozi ide ko zmaj. Jako brzo i jako stabilno. Narocito 64bitni soft. Boota se 2x brze od 32bit XPa.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 08.08.2007. u 15:37.
Staro 08.08.2007., 21:44   #11
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Dok tu cekam vas, kakti grde hakere, slozio sam sve sam.
I radi. I to dobro. Ave Vista 64bit, znam zasto te ne vole, ali nisu u pravu...
Radi savrseno uz malo strpljenja i istazivanja.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 08.08.2007., 22:01   #12
yedwy
yedwy's Avatar
Postovi: 6,956
Kao prvo - vjerovao ili ne ali ljudi na ovom forumu imaju i drugih poslova u životu nego odgovarati tebi na trivijalna pitanja...
Kao drugo - odma sam ti rekao da nema problema s bilo čime što radi u router modu, a što se bridging moda tiče - to ovisi o tome dali router/modem treba drivere ili netreba, konkretno siemens NE treba a oni koji ih možda trebaju - pitanje je dali isti postoje za x64 Vistu, samo to i ništa više...
Kao treće - melješ gluposti sigurno se ne diže 2x brže od 32 bitnih XPa prema tome skuliraj se malo s tim Vista oduševljenjem, makar uostalom - brzo će te proć kad te malo BSODovi pouče zašto ista ta Vista i nije baš tako bajna kao što se čini na prvi pogled...
Istina ako koristiš samo benchmarke i IE7 vjerojatno nećeš imati previše problema...
Kao četvrto i zadnje - kad si ti tako pametan istraživač i pametniji si očito od svih nas onda kaj uopće postaš pitanja, pa ti bi nas trebao sve tu instruirati, jesi razmišljao da naplaćuješ svaki svoj post - recimo 10kn po postu ili sl...
Have a nice day...
Staro 08.08.2007., 22:49   #13
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Yedwy, sorry ali ovo ti je malo nepromisljeno, da ne budem izravniji.
Cemu to? Cemu takvo podcjenjivanje? Cak da je i opravdano bilo bi primitivno.
Sigurno je u pitanju isfrustriranost neuspjelim pokusajem instalacije. I ja sam bio razocaran kad mi prvi put nije upalilo. Za BSOD uvijek postoji razlog i rjesenje. Samo se mora malo istrazivati i imati strpljenja i tolerancije.
No dobro...
"Grdi hakeri" je bila sala. Cini mi se; vrlo ocita za prosjecnu osobu. Ako je netko drugacije shvatio; moja iskrena isprika.
Pitao sam za podesavnja mreze, zato jer cijenim savjete gotovo svih ljudi ovdje, a sam sam se prvi put susreo s Vistom, i 64bitnim OSom generalno, prije par dana i nisam imao pojma o tome.
Napisao sam mali osvrt na instalaciju i prve dane koristenja Viste x64, na "Windows Vista Ultimate - moj review", ako nekoga zanima detaljnije.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 09.08.2007. u 03:12.
Staro 09.08.2007., 09:17   #14
yedwy
yedwy's Avatar
Postovi: 6,956
Autor estugarda Pregled postova
Budi izravniji... Baš me zanima...
No dobro...
Nemaš pojma o čemu govoriš btw ja znam razlog BSODanja ako nisi skužio problem je u tome što nemogu ništa u svezi toga poduzeti a to je zato jer je Vista zadnje smeće što se dorade koda tiče...
Možda sam ja onda teški idiot ali ja uostinu ve vidim tu nikakav humor...
I nakon što si cvilio po pola foruma da ti neko veli dal taj modem/router radi sa x64 Vistom i dal je probao sad si odjednom postao teški ekspert? Cooool...
I ja bi htio bit takav kad budem veliki...
Have a nice day...
Staro 19.09.2007., 21:33   #15
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Drugi problem
Prije svega; da se ne bojite vise ovih postova gore, mr. yedwy i moja malenkost, davno smo rascistili sitne nesuglasnosti.
Ali imam drugi problem...
Na Visti x64, s kojom sam i dalje prilicno zadovoljan, instaliran mi je iskon ADSL preko starog Siemens C-010-I mreznog modema. Internet je od pocetka radio iako je "Network and Sharing Center" redovito pokazivao "Unidentified Network" i "Limited Connectivity" za "mreznu" vezu modema i racunala(mrezne kartice). S obzirom na to da sam se normalno mogao spajati, to me nije previse diralo. Medjutim, nedavno je pocela pucati veza. Opera i IE32/64 nisu prepoznavali Internet vezu. "Network and Sharing Center" bi pokazivao da "Broadband Connection" radi bez greske i vidjelo bi se da ide D/U promet. Interesantno je da utorrent i dalje normalno skida. Ako bi se diskonektirao i opet spojio (samo dialup) - opet ista stvar. Ako bi resetirao mreznu vezu modema i LAN kartice - opet ista stvar. Samo ponekad proradi samo od sebe, a inace tek nakon restarta.
Sto bi to moglo biti?
Modem?
LAN?
Driveri mrezne kartice su friski. Inace imam sve updateove za vistu x64.
Kako to rjesiti? Pocelo me opako zivcirati.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 20.09.2007., 08:48   #16
yedwy
yedwy's Avatar
Postovi: 6,956
Jesi ugasio onaj IPv6 u servicima i opcijama za mrežu? On ti je zaslužan za ono limited connectivity...
Inače u Network Managment Centeru u opcijama veze ugasi sve osim TCP/IP v4 i Link-Layer Topology Discovery Mapper I/O driver pa probaj tako...
Have a nice day...
Staro 20.09.2007., 09:14   #17
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
U opcijama sam vec ugasio. To nista nije popravilo.
Ali u servicima ne!? Kako to mislis u servicima?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 20.09.2007., 09:17   #18
yedwy
yedwy's Avatar
Postovi: 6,956
Imaš jedan IPv6 service... Zoe se IP Helper to isto umlatiš...
Jesi probao sve osim TCP/IPa ugasit? Naravno moraš restartati vezu da bi to postale aktivne postavke...
Have a nice day...
Staro 20.09.2007., 18:06   #19
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Jesam. Ugasio. Disable. Enable. Restart. Nista novo. I dalje je unindentified network/limited connectivity.
Nije jos pukla veza Interneta, pa ne mogu reci ima li tu promjene.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 21.09.2007., 15:59   #20
yedwy
yedwy's Avatar
Postovi: 6,956
Čudno meni je sve odma proradilo bilo kad sam zatukao IPv6 bez problema, da ti nije nešto sprčkano sa adresama ili postavkama mrežne? Probaj je removati u Device Manageru i onda je natrag instalirati...
Have a nice day...
