Staro 01.09.2006., 19:02   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Maxtor u plamenu?!
Well, I was going about my business tonight, got back from the store and hit the power button on my computer... I heard this crackling sound, and smelled something burning, I got worried... but the system continued to boot, but didn't actually boot, it said NTLDR not found, which means it couldn't find the OS Loader on the other drives... so I restarted the system and went into the BIOS, sure enough my 200Gig SATA Maxtor hard drive wasn't there.....
So I powered the system off and pulled the drive, I examined it and it looked fine, so I figured I would just plug it in while it was out of the case to make sure it was running... when I hit the power button flames..LITERALLY shot out of the bottom of the HDD, I was like F**K!!
nastavak priče + SLIKE ovdje: http://tinyurl.com/ov5n8
update:
Well as per instruction by Maxtor, I only need to send back the top cover of the HDD with the information on it, so when I took the top off I discovered the platters were scorched as well.. Check out the pics..
http://tinyurl.com/oe696
Mailman je offline   Reply With Quote
