Staro 30.04.2006., 02:43   #1
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Temperature X850XT Min/Max ??
Naštelavam si grafičku da bude malkice tiša u radu s windozima i također zelim baciti lagani clock pa me interesira koja je temperatura normalna za grafičku:
U mirovanju: __˙C
Rad u windozima: __˙C
Silovanje grafičke igrama: __˙C
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Zadnje izmijenjeno od: Brown Acid. 30.04.2006. u 04:40.
Brown Acid je offline   Reply With Quote
Staro 30.04.2006., 12:05   #2
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
meni ide ovako:
U mirovanju: 30˙C
Rad u windozima: 31˙C
Silovanje grafičke igrama: 56˙C
Artic cooling silencer 4
Smartguy je offline   Reply With Quote
Staro 30.04.2006., 13:08   #3
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Ok, to je Artic Silencer..zna netko temp. sa stock coolerom?
Staro 30.04.2006., 14:56   #4
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
računaj da su nekih 15°C veće otprilike
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 30.04.2006., 16:01   #5
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
nije... prije nekih 10
Staro 30.04.2006., 16:44   #6
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
imah u rukama sapphire x850 xt pe...sa stock hladenjem i do 80 stupnjeva u loadu
Ph03n1x je offline   Reply With Quote
Staro 30.04.2006., 18:10   #7
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
meni se jednom bila popela na toliko kad nisam dobro zavio hladnjak i odma mi resetiralo
Staro 30.04.2006., 18:18   #8
M4rk0
DragonBall Z Fan
M4rk0's Avatar
Postovi: 1,244
76°C - 80°C na full load X800XT + clock MAX.
nisam vise tocno siguran sada imam zalmana VF700Cu i temp mi je 60°C - 65°C na full load + clock MAX.
M4rk0 je offline   Reply With Quote
Staro 30.04.2006., 18:33   #9
Nebelwerfer
Nebelwerfer
Nebelwerfer's Avatar
Datum registracije: Apr 2004
Postovi: 270
WinXP - 39°C
U igri(CoD2) - 65°C
Stock cooler. Jedan vent još dodatno puše na grafičku.
Tiruliru!!
Nebelwerfer je offline   Reply With Quote
Staro 30.04.2006., 19:04   #10
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Puno hvala..
Staro 30.04.2006., 20:13   #11
domy_os
domy_os's Avatar
Postovi: 18,847
Stock na GTO:
Idle - 50°C
Load - 85°C
Silencer @ 5V (cca 1000 rpm):
Idle - 40°C
Load - 65°C
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 30.04.2006., 20:16   #12
dj_kalyx
dj_kalyx's Avatar
Lokacija: dj_ZAGREB
Postovi: 187
WinXP - 34°C
U igri(CoD2) - 58°C
dj_kalyx je offline   Reply With Quote
