Staro 14.09.2006., 19:56   #1
daytripper
Ultrabitchinfast
daytripper's Avatar
Postovi: 880
9250 agp problemi...
Pozdrav, imam powercolor 9250 128 bita, 128 mb. Pise da kartica radi do 8xagp. Na Ms9147c ploci nemogu dobiti vise od 2x agp(mislim da zbog via chipseta).
Kupio Asus P4pe koja za agp koristi 1.5v kartice, bez njih nema pokretanja sistema, nista. svijetli crvena dioda za upozorenje, kao sto pise u manualu.
E sad, ako podrzava 8x agp, nije li to 1.5v.
Brijem da je kartica shebana, jer na Ms ploci radi ali na 2xagp. imate koje rjesenje? ili je ploca? ne kuzim.: stoopid
daytripper je offline   Reply With Quote
Staro 14.09.2006., 20:19   #2
daytripper
Ultrabitchinfast
daytripper's Avatar
Postovi: 880
evo sto sam nasao. trebam novi bios.
AGP slot/card support status:
Generally...
If AGP 1.0 or 2.0 card is running in 2x, 1x mode it will use 3.3v
If AGP 2.0 or 3.0 card is running in 4x mode it will use 1.5v
If AGP 3.0 card is running in 8x mode it will use 0.8v
AGP 1.0 slot supports 1x and 2x at 3.3v
AGP 2.0 slot supports 1x and 2x at 3.3v
AGP 2.0 slot supports 4x at 1.5v
AGP 3.0 slot supports 4x at 1.5v
AGP 3.0 slot supports 8x at 0.8v
AGP 2.0 and 3.0 cards and slots overlap nicely. Hardly anyone has sold an AGP 1.0 anything for a couple of years now.
The only real 'bender' to these rules is that some boards based on Intel chipsets with an AGP 2.0 slot do not support 3.3v (2x, 1x) AGP operation. These boards will usually feature a large warning sticker or be keyed to not accept an AGP 1.0 card.
Staro 14.09.2006., 22:26   #3
daytripper
Ultrabitchinfast
daytripper's Avatar
Postovi: 880
rom je write protected. moram znaci novu grafu ubosti. valjda nvidia.: hello2 :
Staro 15.09.2006., 09:34   #4
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ne kužim te sad baš?
Što ne radi na čemu? Ako ti na ploči radi u AGP2x modu što te briga to nije AGP 2x mod glede napona ako je 4x/8x kartica jer bije grilao, a ako je glede propusnosti što te briga nećeš nišda puno izgubit time jer ionako je AGP sa sistemskom memorijim x puta slabiji od grafičke memorije i nema nekog smisla da se od tamo nešto kopira u smislu tekstura a za igranje sa ispravnim postavkama pri kojima su sve teksture u video memoriji može ti u PCI modu radit i bit će isti drek možda 5% manje ćeš imati preformanse...
E da i Via i Ati se poslovično znaju poklat...
Have a nice day...
Staro 15.09.2006., 19:35   #5
daytripper
Ultrabitchinfast
daytripper's Avatar
Postovi: 880
ne radi uopce na asus p4pe ploci. ona treba 1.5v na agp kartici a ako je 3.3v kartica uopce ne radi. sad sam stavio gforce mx400 i radi perfektno. znaci da je kartica shebana. dao sma frendu neka je isproba.
Staro 16.09.2006., 10:53   #6
yedwy
yedwy's Avatar
Postovi: 6,956
Autor daytripper Pregled postova
Ne ne znači da je s***ana, vjerojatnije je da se VIA i ATi ne vole već sam viđao slične stvari...
Have a nice day...
Staro 16.09.2006., 11:15   #7
daytripper
Ultrabitchinfast
daytripper's Avatar
Postovi: 880
To znam da se via i ati ne vole bas. ALi fora je u tome da na Asus P4PE ploci sa intel 845pe chipsetom ne radi uopce. Ne radi jer ploca dopusta samo 1.5v kartice. Naime Radeon 9250 ide do 8x agp, te ima univerzalni agp port, tako da radi i na 3.3v i 1.5v agp utorima na plocama. Medutim na asus ploci uopce ne radi. To je stos. Jer mx400 od nvidie uredno radi na njoj.: sweating
Staro 16.09.2006., 13:11   #8
yedwy
yedwy's Avatar
Postovi: 6,956
Aha tako... Krivo sam te skužio moj bad... : suicide : suicide : suicide
Da to je čudno da neće na 845 ploči radit...
Onda je ili stvarno mrtva ili nešto drugo s njom ne valja...
BTW jesi siguran da je i 2x i 4x kartica? To mi je malo čudno jer sam je bio uvjeren da je 9xx0 radeon serijal samo 4x/8x...
Ako si je piknuo u 2x ploču možda je grilana...
Have a nice day...
Staro 17.09.2006., 09:54   #9
daytripper
Ultrabitchinfast
daytripper's Avatar
Postovi: 880
Moguce, jer mi via nije dala vise od 2x agp pa je mozda sibnula vise voltaze. Naime kad agp 2.0 kartice dode na agp 2x onda koristi 3.3v.
ALi opet na netu pise da je on i 2xagp radeon, upravo zbog tog univerzalnog agp slota. vidjet cu da li je riknula.
sandra je pokazivala da je 2xagp ali 2*88 a ne 2*66, jer sam clocknuo komp a via nema agp/pci lock. mozda ju je to skurilo. neznam, bude mi frend pogledala kod sebe.
