Staro 04.01.2007., 21:07   #1
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
NiBiRu
Zapeo sam na ovome djelu, ako tko zna kako riješiti tu zagonetku neka napiše
Staro 05.01.2007., 21:48   #2
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
pa kaj nitko nije igral tu avanturu?!?!?
Staro 05.01.2007., 23:31   #3
morph
morph's Avatar
Postovi: 1,530
http://www.gameboomers.com/wtcheats/pcNn/NiBiRu.htm
http://www.adventurelantern.com/Walk...iru/nibiru.htm
http://www.uhs-hints.com/uhsweb/nibiru.php
Solution by drdel:
At the start of the puzzle, Save your game before you touch it.
In the close up you’ll see the balls arranged in four radial arms at clock positions: 12, 3, 6 and 9 o’clock. If you look at the little arrows at each clock position, you’ll see which colors are to finally go on the arms: 12 o’clock = red; 3 o’clock =green; 6 o’clock =white; and 9 o’clock = yellow.
When you start, the balls are arranged from inside out on each arm as: white, green, red and yellow. Obviously, you’re going to have to do some jiggling to move the balls around so that there is one of each color in each ring in the correct aspect to each other.
Keep the relationship of the colors to each other in mind as you go, and think Rubik’s cube! That’s what gave me a clue to finally solving this wretched little monster!
You’ll see there are four rings, plus an outer ring with a ‘free’ spot, that you can temporarily park a ball on. I labeled mine from center outward as 1R, 2R, 3R, 4R and OR (for outer ring). All the rings move either clockwise or counter-clockwise with L or R mouse clicks. Clicking on a ball will move it to an empty space. Clicking on the empty space just moves that ring, so position your mouse carefully when you’re clicking.
Here goes:
R mouse click your OR to the 6 position. Click on each ball and move each one outward. That leaves a slot on the 1R to move something into.
R mouse click 1R. At 3 o’clock position move all the balls towards the center
R mouse click OR to 3 position. Insert yellow ball into the 4R.
R mouse click OR to 12 position. Move all balls outward.
R mouse click 2R. At 12 position move red ball to center.
R mouse click 3R. At 12 position move all the rest of the balls toward the center.
R mouse click OR to 9 position. Move all balls outward.
R mouse click 2R. At 9 position move yellow ball toward center.
L mouse click 2R. At 12 position move red ball toward center. Move yellow ball down to 3 R.
L mouse click OR. Move yellow ball in to 4R.
R mouse click OR. At 9 position move all balls outward.
R mouse click 3R. Move one yellow ball in.
R mouse click 4R. Move remaining yellow and the green balls in.
R mouse click OR to 6 position. Move all balls outward.
L mouse click 2R. At 6 position move the white ball in toward center.
R mouse click 2R.
R mouse click 3R. At 3 position move the green ball toward center.
L mouse click 3R. Move all white balls in toward center.
L mouse click OR to 9 position. Move green ball onto OR. Also, move 3R yellow ball to 4R.
R mouse click 4R. Move 4R yellow ball to 3R then L click 4R.
You should now have all yellow and white balls in their proper positions.
Now to fix red and green!
R mouse click 3R. At 12 position move 3R red ball to 4R.
L mouse click 3R. At 3 position move 2R green ball right to 3R.
L mouse click 3R. At 3 position move 3R green ball to 2R.
R mouse click 3R.
R mouse click 4R. At 12 position move 4R red ball down to 3R.
L mouse click 4R
R mouse click OR x 2 and pop green ball onto it’s proper arm.
If done correctly, a panel opens on the side. Take the prism. Look at the prism in inventory.
morph je offline   Reply With Quote
