Staro 23.04.2006., 03:40   #1
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Postoji li ovo kod nas za kupiti?
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Brown Acid je offline   Reply With Quote
Staro 23.04.2006., 12:52   #2
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
kopija sonic towera....kupi sonic
Ph03n1x je offline   Reply With Quote
Staro 23.04.2006., 13:19   #3
Wolverine
Wolverine's Avatar
Postovi: 12,433
Nažalost još ga nema! To je zasad koliko znam najjači cooler (zračni) no možeš uzet i Sonic-a koji je svega par stupnjeva slabiji!
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 23.04.2006., 13:22   #4
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Ma nije frka, pricekat cu..
Staro 23.04.2006., 13:32   #5
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ako Links ne nabavi nece nitko
Staro 23.04.2006., 16:15   #6
iveumag
zippo61_junior
iveumag's Avatar
Postovi: 1,296
Koja mrcina
iveumag je offline   Reply With Quote
Staro 23.04.2006., 17:11   #7
Bran
nemam kaj napisati
Bran's Avatar
Datum registracije: May 2003
Lokacija: Međimurje
Postovi: 1,303
Kak je ogroman. Za to sigurno treba oružani list.
Staro 23.04.2006., 20:34   #8
Wolverine
Wolverine's Avatar
Postovi: 12,433
nije niš veći od sonica ili ninje
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 23.04.2006., 20:36   #9
Roberto
Roberto's Avatar
Postovi: 2,669
Autor Wolverine
ali je zato dosta skuplji...
Staro 23.04.2006., 20:37   #10
LuXor
Datum registracije: Jul 2004
Lokacija: Bjelovar
Postovi: 752
Ogroman je, ali čini se još većim jer ga p*zde snimaju iz žablje perspektive pa se k*rče da imaju najvećega : smoke :
LuXor je offline   Reply With Quote
Staro 23.04.2006., 20:44   #11
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
mislim da je iste veličine ko Sonic al je u sredini vent i nema onog prostora u sredini ko kod Sonica, zato je vjerojatno i bolji za par stupnjeva.
vidi se na kilometar da je kopija Sonica. aj, bar im je uspjelo napravit bolju kopiju nego original.
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 28.04.2006., 14:03   #12
Mr.Lee
Lokacija: Bg
Postovi: 4
Dimenzije Sonic Tower-a : 112 x 112 x150 mm
Dimenzije Tuniq Tower-a : 131mm (W) x 108mm (H) x 153mm (D)
Dimenzije Scythe Mine : 105 x 109 x 150mm (L x B x H)
Neko gledajuci design Sonic Tower-a se sigurno setio da proba da stavi
veliki ventilator u sredini i tu je pocelo sve.Takozvana sendvic tehnika
ima tu prednost da dozvoljava da se usmeri ventilator tako da izbacuje vazduh van kucista preko njegovog zadnjeg dela iliti preko donjeg dela
napajanja.Mana mu je da vec toplim vazduhom s jedne strane (izmedju rebara) hladi drugu stranu.Zanimljivo je da je kod Tuniq-a koriscen 120 mm
ventilator koji viri ispod dole i zbog turbulencije koje se stvara na tom mestu
pravi karakteristican zvuk.Nasuprot Japanci kod Scythe Mine kulera su to resili tako sto su upotrebili nestandardni 100 mm ventilator izuzetnih karakteristika.Prilog slika.
Mr.Lee je offline   Reply With Quote
