Staro 29.05.2006., 14:30   #1
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Battlefield 2 i punkBuster problem?!?
Helou..evo instalirao sam Battlefield2 po prvi put, krenuo da ću igrati na jednom serveru i iskoči mi poruka "GLOBAL punkBuster GUID BAN c10d7590"..probam drugi..isto...ne kužim..šta to znači? Mislim znam..ali kako sam dobio bann kada nisam nikada tu igru online??
Slično ovome samo meni piše "c10d7590" sllika: http://image.donanimhaber.com/image....B67976A8E5.jpg
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Zadnje izmijenjeno od: Brown Acid. 29.05.2006. u 15:01.
Brown Acid je offline   Reply With Quote
Staro 29.05.2006., 15:55   #2
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Kupi orginal igru...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 29.05.2006., 20:32   #3
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Šta znači taj error? Nema to veze s originalima i sl. jer je original. Ako neznas rjesenje..vozi.
Staro 30.05.2006., 00:21   #4
BADSIM
BADSIM's Avatar
Datum registracije: May 2002
Postovi: 152
Jesi li mijenjao bilo sto, tj. dodavao u mapu gdje si instalirao igru.
Raznorazne dodatke, otkljucavanja oruzja, micanje uvodnog videa.........
Gigabyte B450 Aorus elite, amd ryzen 5 2600, 8gb ddr4, nvidia 1060 6gb
Arma 3 i Warthunder u srcu, Suzuki Scross u garaži
BADSIM je offline   Reply With Quote
Staro 30.05.2006., 09:26   #5
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Skini zadnji punk buster - use google...
Ounk buster je anti cheat software koji jako voli stvarati probleme - apsolutno skini zadnju verziju jerbo auto DL u principu ne radi ...
Staro 30.05.2006., 12:29   #6
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Nisam mjenjao ništa..instalirao Battlefield 2 i napravio update sa EA-stranica na verziju 1.3 i također napravio update punkbustera
Staro 31.05.2006., 12:02   #7
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
to je u cod2 kad neko koristi cheatove pa mu bannaju cd key tj. guid i nemožeš s tim guidom više igrati na netu
vjerojatno je tak i za BF2
thuNdeR je online   Reply With Quote
Staro 05.06.2006., 10:20   #8
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Ma punk buster kao takav ne radi baš dobro - super senzibilan je ...
Dok sam igrao BF Vietnam - imao sam brutalnih problema dok sam ga složio...
Pogledaj forume od BF-a, jerbo je Punk jako mušićav i sve mu je cheat -.-
