Staro 26.01.2006., 13:51   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Talking Old Celeron OC!!!
Eto, svi clockate nove piceke, i ja bi rado - ali nemogu... Maticna mi je za q..., mislim dobra je za ovak radit, nema stabilnije - ali za OC je nula...
Pa sam se odlucio malo zezat sa starim Celeronom od 500MHz. Do kolko bi to islo na mojoj Asus CUB-X ploci? Inace FSB ide stabilno do 133/140MHz na toj maticnoj sa P3 667MHz
Idem probat pa javim rezultate....
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 27.01.2006., 04:34   #2
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,317
...nemas pci lock,skurices nesto,ostavi se celera da pociva u penziji
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 27.01.2006., 10:02   #3
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Ako imas neku plocu koja je dobra za oc...nemas opasnosti.
Ja sam na KT133A vozio 166Mhz FSB i nisam skurio nish. A nije imala PCI/AGP lock...sve radilo normalno
Staro 27.01.2006., 10:35   #4
piNheaD
piNheaD's Avatar
Lokacija: Senj
Postovi: 636
Na mojoj Gigabytici nema Agp i Pci lock ali ima za stavit frekfenciju Agp-a.Znači,kad stavim frekvu Agp-a na 66Mhz-a automatski se zaključava Pci na 33Mhz-a.Provjeri dal imaš tu opciju i deri
Suck Satan's cock
piNheaD je offline   Reply With Quote
Staro 28.01.2006., 00:51   #5
Panzer
Panzer's Avatar
Postovi: 1,814
Ima agp i pci lock, imam na jumperima za riktat... ima do 150fsb,33 pci...
ali nekaj sam skuril...
neznam kaj, brijem maticna... metnul proc, ovaj celeron 500, a zaboravil poriktat na 66fsb, tak da je radil na 1000 mhz -> 133x7.5... Nema veze, jedino kaj moram sad nekaj sredit s tim kompom, uglavnom grafa, zvucna i te stvari rade normalno... jos moram stestat memu i proc...
UPGRADED...
Staro 28.01.2006., 01:46   #6
bozzomfeeder
bozzomfeeder's Avatar
Lokacija: Sinj
Postovi: 1,080
Buhahahaha,imao sam ja taj proc,to je bila zvjerka jedini "poluproc" koji je dostojan bio starije braće.(PIII)
bozzomfeeder je offline   Reply With Quote
Staro 28.01.2006., 12:22   #7
maX
maX's Avatar
Postovi: 7,326
Ne vjerujem da si nesto skurio... Ako je bio podesen proc na 7.5x133 on na tolko nije mogao radit i ploca ga uopce nije palila. Probaj napraviti CMOS i probaj proc na drugoj ploci. Ako se ja dobro sjecam ti celeri rade na visem naponu (2.0V) od P3 (koji radi na 1.75V) tako da celera 99% nisi skurio buduci da je radio na manjem naponu. Probaj pogledat za Vcore jumpere na ploci i ako ima digni napon na 2V jer je 1.75V celeru premalo buduci da je to Mendocino jezgra, a P3 je coppermine.
