Staro 06.07.2006., 11:08   #1
axe counter
axe counter's Avatar
Lokacija: rijeka
Postovi: 452
CC u mrezi problemi
u biti nikako na zelenu granu s ovom igrom i mrezom tj. svako malo puca bez obzira igramo li preko neta ili u LAN-u i to sve verzije Close Combata primio sam neki mail kako to rjesiti (za lan) ali mi bas nije jasno ako tko moze pomoći HELP ....evo maila :
go to 192.168.1.1 in internet explorer search bar
IF you have not set your password its as below:
'admin'
'password'
advanced set up,
port forwarding,
save after each line. NOT save and rebot, thats at the end.
2300 2300 2300 tcp 192.168.1.? (MY IP at the end number,go to start/accessories/dosprompt,type'configip, type this number for your IP)
2300 2300 2300 udp 192.168.1.?
47624 47624 47624 tcp 192.168.1.?
47624 47624 47624 udp 192.168.1.?
saved and rebooted,
HAY PRESTO!
axe counter je offline   Reply With Quote
