Staro 01.03.2006., 19:24   #1
T o T o
Lokacija: herc
Postovi: 1
kako overclock.?
poz.
evo citam malo o overclocku i nisam bas upoznat s ovim... : )
posto vidim da ovde ima experta za overclock molio bih nekoga da me uvede malo u to...mislim da overclockujem moj PC ali u sigurnim granicama..
dole ispod sam stavio ispis sto mi je izbacio software "aida32"
pa ako moze netko da mi objasni sta mi je radit....hvala unaprijed
T o T o je offline   Reply With Quote
Staro 01.03.2006., 19:29   #2
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Imash intelovu maticnu,ako sam dovoljno upucen mislim da ne mozes nista overclockirati,neka me neki intelovac ispravi ako grijesim
Staro 01.03.2006., 19:52   #3
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
potpisujem
Staro 03.03.2006., 01:56   #4
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Autor Thoroughbred B
Potpisujem, moja ide samo 4% oc...
@T o T o
Probaj s CPUFSB, ako uspijes narihtat clock generator...
Evo link-> http://www.majorgeeks.com/download.php?det=420
Makar po mojem misljenju ostavi kak je, neces previse dobit ako OC-as, jos imas i SD-RAM... Dok ide nek ide, kad ce bit preslab, kupi novu konfu...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
