Postovi: 183
pomoć
If you disable Overdrive (might need to re-install the drivers) then disable the mode switcher (i.e. disable the ATI Smart service) and then use ATI Tool the speeds/volts should not change (except if you use the ATITool options). kak se taj Overdrive i ovaj mode switcher gase? |
Postovi: 7,568
Zadnje izmijenjeno od: McG. 17.06.2006. u 00:17. |
#4 | |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
#6 | |
Postovi: 11,642
#8 | |
Lokacija: Požega
Postovi: 174
