Staro 24.06.2006., 23:29   #1
duffy
Brum brum...
duffy's Avatar
Postovi: 584
mix ramova
e ovako mjesanjem ddr - ramova od kojih su jedni na 266mhz i drugi na 400mhz ---- dali to smeta. jer sklopio sam racunalo i stalno kod igara mi zablokira nakon par minuta. jer to zbog toga ili nest drugo?
duffy je offline   Reply With Quote
Staro 24.06.2006., 23:45   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
U tom mixu vjerojatno ti rade na 266mhz, ako si ih podesio na više u biosu. Onda je jasno da ti ne rade, jer ovaj 266 ne može radit na 400mhz kao onaj drugi
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 25.06.2006., 01:36   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Ja sam imao (jos uvijek imam ) dvije plocice od 256MB 400Mhz u DC modu, i dodao sam trecu plocicu od 512MB 333MHZ, i radilo mi je normalno na 320 MHz, tak mi je ploca automatski stavila...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 25.06.2006., 02:09   #4
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Radi uvjek na brzini sporijeg rama.
Staro 25.06.2006., 09:30   #5
duffy
Brum brum...
duffy's Avatar
Postovi: 584
Da tak sam i mislio. OK. Thanks.
Staro 25.06.2006., 10:48   #6
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Talking
Nemora uvjek raditi...
Kako je poznato neke vrste ramova se međusobno ne podnose, isto tako neke vrste ramova se ne podnose s nekim pločama...
Mi nemožemo znati koji su kod njega u pitanju pa tako niti procjeniti, a ionako teško da bi ovako napamet neko mogao baš decidirano reći dali se podnose ili ne...
To duffy...
Izvadi prvo stari ram pa testiraj samo s njim unutra...
(pretpostavit ću da je sa samo starim se dobro radilo)
Ako novi radi bez problema - očito se ne podnosi sa starim...
Ako NE radi - zaključak je očit za daljne postupke - nije li?
I na kraju probaj malo dignuti napone rama (sasvim malo za jedan ili dva stupnja gore npr. sa 2.6V na 2.7V ili 2.8V) ako proradi dobro ako ne - vjerojatno ti se ploča kolje s ramovima...
I na kraju znaj da dodatni ram ipak povećava malo potrošnju struje s ploče...
Have a nice day...
