80286
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Xubuntu 7.04 i rezolucije...
Ovako, vec me pocelo zivcirat ovo, skinuo sam Xubuntu 7.04 i instalirao, prvo nakon toga sam nabacio drivere za grafu (nvidia-glx). u xorg.conf-u sam promijenio driver iz 'nv' u 'nvidia' i zatim pokrenuo dpkg-reconfigure xserver-xorg, i sve fino sredim i namjestim koje da rezolucije koristi. Zatim lupim Ctrl+Alt+Backspace i hocu promjenit rezu kad na listi opet samo default i stalno tako. Neznam vise sto da radim ![]()
Kernel panic
Postovi: 522
Provjeri jesu li rezolucije navedene u /etc/X11/xorg.conf fajlu: Section "Screen" Identifier "Default Screen" Device "nVidia Corporation NV18 [GeForce4 MX 440 AGP 8x]" Monitor "SyncMaster" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 4 Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" /! CUT !\
Keyboard error or no keyboard present Press F1 to continue, DEL to enter SETUP |
Lokacija: Zabok
Postovi: 3,419
@rams koji monitor imaš? Najvjerojatnije te zezaju modlajnovi. http://ubuntuforums.org/showthread.php?t=83973 Izgeneriraš ih ručno i nalijepiš u /etc/X11/xorg.conf kam treba. |
..dno
Lokacija: Crikvenica
Postovi: 1,973
Imao sam iste probleme s X850XT, no s MX440, i s 9200SE nije bilo problema.. I mene interesira rjesenje..
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.” |
80286
Postovi: 1,724
Evo dio mog xorg.conf-a Section "Device" Identifier "nVidia Corporation NV17 [GeForce4 MX 440]" Driver "nvidia" BusID "PCI:1:0:0" Option "UseFBDev" "true" EndSection Section "Monitor" Identifier "CM1772FS" Option "DPMS" HorizSync 30-72 VertRefresh 50-135 EndSection Section "Screen" Identifier "Default Screen" Device "nVidia Corporation NV17 [GeForce4 MX 440]" Monitor "CM1772FS" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 4 Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 8 Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 15 Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 16 Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 24 Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480" EndSubSection EndSectionon sve su linije dobro napisane, barem ja tako mislim, ako nesto nevalja recite, nvidia driver je instaliran, no kad odem u Display Preferences na popisu reyolucija stoji samo Default i nista vise...
80286
Postovi: 1,724
Lokacija: Zabok
Postovi: 3,419
Nisi izgenerirao modlajnove. Ideš na online modeline generator: http://www.sh.nu/nvidia/gtf.php Upišeš rezoluciju i refresh rate, npr 1280 x 960, 85Hz Dobiješ ovo: # 1280x960 @ 85.00 Hz (GTF) hsync: 85.68 kHz; pclk: 149.43 MHz Modeline "1280x960_85.00" 149.43 1280 1376 1512 1744 960 961 964 1008 -HSync +Vsync Pejstaš to unutar Monitor sekcije u xorg.conf Ako koristiš NVidia driver onda unutar Monitor sekcije pejstaš još i ovo: Option "DDC" "False" Time kažeš da X server koristi isključivo tvoj modeline (ovaj gore koji si napejstao), jer nvidia driver ima problema s prepoznavanjem/korištenjem modlajnova pa ga tako forsiraš. |
#9 | |
80286
Postovi: 1,724
Evo sad to ovako izgleda: Citiraj:
Zadnje izmijenjeno od: rams. 01.04.2009. u 20:48. |
Lokacija: Zabok
Postovi: 3,419
, to je najmanji problem. XFCE je malo siromašan takvim alatima, al je zato jako brz .Al što uopće hoćeš napraviti? Sve možeš ručno prek xorg.conf-a i to pali na bilo kojem desktop environmentu. Ak si instalirao nvidia drivere imaš njihov utility u kojem možeš podesiti neke opcije vezane za drivere. Pokrećeš ga u konzoli sa: sudo nvidia-settings |
#14 | |
Kernel panic
Postovi: 522
#15 | |
Lokacija: Zabok
Postovi: 3,419
Secton "Screen", SubSection "Display", treba ti pisati pod svim Modovima: Depth 1 Modes "1680x1050" EndSubSection Trebaš imati izgeneriran modlajn za tu rezoluciju: Citiraj:
