Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Driver Cleaner 2.5
Evo-izašla je nova verzija. Novo je: Improved: - ATI cleaning file - ATI MMC cleaning file - nVidia cleaning file - Creative Audio cleaning file - Added questions in the FAQ - Program Code - Complete new installer - Better backup routines Added: - Language Support (English, Dutch, German, Italian, Spanish, French) more will follow - Detection of the Program Files Directory - Realtek AC'97 cleaning file beta - nVidia Special cleaning file beta (Check readme for info) Also some new addition in Cab Cleaner: Added: - Cab File detection (Only files that exist will be in the drop down box) Read the Readme. IMPORTANT: uninstall the older version first before you install this version. For uninstalling nVidia drivers i recommend putting the backup functions on. If something goes wrong you can restore it. Also if you get an error with installing new drivers, please send me the directories in the backup folder, so i can check and locate the problem than. Or mail me if you want to ask more how to send it, but don't use the restore before you sended it. It is for nVidia, ATI, Creative and Turtle Beach. It will remove anything that is left by the drivers after uninstall. Možete ga skinuti tu: http://www.driverheaven.net/cleaner/ A primjedbe, pohvale ili pljuvanje po dotičnom možete tu: http://www.driverheaven.net/showthre...threadid=29413 |
