Staro 03.05.2006., 14:47   #1
QuickTime
Postovi: 15
Windows Post-Install Wizard (WPI)
Šta je to? Za šta se koristi i kako???
QuickTime je offline   Reply With Quote
Staro 03.05.2006., 18:31   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Google, iz prve.
"Windows Post-Install Wizard (WPI for short) is a hypertext application designed for giving users choice. While Windows XP offers many ways of customizing the setup process out of the box, its major drawback is the lack of being able to select which applications an end user may install. In the past, end users and administrators needed to either download the files manually, or create overly complex scripts that could only be used once. WPI allows you to create one image, which can then be custom configured, and optionally, automated, so that end users can install any applications."
tor je online   Reply With Quote
