Staro 22.05.2018., 16:15   #1
DiVojich
Datum registracije: Nov 2017
Postovi: 69
ACPI
Pozdrav,
počeo mi se pojavljivati problem da svako malo mi iskače warning "Hardware changes have been noticed. please restart your pc". Problem je što nikakav HW nisam mijenjao.
Odjenom mi se počeo svaki malo pojavljivati BSOD.
Kada odem u Event Viewer, vidim error:
ACPI: ACPI BIOS is attempting to write an illegal PCI Operation Region (0x10). Please contact your system vendor for technical assistance.
Napravio sam update drivera, upgradeo OS na najnoviju verziju i nije ništa pomoglo.
Ima li tko kakav savjet?
unaprijed hvala i lijepi pozdrav
DiVojich je offline   Reply With Quote
Staro 22.05.2018., 16:36   #2
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,491
koji OS, koji hardware, napravio si update kojih drivera, jesi napravio update BIOS-a, jesi probao deinstalirati ACPI u device manageru i ponovo instalirati, jesi skinuo BSOD minidump reader i provjerio što piše u njemu?
Staro 22.05.2018., 16:49   #3
DiVojich
Postovi: 69
Win 10 Pro, 64bit
Napravio sam update Intel HD graphics, i od Intel procesora
BIOS update nisam napravio.
ACPI deinstall/install ću sada napravit.
BSOD sad provjeravam trenutno, pa javim ako šta saznam vrijednoga.
Tnx
Staro 22.05.2018., 17:02   #4
Alister
Alister's Avatar
Postovi: 1,491
ACPI driver se obično nalazio u chipset driveru, sada kako su došli Windows 10 chipset driver se skoro pa izgubio jer ga Windows update povuće automatski
Staro 22.05.2018., 17:10   #5
DiVojich
Postovi: 69
MemoryDump report
BugCheck Analysis
KERNEL_SECURITY_CHECK_FAILURE (139) A kernel component has corrupted a critical data structure. The corruption could potentially allow a malicious user to gain control of this machine. Arguments: Arg1: 0000000000000003, A LIST_ENTRY has been corrupted (i.e. double remove). Arg2: fffff58d0d50e930, Address of the trap frame for the exception that caused the bugcheck Arg3: fffff58d0d50e888, Address of the exception record for the exception that caused the bugcheck Arg4: 0000000000000000, Reserved Debugging Details: ------------------ TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2 CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT BUGCHECK_STR: 0x139 PROCESS_NAME: System CURRENT_IRQL: 2 LAST_CONTROL_TRANSFER: from fffff802403bc829 to fffff802403a9670
