Staro 20.02.2007., 00:07   #1
vanja81
Postovi: 8
Problem sa Tagan napajanjem
ovako. uzeo sam si u americi napajanje tagan tg530-u15 http://www.dansdata.com/tagans.htm. e sad, doslo je do problema. slijedio sam upute koje kazu:
1. Ensure that the main power on/off switch i off. If you are replacing an old PSU, unplug the power cord from the PSU.
2. Open the PC case chassis and mount the Tagan onto the matching chassis holes using the correct four screws which are included with the PSU as part of the accessory kit.
3. Connect the ATX 20-pin and 4-pin (WARNING: Please ensure you plug in the 4 pin marked p4 and not +P4 as the +P4 is only to be used to clip onto the 4 pin P4 to transform from 4 to 8 pin as required on some mainboards) or the ATX 24-pin and 4/8-pin DC output connectors to the mainboard by carefully following the mainboard's instruction manual.
Note: The shape of the DC connector ---with its marked nose--- helps to prevent incorrect insertion. If the DC connector is difficult to insert, do not force. Double check the corrector connector direction first otherwise damage may occur.
4. Connect the large 4-pin device connectors to your storage peripherals, such as HDD, CD-ROM or DVD-drive etc.
5. Connect the small 4-pin device connectors to your 3.5" FDD -ovo sam preskocio jer sam odavno iscupao disketnu
6. Connect the SATA 15-pin power connector to your Serial-ATA hard disc device, if available.
7. Connect the 4-pin................za pci express vga karticu koju nemam (imam agp)
8. Connect the RTN grounding cable (thick cable) to one of the fixing screw holes on your mainboard (the RTN/GND connections). Double check for contact with nearby components and short-circuiting.
ovo mi malo nije jasno sto se tu zeli reci pa bi molio nekog da mi objasni
9. The Tagan PSU is for universal use with 115-230 Vac (plus/minus 10%) only!
Make sure that the AC input of your domestic power network has the correct voltage.
10. Double check whether all the connectors to the mainboard and peripherals are properly connected before proceeding with the next steps.
11. Connect the AC power cord to the PSU and to your domestick power network, switch on the power switch and finally turn on your computer system to boot up your operating system (OS).
maticna ploca je soltek SL-865PRO-FGR
http://www.dansdata.com/images/tagans/u22back1024.jpg
na ovoj slici me muci sto znaci taj split i combine, voltaza je namjestena na 230 V te na split (to nisam dirao)
problem je u tome sto kompjuter uopce ne reagira kad ga zelim upaliti, apsolutno se nista ne desava. rastavio sam napajanje ne bi li se uvjerio da je osigurac citav i bio sam u pravu. nista mu se nije desilo. probao sam spojiti staro napajanje na maticnu i upalio ga je bez problema. eto, to je moj problem pa bih molio nekoga ako zna kako da ga rijesim da mi pomogne.
zahvaljujem
vanja81 je offline   Reply With Quote
Staro 20.02.2007., 00:39   #2
domy_os
domy_os's Avatar
Postovi: 18,828
Split znači da će +12 V rail razdvojit na dva slabija raila, a combine će ih ujedinit u jedan jači rail. To nema nikakve veze s uključivanjem napajanja, tj. barem ne bi trebalo. Je li se napajanje pali kad ručno spojiš zelenu i crnu žicu na ATX konektoru?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Zadnje izmijenjeno od: domy_os. 20.02.2007. u 10:21.
Staro 20.02.2007., 08:10   #3
vanja81
Postovi: 8
Autor domy_os Pregled postova
Je li se napajanje pali kad ručno spojiš zelenu i crvenu žicu na ATX konektoru?
nisam probao. neznam ni kako da to napravim, iscupam zice i spojim te dvije zice ili...? sorry sto postavljam glupa pitanja jer nisam bas strucnjak za takve stvari
Staro 20.02.2007., 08:16   #4
domy_os
domy_os's Avatar
Postovi: 18,828
Uzmeš komad žice, spajalice recimo, napraviš od nje slovo U i kratko spojiš te pinove.
Gore si rekao da ti nešto nije jasno, a što točno? Znači, ništa se ne pali s tim napajanjem, ni jedna LED-ica ni vent(ovi)?
Staro 20.02.2007., 08:35   #5
vanja81
Postovi: 8
aha, probat cu to napraviti poslije posla pa cemo vidjeti da li ce reagirati. hvala
pod tockom 8. mi nije jasan taj RTN grounding cable sta je i cemu sluzi? ako je nebitan u vezi mog problema ne moras ni odgovoriti.
odgovor na drugo pitanje...da, nista se ne pali sa tim napajanjem, ne gori niti jedna led-ica niti ventilatori. mrtav je.
Staro 20.02.2007., 09:38   #6
domy_os
domy_os's Avatar
Postovi: 18,828
RTN grounding cable je kabal za uzemljenje, takni crni kabal koji na kraju ima ovo...
...i to se onda stavi ispod nekog šarafa na kućištu. Služi za smanjenje elektrointerferencija i ostalih smetnji.
Staro 20.02.2007., 09:45   #7
vanja81
Postovi: 8
e da, to imam ali nisam ga uopce nigdje stavljao. ne vjerujem da zbog toga ne radi.
Staro 20.02.2007., 10:02   #8
domy_os
domy_os's Avatar
Postovi: 18,828
Da, nema to veze, mora i bez toga radit...
Staro 20.02.2007., 10:16   #9
vanja81
Postovi: 8
hvala, i tebi. isprobat cu to sto ste mi rekli
Staro 20.02.2007., 10:19   #10
domy_os
domy_os's Avatar
Postovi: 18,828
Ma lol, ja sam se zahebo, mislio sam na zelenu i crnu. Umor čini svašta...
Editirao sam.
Staro 24.02.2007., 20:06   #11
vanja81
Postovi: 8
hvala svima na pomoci, problem bi se trebao rijesiti u ponedjeljak kada kupim novi osigurac. ipak je do toga doslo, nisam dobro vidio dok nisam popizdio te skinuo garanciju ne bi li rastavio skroz to napajanje te kolega izvadio osigurac gdje je pukla zica.
