Postovi: 2,881
Java problem.........bluranje ekrana !!!
Pojavio mi se problem sa javom prilikom browsanja. Kada god otvorim neku stranicu koja sadrzi javu ekran mi se zablura :confused: ....prvo sam mislio da je problem do flash plug-ina, ali sada sam 100% siguran da je do jave. To mi se desava u operi i firefoxu dok u IE ne. Koristim zadnje verzije navedenih browsera i zadnju javu.
Postovi: 2,881
Rješeno....
Lokacija: Vž
Postovi: 81
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore |
