Staro 12.06.2007., 00:02   #1
sick_boy
sick_boy's Avatar
Postovi: 680
Gigabyte 945P-S3 pokazuje 3400MB umjesto 4GB
Dakle, s obzirom da je memorija skoro džaba, kupio sam i stavio 4x1GB, DDR2-667 (2xGoodRAM, 2xKingmax) memorije. No, ploča iz naslova pokazuje 3400MB, kao i Windowsi (task manager) . However, CPU-Z vidi 4GB i pokaže svaki modul ispravno.
Stavio sam zadnji BIOS, probao mijenjati mjesta modulima, ali ništa ne pomaže. Čini se kao da je ploča ograničena, iako prema specifikacijama piše da podržava 4GB (kao i specifikacija Intel 945p chipseta). Doduše, na Gigabyte-ovim stranicama piše:
Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount.
ali pretpostavljam da se to odnosi na onih 640KB osnovne DOS memorije.
Inače, sve radi u dual channel-u, i svaka 2GB ako ih ubodem zasebno, prepozna full (dakle, svih 2GB).
Ima li netko ideju zašto je tomu tako?
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 12.06.2007., 00:31   #2
qbone
qbone's Avatar
Postovi: 146
vjerojatno zato jer 32-bitni Windowsi prepoznaju najviše cca 3,5 GB RAM, da bi iskoristio 4 GB trebaju ti 64-bitni Windowsi...
qbone je offline   Reply With Quote
Staro 12.06.2007., 00:39   #3
SPLiFF
SPLiFF's Avatar
Postovi: 2,076
pise u "Moj Komp" da ima Vistu 64 bitnu...
ima neka fora u BIOS-u, nesto memory allocation update, tako nesto? Ja to kod sebe nisam nasao, al procitao sam ovdje o tome pa potrazi.
Mozes probati i onaj HPET staviti na 64-bit. Takodjer u BIOSu potrazi, i stisni onaj ctrl+F1 kad udjes u bios.
Staro 12.06.2007., 10:00   #4
sick_boy
sick_boy's Avatar
Postovi: 680
Da, 64-bitna je Vista, ali problem nije u OS-u, jer i BIOS pokazuje 3400MB (ustvari, čini mi se nešto manje - 3372 ili nekako slično).
Anyway, igraću se još malo sa postavkama. Ionako sam kupio tu memu jer je prejeftina - mislim da preko 2GB baš i nema smisla (osobito kad se kod kuće ne bavim ničim jako zahtjevnim ni bitnim).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 12.06.2007., 11:07   #5
domy_os
domy_os's Avatar
Postovi: 18,847
Taj chipset podržava max 4 GB tako da ćeš teško dobiti puni kapacitet jer jedan dio uvijek otpada na adresiranje uređaja (potraži detaljnije na forumu), ali pokušaj se igrati s postavkama u BIOS-u, možda pomogne.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 13.06.2007., 00:36   #6
sick_boy
sick_boy's Avatar
Postovi: 680
Ma znam, ali preko 600MB!!!!
BTW, sad sam stavio 2x1GB i 2x512MB (izvadio iz mediacentera). Pokazuje 3072 MB, dakle upravo onoliko koliko i treba. Sve mi se čini da ploča ima neko glupo ograničenje...
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 13.06.2007., 14:57   #7
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Mislim da je ovo što je Domy rekao. Dio meme otpada na adresiranje, tj. imaš "Memory hole". Probaj naći u BIOS-u opciju za taj Memory hole i probaj to isključiti pa vidjeti što ćeš onda dobiti.
Staro 13.06.2007., 17:13   #8
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,819
il memory remaping,uključi u biosu....meni na visti pokaziva 3.33gb 32bitna a 64 bitna 3.85gb....nekaj ti u biosu nije upaljeno
