Staro 30.05.2007., 01:30   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
WinRAR 3.70
Glantz novi
Latest Changes:
Numerous Windows Vista compatibility changes
Added support for ISO 13346 (UDF) file format. This format is frequently used in ISO images of DVD disks
Added Unicode support for ISO 9660 files, so WinRAR should handle non-English file names in .iso files better
Design changes in window displaying archiving and extraction progress
GUI self-extracting modules support following command line switches
GUI self-extracting modules do not pass the entire command line to setup program like they did in previous versions
New switch -sc[objects] allowing to select character sets for archive comments and list files
New "Save archive copy as..." command in "File" menu
"Word wrap" command added to "View" menu of WinRAR internal viewer, so you can change the wrapping mode of already opened viewer window
Buttons "Up" and "Down" added to "Organize profiles" dialog
Operation progress is displayed when adding the recovery record
If WinRAR is minimized to tray and mouse is over its icon, WinRAR diplays a message about the current operation progress
Console RAR displays "Calculating the control sum" message when calculating CRC32 control sum for newly created RAR volume
Archives history list in "File" menu allows Unicode names, providing more reliable support for non-English archive names
Stack overflow vulnerability has been corrected in password processing module of console RAR and UnRAR. GUI WinRAR is not affected
Nova verzija postoji i za Mac OS X, Linux, ili FreeBSD.
http://fileforum.betanews.com/detail/WinRAR/930118351/1
Staro 30.05.2007., 01:46   #2
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Je dobar, ali nije besplatan
A besplatna konkurencija ima dobre proizvode...
Ali da je najjači (omjer brzina/kompresija) - vjerojatno je.
Staro 30.05.2007., 14:58   #3
domy_os
domy_os's Avatar
Postovi: 19,060
Imaju i nove ikonice, stare su mi bile nekako ljepše, ali to je valjda stvar navike...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 31.05.2007., 01:20   #4
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
konacno su promijenili onaj progress window, svidja mi se
btw. ako vam se ne svidjaju defaultne ikone WinRAR vec neko vrijeme podrzava theme, ima ih na sluzbenoj stranici za skinuti
Zadnje izmijenjeno od: DeadMan+. 01.06.2007. u 11:10.
DeadMan+ je offline   Reply With Quote
Staro 31.05.2007., 12:43   #5
jollyb
4K FTW
jollyb's Avatar
Lokacija: Minken
Postovi: 1,046
winrar je definitivno najbolji
uz njega sam već par godina. isprobao sam powersrchiver, zipgenius, 7zip, winzip... ali ništa nije do winrara
7zip prolazi ako netko nema potrebe zipati u rar iliti rarati
jollyb je offline   Reply With Quote
Staro 27.10.2007., 02:20   #6
Dacho
Dacho's Avatar
Lokacija: Sarajevo
Postovi: 1
nedavno sam skinuo putem torrenta neke filmove u .rar formatu i kada sam htjeo da ih raspakiram trazi mi password. Ima li sanse da nekako zaobidjem taj password kako ne bih morao ponovo skidati iste stvari.
Pozdrav Dacho
Dacho je offline   Reply With Quote
Staro 27.10.2007., 03:01   #7
SPLiFF
SPLiFF's Avatar
Postovi: 2,141
Nema sanse, shift+del
Staro 27.10.2007., 03:03   #8
Joke
N00B
Joke's Avatar
Postovi: 3,886
Dacho ja mislim da tu http://forum.pcekspert.com/faq.php imaš brdo passworda za takve stvari!
Staro 27.10.2007., 04:01   #9
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Dobro nije bas pitanje nesto s pravilima ili se varam ali mores to probiti ako znas duzinu,vrstu slova/brojika ali ako ne mores se slikati ili ga ostaviti na samo 1000g dok to ne hakne .
' alt='' border=0>
Vejita je offline   Reply With Quote
Staro 28.10.2007., 02:26   #10
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
u masu slučajeva ti je pass ime samog file-a
ako se file zove : svjetska kuhinja, pass je u puno slučajeva ili svjetska, ili kuhinja,
akome kužiš.
