Lokacija: Agram
Postovi: 2,982
![]() http://download.microsoft.com/downlo.../w2ksp4_en.exe i to je to ljudi. 130 Mb težak download u kojem se nalazi 675 ispravki za još uvijek najbolji M$ OS.
Datum registracije: Nov 2002
Postovi: 1,950
Cek cek, jel to 675 novih ili sveukupno? Kolko je novih? Bas me zanima. |
Lokacija: Agram
Postovi: 2,982
Unutar ovog SP4 se nalazi 675 zakrpa sveukupno, a za budući SP5 je već izašlo novih 27 ![]() 328504 - Files Are Not Saved and You Receive a "Windows Delayed Write Failed" Error Message When You Remove Flash Card 811657 - WSAIoctl (SIO_SET_QOS) Returns SUCCESS When It Should Return FAIL 813130 - A Computer May Lose Network Connectivity Under High Stress 816560 - You Cannot Save Printing Preferences 817298 - Services.exe Quits Unexpectedly and Restarts the Primary Domain Controller 817429 - Memory Leak in Task Scheduler When You Schedule Programs or Processes to Run for a Long Time 817472 - IDE ATA and ATAPI Disks Use PIO Mode After Multiple Time-Out or CRC Errors Occur 817772 - MS03-019: Flaw in ISAPI Extension for Windows Media Services Could Cause Denial of Service 817892 - Cannot Connect to a Windows-Based Server That Is Running NAT If the Client Source Port Is 1723 818043 - L2TP/IPSec NAT-T Update for Windows XP and Windows 2000 818323 - "Stop 0xC2" Error Message When the Computer Resumes from Hibernation 818383 - The Keyboard and Mouse Do Not Work When You Resume from Standby 818528 - Problems When More Than One User Accesses the Same File Through Terminal Services 818529 - Download - MS03-020: June, 2003, Cumulative Patch for Internet Explorer 818603 - You Cannot Specify a User or Group from an External Trusted Windows 2000 Domain When You Copy a User Profile 818704 - Programs That Require Continuous Connection to Target Servers Do Not Function As Expected After Upgrade to Windows 2000 818740 - Access Control List Editor Displays Groups by Using Their SAM Account Names Instead of Their Display Names 819249 - You Receive an "Event ID 1311" Message Every 15 Minutes in the Directory Services Event Log 819628 - Screen Output from the DrawText API Appears Incorrectly 819636 - Computer with Multiple SCSI Controllers and /3GB Boot.ini Option Stops Responding with SYSTEM_PTE_MISUSE (0xDA) Stop Error 819895 - STOP 0x0000000A Error When Computer Performs Intensive Operations on USB Drives 820519 - Two Nodes Successfully Claim Ownership of the Same Quorum Disk After Loss of Heartbeat 820579 - Problems Occur When a Program Tries to Access a USB 2.0 DVD Drive or CD-RW Drive 820841 - A "Stop 0x00000010" Error Occurs in Scsiport.sys in Windows 2000 821144 - MSMQ: Message Queuing (MSMQ) Applications May Stop Responding Because of a Deadlock in MQSEC.DLL 821653 - Messages May Not Be Sent If the Sender Belongs to Too Many Groups 821290 - Clicking the Network Icon Does Not Open the Local Area Connection Status Window After You Bring Your Computer out of Standby
