Staro 19.03.2006., 10:39   #1
theI
Lokacija: zagorje
Postovi: 4
intel maticna
Maticna Intel 945PVSLKR ATX Intel@ 945P Express Chipset,LGA775
socket. supports 1066/800/533 MHz System Bus, Dual Channel DDR2
667/533/400 SDRAM Memory, Intel@ EM64T, Intel(R) Matrix St~rage
Technology (NCQ, Hot Plug, RAID 0, 1, 10, 5 and Matrix RAID, PCI
Express* x16, four PCI connectors, two PCI Express* xl connectors, up
to 8 Hi-Speed USB 2.0 ports (4 back ports.), up to three IEEE-1394a
ports (1 back port), Intel@ High Definition Audio enabling 7.1
Surround Sound, four SATA ports (3.0 Gb/s), and Intel@ PRO 10/100/1000
Network Connection.
kaj mislite o ovoj maticnoj? e ima ko iskustva s intelovim mat?
theI je offline   Reply With Quote
Staro 19.03.2006., 11:35   #2
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
stabilna ploča, ali ako misliš overclockati nije neki izbor
Staro 19.03.2006., 11:35   #3
Darth Vader
Dark side Moderator
Darth Vader's Avatar
Postovi: 1,633
intelove poloce ako nisu za uredsku upotrebu i nisu nekakav dobar izbor. oc mozes zaboravit. trebale bi biti stabilne u onom sto obavljaju al ako si gamer ili se volis zezat s kompom bjez od intela.
Jak ko rakija!
Darth Vader je offline   Reply With Quote
Staro 19.03.2006., 13:32   #4
theI
Lokacija: zagorje
Postovi: 4
ocete reci da se uopce nemre overclockati (zasto, ne kuzim se bas u te stvari)?
Staro 19.03.2006., 13:55   #5
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Autor theI
Vjerovatno se da nesto sitno OC, moja ide 100MHz a imam proc za OC...
Jedino kaj su Intel ploce full stabilne, hladne i radene da traju
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 19.03.2006., 16:38   #6
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor theI
Mislim da u BIOS-u nema opciju za oc ili je FSB jednostavno zakljucan.
Staro 19.03.2006., 21:56   #7
Ramses_III
kapetan Janez Ibrahimovič
Ramses_III's Avatar
Lokacija: Novska
Postovi: 265
Evo ja konkretno imam Intel Billings2 D845EBG2, proc. P4 Northwood 2,666 MHz i nema šanse da ju OC, jednostavno je lockano u BIOS, a ni pokušaji iz Win nisu uspjeli.
Ramses_III je offline   Reply With Quote
Staro 20.03.2006., 09:36   #8
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Sve ploče tipa Intel, Abit, ASUS, MSI... su rađene da traju i ful su stabilne ako ne popčneš OCat, a onda se niti nemaš pravožaliti na njih.
Bolje uzmi neku od ASUSa i za koj mjesec kad se napališ na OC budeš spreman, a ovako ćeš plakat
Nemam više lema!!!
