Staro 19.01.2006., 01:33   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radeon Omega Drivers 3.8.205 (Cat 6.1)
Ovo je bilo brzo
Well, I hope this is fast enough.
What's New in Omega Drivers?
v3.8.205[*] Based on the Catalyst 6.1 Official drivers.
[+] Starting from this set, I will use my own version internally for the Catalyst drivers, instead of using 6.1, 6.2, etc, I will be naming them 6.01, 6.02, etc, this will make the Cat versions less confusing and more "logical".[*] Updated Multires to v1.56. (fixes the "non-supported" resolutions bug)
[+] New version naming scheme for the Omega Drivers, now is based on the internal ATI version number than in the 2D Display version.
What's new for ATI Tray Tools?
1.0.5.815
[F] Fixed bug when ATT produce BSOD at start up on some motherboards like Asus P5WD2[*] Improved current 3D settings detection on new Catalyst installation
[F] Fixed bug with wrong detection of current level of Adaptive AA.
[+] "Save Icon Position" module now will save positions for each resolution you will use. Saved positions are incompatible between different resolutions.
[+] Added new module in monitoring graphs. "Motherboard Resources". Now you can directly monitor temperatures, voltages on your motherboard! Big thanks to OverSoft team for SIO Engine plugin. Full supported sensors Winbond: W83627HF, W83637HF, W83627THF, W83782D, W83781D, W83697HF, W83627EHF ITE: IT8705F, IT8712F. Abit uGuru. Partially supported Winbond W83647HF, Asus AS99127F, Fintek F71872. This module in beta test stage.
[+] Added support for custom FPS color in game profiles. Only for OpenGL/Direct3D8/Direct3D9 Games and applications. For old Direct3D and DirectX games (Direct3D7/6/5) custom FPS color will be used only if game will use 32 bits color format in rendering procedure.[*] Updated Core names database. Included information about R580, R600, RV370X, RV371, RV530 LE/SE/VE chips.
[+] Added information about X1900 boards[*] Now Overclocking and Monitoring disabled by default for R5xx boards. Until I find more information about overclocking new ATI chips.[*] Now ATT will not update Monitoring Tray Icons if registered games is active.[*] Moved all overclocking procedures into Kernel mode driver.[*] Updated I2C procedures.[*] Updated OSD plugin "Motherboard resources". Added support for internal ATT Motherboard monitor sources.[*] Updated plugins API. Included functions to access internal Motherboard monitor information. Some function has been updated for OSD Plugins. Please refer to readme.txt in plugins folder. All third party runtime and OSD plugins with configuration procedures must be updated.[*] I2C Dump procedure now can be directly accessed in System Information module.
[F] Fixed wrong CRT + TV detection in System Information module.
[+] Updated texture LOD adjustment procedure. Now you can select positive value, which can increase performance, but in result of very bad quality.
[+] Added support for HDTV modes in Display module.[*] Improved TV/Display module support under Windows XP 64
[F] Fixed situation when ATT unable to properly detect supported display types
[F] Fixed bug when ATT lockups in System Information module under Windows 64.[*] Updated ATT Shared Memory. Included information about free Video/Texture memory, current 3D api and System Memory used by game. Last two fields will be updated only if any 3D application is active and in FlashOSD interval.[*] Recreated color correction procedure. Now colors will be changed automatically on all available displays. Added support for color correction on X1300/X1600/X1800/X1900[*] Added option in Game Profiles to adjust interval in seconds in which ATT will check and update current colors in game. Default value is 10 seconds.
[F] Fixed incorrect FPS color rendering for DirectX and old Direct3D games
Enjoy!
http://omegadrivers.net/
Important Info:
Since these drivers include a non-standard version of ATT, I would recommend that if you have any previous version of ATT installed, please uninstall it before installing these drivers, not doing so may cause unknown problems
Staro 19.01.2006., 10:07   #2
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Evo danas ćemo domy i ja probat pa javim kak radi
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 19.01.2006., 10:20   #3
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,910
Bome i ja,s omegom nikad problema
Staro 19.01.2006., 12:53   #4
Lihto
Lihto's Avatar
Postovi: 3,945
istina
iPhone XR 128gb
Staro 20.01.2006., 13:09   #5
Lihto
Lihto's Avatar
Postovi: 3,945
evo stavio sam jučer omege 6.1 super radi sve 5
ipak je to ATI,nikad problema sa driverima
iPhone XR 128gb
Staro 20.01.2006., 13:23   #6
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Koristio duugoo omegu, pravila probleme u nekim igrama, sad već duže vrijeme na catalystima 5.11, nemam problema i ne diram!
Staro 20.01.2006., 13:58   #7
ZED
a.k.a. LOPOV
ZED's Avatar
Postovi: 2,022
Da i ja isto, 5,11 dobar
Zabranjene reklama u sigu.
Staro 20.01.2006., 14:07   #8
Lihto
Lihto's Avatar
Postovi: 3,945
probaj 5.13 ili 6.1 isto su dobri
iPhone XR 128gb
Staro 20.01.2006., 14:14   #9
ZED
a.k.a. LOPOV
ZED's Avatar
Postovi: 2,022
Sljedeci mj. cu probat, naime prekoracio promet za ohoho(rade tih 15mb spizdim na cod)
Staro 20.01.2006., 17:24   #10
Gigi1
Postovi: 2,138
Efo, stavih ih i ja jucer-sve 5.
Staro 20.01.2006., 17:43   #11
Thoroughbred B
Lokacija: RI
Postovi: 4,910
Zadovoljan!
