15.07.2003., 21:15 | #1 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,484
Novi Catalyst 3.6
Dakle-novi driveri,novi Control Panel i WDM Capture Driver Nekaj JE bilo govora da će se po novom svi uočeni problemi promptno rješavati,ali ovo je fakat bilo brzo... http://mirror.ati.com/support/driver.html |
15.07.2003., 21:21 | #2 |
Head Of The Radio
Datum registracije: May 2003
Postovi: 672
Ja pičim još na 3.2 i nemam problema pa ih neću skidat možda kasnije iz znatižeje ali za sada NE... Stvarno je ATievo izdavanje novih drivera učestalo no bilo je govora o upgradeu drivera ili tak nešto(možda dođe 4.0 s tim mogućnostima ) |
15.07.2003., 21:22 | #3 |
PC Ekspert
Datum registracije: Sep 2000
Lokacija: Zagreb, Hrvatska
Postovi: 1,214
Prebrzo... Ja sam tek uspio zbenchat 9800 Pro s 03.5 da ju mogu usporediti s FX5900, i kad tamo eto 03.6... E fuckat ga, sad vise nemam 9800... Idem bas vidjet listu fixeva, mene ni 03.5 nisu mucili.
Nissan GT-R Black Edition |
15.07.2003., 21:25 | #4 |
Super Moderators
Postovi: 17,484
New Features The CATALYST™ software suite now provide a Force TV Detection feature. Force TV Detection Some TV sets may use non-standard inputs resulting in the TV enable button continuing to stay grayed out in the ATI Displays tab. This issue is address by a Troubleshoot button that is now available. This button allows the user to force detection of their TV. However, features that rely on automatic detection of the TV will not be supported on the TV display. TV detection will also need to be re-enabled each time the system is restarted. Issues Resolved in CATALYST™ Version 3.6 This section provides information on game issues that have been resolved in the latest release of CATALYST™. Switching to the program Second Life using the ALT-Tab command no longer results in the system not responding or looping indefinitely Running the demo game Lord of the Realms 3 under Windows XP with a RADEOIN 9000 series card installed no longer results in the system not responding when a 3 stage effect is used The game Unreal Tournament 2003 no longer hangs when loading the CTF-December level The geometry flashing throughout the background of Second Life is now resolved Flickering and display corruption in the game NeverWinter Nights is now resolved Resolved Benchmark Issues This section provides information on Benchmark issues that have been resolved in the latest release of CATALYST™. Running ViewPerf 6.1.2 under Windows ME with any RADEON™ family product installed no longer results in the application not being able to render an image Resolved Software Application issues This section provides information on application issues that have been resolved in the latest release of CATALYST™. Objects are now generated and the VP is no longer gray when running 3ds max in D3D mode Loss of focus when switching between different layers in Studio Tool 10.1 is now resolved Full Screen Anti-Aliasing no longer causes corrupt geometry in model viewer program Overlay no longer disappears when moving the mouse around in panning mode on the secondary display adapter in the application Overfly Resolved CATALYST™ Driver Issues This section provides information on CATALSYT™ driver issues that have been resolved in the latest release of CATALYST™. Multimedia mode scaling and positioning issues have now been resolved when using TV out Display corruption noticed on the ATI Demo Rachel running under Windows XP is now resolved The lighting and triangle culling on the 3D pipes screensaver no longer is incorrect when using a RADEON™ 7000 series card under Windows 2000 Significant CPU usage is no longer noticed when Hardware Overlay Alpha Deblocking is in use Enabling Overlay Theater Mode and playing an HDTV source through the ATI File Player, no longer results in the system rebooting The TV can now be disabled using the Troubleshoot button in the ATI displays tab Connecting a secondary DFP and attempting to enable extended desktop mode no longer now results in the secondary display device becoming active Setting an LCD as the primary display, and a CRT as the secondary display followed by enabling Overlay Theater Mode, no longer results in display corruption when preview the screen saver on the secondary display Enabling extended desktop at certain resolutions and colour depths no longer results in display corruption on the secondary controller Installing a RADEON™ 9600 series card in a motherboard supporting AGP 8X no longer results in some 3D applications failing to respond Known Issues The following section provides a brief description of known issues associated with the latest version of CATALYST™. When updating to future CATALYST™ releases your current color control panel profiles will be lost. This will be fixed in an upcoming CATALYST™ release Running the 3D Pipes screen saver for an extended period of time (24 hours or longer), produces an error message indicating that the virtual memory is not enough Setting the Landscape details to Perfect in the game IL2 Stumovik Forgotten Battles results in the system not responding during the track playback Running MS Links 2003 with Anisotropic filtering and Anti-Aliasing enabled results in vertical and horizontal lines being displayed within the game. This issue is known to occur under Windows XP with a RADEON™ 9700 series card installed. This will be fixed in an upcoming CATALYST™ release Enabling Anti-Aliasing and attempting to take a screen shot results in a corrupt capture when running OpenGL games such as, CounterStrike, Half-Life, Quake III or Medal of Honour: Allied Assault. This will be fixed in an upcoming CATALYST™ release -------------------------------------------------------------------------------- |
15.07.2003., 21:55 | #5 |
Super Moderators
Postovi: 17,484
E, budući da sam ja prvo postao listu fixova,a odmah poslije mene Kova jedno je moralo otići... Nemožemo preko cijele stranice imati dvije iste liste fixova... Da-odmah je izašao i 9500-9700 patch za 3.6 drivere,može se skinuti naravno tu: http://www.ocfaq.com/softmod/ |
15.07.2003., 23:17 | #6 |
***2CROwded***
Datum registracije: Mar 2002
Lokacija: Cro
Postovi: 1,610
Da imaš pravo Jelc, vidiš ja sam ostavio samo zato što smo u isto vrijeme postali, iako bih ja to izbrisao Moram si to sve skinuti, samo neću od doma, budem s DSLom kod frenda |
16.07.2003., 13:26 | #7 |
Datum registracije: Nov 2002
Postovi: 842
U hebo te. Pa tek sam instalirao 03.5 a već je izašla nova verzija. A ne daju mi se sad skidati
16.07.2003., 15:19 | #8 |
Caught Somewhere In Time
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
Malo je ovo off topic ali pojavili su se novi radeon tvikani drajveri pod nazivom DNA, napravio ih je neki tip iz nizozemske i ljudi vele da su bolji od omege. Ne da mi se postat link ali na rage3d.com se mogu nać sve informacije. Baj d vej kaj se tiče drajvera mislim da ati malo sere jer zadnjih par riliseva nisu donijeli nikakav poseban napredak a ja sam otkad sam kupil 9700 imal sam probleme sa 3.4 i 3.5 drajverima. Nevjerojatno nestabilan frjem rejt padovi sa 85 na 30 i sl u nekim stvarima koje bi trebale letit i to sa i bez aa i af. Već sam razmišljao da se vratim nekaj starijim drajverima 3.2 mi se čini još uvijek najboljom verzijom. Po meni par pokrpanih stvari nisu dovoljan razlog za novu reviziju drajvera. Makar sad sam karticu modal u fire gl X1 i fino mi radi s tim drajverima čak neke igre idu bolje jedino kaj nemam cp-a. Baj d vej zna neko kak se cracka Maya 5.0 unlimited just kidding U 3d s maxu radi jako dobro. |
16.07.2003., 15:32 | #9 | |
Super Moderators
Postovi: 17,484
Imaš BIOS za FireGL X1... http://www.3dchipset.com/bios/ati/warp11/index.php Kaj se tiče Maye-probaj hitit oko na hr.comp.video pod "pogledajte obavezno ovo" od 15.07...ili pitaj BD-a...ja već malo duže nisam sa tim na ti... |
16.07.2003., 16:29 | #10 |
Postovi: 1,895
Evo ja ih skinuo, instalirao i sve radi. Onaj troubleshoot TV je ok stvar. Sto se tice igara, nikakvih bitnih promjena (Battlefield, Diablo II) Al ATi sad stvarno pretjeruje s izadavanjem tih novih drivera... |
16.07.2003., 16:56 | #11 | |
Postovi: 1,860
a kaj BD je glavni za te crackove??? E fala za ovo na hr.comp.video budem bacil oko |
16.07.2003., 17:10 | #12 | |
Super Moderators
Postovi: 17,484
Vidiš-ATI-ca ti je dušu dala za neke stvari...obavezno si stavi na drugi monitor/ako ga imaš/ "alate" i na glavnom delaš ko" čovjek...to bu ti spasilo dosta vremena i živaca... Ma možeš čak i na NVidia karticama uključiti"prošireni" desktop... |
16.07.2003., 18:48 | #13 | |
Postovi: 842
16.07.2003., 22:24 | #14 | |
Super Moderators
Postovi: 17,484
19.07.2003., 10:54 | #15 |
Super Moderators
Postovi: 17,484
E da...čisto sam zaboravio-evo i ATI Cat 3.6 9700 > 9800 Hack... http://sunrise.stolemy.tv/ati.shtml Zanimljivo-neki tvrde da su ga probali i na 9500/9500PRO i da dela,sam autor kaže- You could try it on 9500/9500 PRO cards too I guess. Evo... |
19.07.2003., 20:35 | #16 | |
Postovi: 1,860
barem sam ja tak skužio |
19.07.2003., 20:55 | #17 | |
Super Moderators
Postovi: 17,484
Pa ti imaš 9700,kaj te košta-probaj,lupi par testova i igrica sa 6xAA-16xANISO pa buš vidio...ako nije ok lijepo izbriši taj file,vrati nazad stari i bog te veseli... |
19.07.2003., 21:18 | #18 | |
Postovi: 1,860
19.07.2003., 21:24 | #19 | |
Super Moderators
Postovi: 17,484
19.07.2003., 23:07 | #21 | |
Postovi: 1,860
A čuj ak neko ima turbo jaku konfu onda nek proba ja sam sa performansama zadovoljan |
20.07.2003., 00:08 | #23 | |
Super Moderators
Postovi: 17,484
U igrama bi se to fino osjetilo... |
20.07.2003., 07:32 | #24 |
Datum registracije: Jul 2003
Lokacija: Australia
Postovi: 6
radi za mene |
20.07.2003., 17:24 | #25 | |
Postovi: 1,860
Imam tri kante tak da ne znam kud bi to sve stalo A ono bitno stoji gore pored nicka |
20.07.2003., 17:39 | #26 | |
(°_°)
Postovi: 3,249
Toshiba m200 TabletPC + Samsung 205BW |
20.07.2003., 17:45 | #27 | |
Postovi: 1,860
