Rakija
Postovi: 484
Dizanje Windoza
evo mog problema kada upalim komp i prije nego se pojavi boot screen javi se poruka: Scanning IDE drives... No drive attached to Fasttrack Kontroller.THE BIOS IS NOT INSTALLED. ali bios radi normalno.Sve to mene nebi smetalo da mi se windowsi ne dizu 1 minutu, sto mislim da je previse a gase se nekih 30 sec. To mi se desava otkad imam kompjuter i s novim windowsima i driverima... Evo moje konfiguracije:AMD Athlon 64 3200+,Asus K8V SE DELUX,2*512 MB memorije, HDD segate Barracuda 40 GB MB Cache,Ge Cube Radeon 9600XT. Hvala |
Lokacija: Split Hrvatska
Postovi: 936
da pogledaš u bios-u možeš li isključit taj kontroler |
Postovi: 18,874
Još kad bi netko pogledao FAQ na stranici proizvođača... Question: I've got an error message for K8V SE Deluxe - "No drive attached to FastTrak controller, the BIOS is not installed." during boot up. What should I do? Answer: You can find FastTrack controller as "Promise R20378 RAID controller" from the specification. The message reports that there is no hard drive attached on Promise controller. It is just informing you when you have not connect any hard drive on Promise controller. Hence, if you didn't connect hard drive on Promise controller, you can ignore this message.
Junior Member
Datum registracije: May 2003
Postovi: 3,205
U biosu treba isključit ak ti smeta.
__________________ |
Rakija
Postovi: 484
evo napokon sam nasao i iskljucio ali mislim da bi mi se windowsi trebali brze dizati, |
