Staro 13.08.2003., 18:47   #1
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
ibm feature tool
Nesto me zanima, posto nemam floppy jer ima neki nacin da se to snimi na cd ili slozi neki boot cd?
Veky je offline   Reply With Quote
Staro 13.08.2003., 18:51   #2
Veky
Veky's Avatar
Postovi: 1,950
Nasao sam, ovo je zakon.
http://www.ultimatebootcd.com/
Staro 13.08.2003., 21:00   #3
Veky
Veky's Avatar
Postovi: 1,950
Evo pokrenuo sam feature tool i imam pitanjce.
Kaze da je acoustic management i power management iskljucen.
Jel to treba bit ukljuceno?
IBM stranica kaze:
Change the drive Automatic Acoustic Management settings to the:
Lowest acoustic emanation setting (Quiet Seek Mode), or
Maximum performance level (Normal Seek Mode).
Change Advanced Power Mode - allows you to change between the lowest power consumption and the highest power consumption (maximum performance level).
:confused:
Staro 14.08.2003., 05:31   #4
marac
marac's Avatar
Postovi: 2,030
Akustik menađer ti usporava disk ali značajno smanjuje buku diska pa ti odluči da li ti ej potrebniji 2mb/sec brzi disko ili tiši disk!
