Staro 01.04.2007., 07:08   #1
munst0r
munst0r's Avatar
Lokacija: Bjelovar/Zagreb
Postovi: 357
Siemens C-010-I kao router
Godinama vec koristim ovaj modem samo kao modem. No, sada dobih potrebu spojiti jos jedan komp i pokusao sam to malo cudo prebaciti u route mode.
Vec se 2 sata za***avam s time i nije mi jasno zasto me za***ava nesto sto svima radi bez problema...
Dakle, napravio sam sve po svim mogucim uputama koje sam uspio naci (clanak na PCE, Carnetov PDF te Buddhina uputstva). No, ovo nikako ne zeli raditi... Jednostavno se ne spaja i ne dodijeljuje WAN IP...
Evo kopi pejst loga... mozda netko nesto uoci...
01/01/1970 00:00:00> Ethernet Device 0 Detected
01/01/1970 00:00:00> ATM: Detected
01/01/1970 00:00:00> ATM: Setting up vcc1, VPI=0, VCI=33
01/01/1970 00:00:00> Initialized Dynamic NAPT.
01/01/1970 00:00:00> CfgMgr: 'Shtm.dlz' module loaded.
01/01/1970 00:00:06> CfgMgr: 'ShtmMib.dlz' module loading failed.
01/01/1970 00:00:06> CfgMgr: 'Washer.dlz' module loaded.
01/01/1970 00:00:06> CfgMgr: 'Apimage.dlz' module loaded.
01/01/1970 00:00:06> CfgMgr: 'Prism.dlz' module loaded.
01/01/1970 00:00:17> ATM Connected
01/01/1970 00:00:17> ATM layer is up, cell delineation achieved
01/01/1970 00:00:17> ADSL connected
01/01/1970 00:00:17> Modulation: G.dmt
01/01/1970 00:00:17> Annex Mode: ANNEX_B
01/01/1970 00:00:17> Max Tx Power: -38dBm/Hz
01/01/1970 00:00:17> CO Vendor: UNUSED_VENDOR_0
01/01/1970 00:00:17> d/s SNR: 127.9dB, u/s SNR: 26.0dB
01/01/1970 00:00:17> d/s Attenuation: 17.4dB, u/s Attenuation: 7.5dB
01/01/1970 00:00:17> d/s Data Rate: 1024kbps, u/s Data Rate: 192kbps
01/01/1970 00:00:17> d/s Latency: FAST, u/s Latency: FAST
01/01/1970 00:00:17> d/s total bit capacity: 2197bits, used: 328bits
01/01/1970 00:00:17> u/s total bit capacity: 56bits, used: 56bits
01/01/1970 00:00:17> ATM Tx Error Count: 0, Rx Error Count: 0
01/01/1970 00:00:17> PPP1 PPPoE PADI Sent
te Dignostic Test:
Checking LAN Connection
Testing Ethernet LAN connection PASS HELP
Checking ADSL Connection
Testing ADSL Synchronization PASS HELP
Checking Circuit 1 for Network Connection
Test ATM OAM Segment Loop Back PASS HELP
Test ATM OAM End-to-End Loop Back FAIL HELP
Test Ethernet connect to ATM PASS HELP
Test PPPoPvc 1 PPPOE connection PASS HELP
Test PPPoPvc 1 PPP layer connection FAIL HELP
Test PPPoPvc 1 IP connect to PPP SKIPPED HELP
Testing Internet Connection
Ping primary DNS SKIPPED HELP
Query DNS for www.conexant.com SKIPPED HELP
Ping www.conexant.com SKIPPED HELP
munst0r je offline   Reply With Quote
Staro 01.04.2007., 13:21   #2
daigu
Lokacija: Crikvenica
Postovi: 143
Kada ga iskonfiguriraš, jednostavno ga ugasi, pričekaj malo i ponovno upali. To je znalo funkcionirati. Inače je jedan od najboljih uređaja u povijesti T-com ADSL-a, ali se nekada zna izblesirati, pogotovo prilikom konfiguracije.
daigu je offline   Reply With Quote
Staro 01.04.2007., 13:53   #3
Foxman
localhost
Foxman's Avatar
Postovi: 711
moj nije htio profunkcionirati isto apsolutno nikako pa sam si nabavio ruter jer vise nisam imao snage za za***anciju s njim također sam isprobao sve a modem ne bi dao ni za što koliko mi je dobar...
Zapravo ja sam svoj natjerao da radi kao ruter ali nije bas slusao najbolje jer na jednom racunalu je sve radilo kako treba a na drugom je neke stranice htio otvoriti neke nije, i slicno.... Ne sjecam se sad tocno koje testove mi nije prosao ali ima negdje na forumu
Zadnje izmijenjeno od: Foxman. 01.04.2007. u 14:41.
Foxman je offline   Reply With Quote
Staro 01.04.2007., 16:58   #4
munst0r
munst0r's Avatar
Postovi: 357
Zanimljivo...
Ostavio sam ga onako i otisao spavati... I tokom "noci" se spojio... Trebale su mu samo 54 minute...
Jos cu malo prckati po njemu... ali nekako mi se ne da cekati sat vremena svaki put...
Evo nastavak loga...
01/01/1970 00:54:40> PPP1 PPPoE PADR Sent, Service-Name:HTnet AC-Name:HTdsl Tag:0104 ValueE 06 FC 78 38 CB 6E 6D 9B E4 C3 7A A8 64 B1 7E
01/01/1970 00:54:40> PPP1 PPPoE PADR Sent, Service-Name:HTnet AC-Name:HTdsl Tag:0104 Value:10 27 1D C9 13 2B 95 89 2F 48 43 36 C9 44 4B 15
01/01/1970 00:54:40> PPP1 PPPoE PADS Received Service-Name:HTnet AC-Name:HTdsl Tag:0104 Value:10 27 1D C9 13 2B 95 89 2F 48 43 36 C9 44 4B
01/01/1970 00:54:40> PPP1 PPPoE Session is established.
01/01/1970 00:54:40> PPP1 PAP Authentication success
01/01/1970 00:54:41> PPP1: PPP IP address is 83.131.30.xxx
01/01/1970 00:54:41> PPP1: PPP Gateway IP address is 172.29.252.5
01/01/1970 00:54:41> PPP1: DNS Primary IP address is 195.29.150.3
01/01/1970 00:54:41> PPP1: DNS Secondary IP address is 195.29.150.4
01/01/1970 00:54:41> NAT/NAPT Session Start: interface ppp1, WAN IP is 83.131.30.251
01/01/1970 00:54:41> No Static Session Information is defined.
01/01/1970 00:54:41> DNS: Add IP address 195.29.150.3 (Auto discovered)
01/01/1970 00:54:41> DNS: Add IP address 195.29.150.4 (Auto discovered)
01/01/1970 00:54:41> PPP1 Session is up.
04/01/2007 06:55:17> Received time from Time Server 128.138.140.44
Staro 19.05.2007., 13:12   #5
jest
Lokacija: tu
Postovi: 79
ej.. imam isti problem kao i ti... da li bi mogao postati kako si ti konfigurirao svoj modem..
ovo je moj log
01/01/1970 00:00:00> ATM: Setting up vcc0, VPI=0, VCI=33
01/01/1970 00:00:18> ATM Connected
01/01/1970 00:00:18> ATM layer is up, cell delineation achieved
01/01/1970 00:00:18> ADSL connected
01/01/1970 00:00:18> Modulation: G.dmt
01/01/1970 00:00:18> Annex Mode: ANNEX_B
01/01/1970 00:00:18> Max Tx Power: -38dBm/Hz
01/01/1970 00:00:18> CO Vendor: UNUSED_VENDOR_0
01/01/1970 00:00:18> d/s SNR: 26.8dB, u/s SNR: 23.0dB
01/01/1970 00:00:18> d/s Attenuation: 43.1dB, u/s Attenuation: 23.0dB
01/01/1970 00:00:18> d/s Data Rate: 1024kbps, u/s Data Rate: 256kbps
01/01/1970 00:00:18> d/s Latency: FAST, u/s Latency: FAST
01/01/1970 00:00:18> d/s total bit capacity: 1292bits, used: 392bits
01/01/1970 00:00:18> u/s total bit capacity: 72bits, used: 72bits
01/01/1970 00:00:18> ATM Tx Error Count: 0, Rx Error Count: 0
01/01/1970 00:00:18> PPP1 PPPoE PADI Sent
vidim da imam nesto viska
jest je offline   Reply With Quote
Staro 19.05.2007., 14:38   #6
munst0r
munst0r's Avatar
Postovi: 357
Autor jest Pregled postova
Napravio sam sve prema ovim uputstvima...
Prvi put mu je trebalo sat vremena na se spoji, ali nakon toga sve radi super... sada se (nakon nestanka struje) spaja u roku jedne minute...
Staro 19.05.2007., 15:20   #7
jest
Lokacija: tu
Postovi: 79
kad radim po tim uputama dobijem ovo
a kad radim po carnetovim dobijem ovo
i jos nesto... kad odes na 192.168.1.1 u gornjem lijevom kutu ti se pokaze
ili
Staro 20.05.2007., 23:17   #8
MarioArt
Lokacija: Betfair
Postovi: 2
ja ga isto imam...radio ko sat nekoliko mjeseci, a onda je počeo fantazirati... u biti kad je sam radio reconnect sve je islo kako treba...problemi su nastajali kad bi se prisilno prekinio dsl.....da skratim...bez ikakvog pravila radio malo kako treba, pa malo nikako--- riješenje - canyon router i piči dalje....sad je optima ona koja pravi probleme, ali i za nju ima lijeka
MarioArt je offline   Reply With Quote
