Postovi: 704
Plavi ekran smrti
Barem jednom mjesečno mi se komp sruši odnosno plavi ekran smrti, šta napraviti. Ovo mi izbacuje program WhoCrashed Crash dumps are enabled on your computer. Crash dump directories: C:\Windows C:\Windows\Minidump On Thu 10.12.2020. 7:58:50 your computer crashed or a problem was reported crash dump file: C:\Windows\minidump\121020-8828-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x1C3B20) Bugcheck code: 0xA (0x38, 0x2, 0x0, 0xFFFFF8034076443A) Error: IRQL_NOT_LESS_OR_EQUAL file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above. This is a software bug. This bug check belongs to the crash dump test that you have performed with WhoCrashed or other software. It means that a crash dump file was properly written out. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time. On Thu 10.12.2020. 7:58:50 your computer crashed or a problem was reported crash dump file: C:\Windows\MEMORY.DMP This was probably caused by the following module: ntkrnlmp.exe (nt!setjmpex+0x8189) Bugcheck code: 0xA (0x38, 0x2, 0x0, 0xFFFFF8034076443A) Error: IRQL_NOT_LESS_OR_EQUAL Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above. This is a software bug. This bug check belongs to the crash dump test that you have performed with WhoCrashed or other software. It means that a crash dump file was properly written out. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Sig-5 redova normalne veličine max ![]() |
Postovi: 33,981
MemTest si provrtio? Vidi ako će sve biti ok nakon njega. Moje je mišljenje da je problem u driverima grafe.
Postovi: 12,613
Ako je 1 mjesecno, garant nije do hardvera, nesto softverski je.
Postovi: 704
Odvrtio memtest i nikakvih problema nije našao, od grafičke imam zadnje drivere, jučer ili prekjučer su izašli, tako da neznam di nastaje problem sa rušenjem winsa.
Postovi: 8,215
Sent from AS/400. |
Postovi: 704
121020-8828-01.dmp 10.12.2020. 7:58:50 IRQL_NOT_LESS_OR_EQUAL 0x0000000a 00000000`00000038 00000000`00000002 00000000`00000000 fffff803`4076443a ntoskrnl.exe ntoskrnl.exe+1c3b20 x64 ntoskrnl.exe+1c3b20 C:\Windows\Minidump\121020-8828-01.dmp 12 15 18362 1.373.068 10.12.2020. 8:01:22 Ovo dobijem kad pokrenem program
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,471
Kako si to zaključio? sharkri, RQL_NOT_LESS_OR_EQUAL je jedna generička pogreška vezana za greške s korupcijom memorije. Može biti zbog nekog drivera (bilo kojeg, ne nužno grafička, problemi s driverom grafičke se u pravilu očituju drugačije) ili zbog problema s memorijom. Možeš memory dumpove uploadati nekamo pa daj ovamo da bacim oko. Također možeš i Speccy odvriti koji ti generira jedan dosta detaljan report, pa daj i njega ovamo. Što se tipično događa s računalom kada izbaci BSOD? * zanima nas small memory dump https://docs.microsoft.com/en-us/tro...mory-dump-file ** Speccy https://www.ccleaner.com/speccy/download/standard |
Uptime freak
Lokacija: Ri, Cro
Postovi: 2,944
Da ne otvaram novi topic, imam isti problem kao sharkri, dakle komp nikad ne gasim, radi 0-24, svasta nesto je upogonjeno, a BSOD se desi jednom mjesečno ili nekad jednom u 3 mjeseca sa istom greškom... i u principu, nikad pod punim opterećenjem. Vjerojatno nije hardver, ali ono što meni bode oči je tablica XMP profila, odnosno trenutna brzina i trenutni timinzi... koji nisu po XMP-u već nešto izmišljeno, drugačije... ![]() E sad da li je moguće da je neka nekompatibilnost na relaciji ploča - rami ili je taj Corsair poluispravan... ili su driveri za sada već zastarjelu 980Ti isto zastarjeli.... nemam pojma... Ideje? |
