Staro 21.02.2018., 11:12   #1
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,430
[OpenSuse 13.1] USB muke
Imam jako čudan problem sa prepoznavanjem USB vanjskog diska na OpenSuse 13 stroju. Disk u pitanju je Seagate M3 USB 3.0 1TB (2 kom, 100% ispravni jer svugdje rade samo ne tu) i pretpostavljam da udev radi probleme ali nemogu skužit kako riješit stvar.
Code:
# udevadm monitor --udev
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
UDEV  [83499.217409] remove   /devices/pci0000:00/0000:00:14.0/usb4/4-6/4-6:1.0 (usb)
UDEV  [83499.217876] remove   /devices/pci0000:00/0000:00:14.0/usb4/4-6 (usb)
UDEV  [83573.759521] add      /devices/pci0000:00/0000:00:14.0/usb4/4-6 (usb)
UDEV  [83573.762405] add      /devices/pci0000:00/0000:00:14.0/usb4/4-6/4-6:1.0 (usb)
lsusb ga normalno vidi.
Code:
# lsusb
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 004 Device 011: ID 0bc2:61b6 Seagate RSS LLC
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Ali...
Code:
#ls -l /dev/disk/by-uuid/
total 0
lrwxrwxrwx 1 root root 9 Feb 20 10:52 054a3503-1bcc-4fde-9111-4f70e807f818 -> ../../md1
lrwxrwxrwx 1 root root 9 Feb 20 10:52 8024a2dc-7959-48a8-afd9-b04cee2cc2f7 -> ../../md2
lrwxrwxrwx 1 root root 9 Feb 20 10:52 97fbed61-5806-4546-8a4f-2c755b28757f -> ../../md0
Ideje?
Staro 21.02.2018., 11:35   #2
madwifi
Postovi: 61
Code:
dmesg | tail
Code:
uname -a
Code:
fdisk -l
Star je OS, ak ti HW ne dela - probaj kernel upgrade >4.4 ili novi udev/eudev, novi hwdb.bin .. Pretpostavljam da je kernel stariji od diska.
madwifi je offline   Reply With Quote
Staro 21.02.2018., 21:38   #3
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,430
Autor madwifi Pregled postova
Code:
dmesg | tail
Code:
uname -a
Code:
fdisk -l
Nekaj takvog...problem je kaj je do prošlog tjedna radilo. Na sustavu ništa nije dirano. Nestalo struje, ponovo paljenje stroja > problem. Gledao sam i sa dmesg i fdisk -l > 0 bodova. Kao da kad mu kernel treba reći ovo je disk, prikaži particije > 0 bodova. Na bilo kojoj drugoj mašini normalno radi , dodijeli mu odma particiju i tak. 2 diska su unutra pa bi ovaj trebao biti "sdc". Inače USB stickove mi normalno prepozna i mogu ih mountat.
Code:
fdisk -l
Disk /dev/sda: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk label type: dos
Disk identifier: 0x0008a36f
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048   209713151   104855552   fd  Linux raid autodetect
/dev/sda2       209713152   243271679    16779264   fd  Linux raid autodetect
/dev/sda3       243271680  3907028991  1831878656    f  W95 Ext'd (LBA)
/dev/sda5       243273728  3907008511  1831867392   fd  Linux raid autodetect
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors
Disk identifier: 0x000ad8d8
/dev/sdb1   *        2048   209713151   104855552   fd  Linux raid autodetect
/dev/sdb2       209713152   243271679    16779264   fd  Linux raid autodetect
/dev/sdb3       243271680  3907028991  1831878656    f  W95 Ext'd (LBA)
/dev/sdb5       243273728  3907008511  1831867392   fd  Linux raid autodetect
Disk /dev/md1: 17.2 GB, 17165189120 bytes, 33525760 sectors
Disk /dev/md0: 107.4 GB, 107371954176 bytes, 209710848 sectors
Disk /dev/md2: 1875.7 GB, 1875697991680 bytes, 3663472640 sectors
Code:
uname -a
Linux server 3.12.67-64-xen #1 SMP Fri Dec 9 15:56:17 UTC 2016 (35c7b99) x86_64 x86_64 x86_64 GNU/Linux
Code:
dmesg |tail
[121390.812506]  [<ffffffff8000a89c>] show_stack+0x1c/0x50
[121390.812517]  [<ffffffff80549514>] dump_stack+0x76/0xab
[121390.812530]  [<ffffffff80031cbf>] warn_slowpath_common+0x7f/0xb0
[121390.812539]  [<ffffffff80031d37>] warn_slowpath_fmt+0x47/0x50
[121390.812575]  [<ffffffffa02b3932>] hsw_disable_lcpll+0x4e2/0x600 [i915]
[121390.812688]  [<ffffffff8004c77b>] process_one_work+0x19b/0x4b0
[121390.812699]  [<ffffffff8004d635>] worker_thread+0x115/0x420
[121390.812710]  [<ffffffff80053bff>] kthread+0xaf/0xc0
[121390.812720]  [<ffffffff805578a0>] ret_from_fork+0x60/0x90
[121390.812729] ---[ end trace 81fdb04802b18336 ]---
Malo me ovo u /var/log/messages zbunjuje:
Code:
2018-02-21T20:37:08.266538+01:00 server kernel: [121510.812360] CPU: 0 PID: 23353 Comm: kworker/0:1 Tainted: G        W       3.12.67-64-xen #1
2018-02-21T20:37:08.266541+01:00 server kernel: [121510.812364] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./B85M, BIOS P2.10 12/06/2013
2018-02-21T20:37:08.266545+01:00 server kernel: [121510.812401] Workqueue: events hsw_enable_pc8_work [i915]
2018-02-21T20:37:08.266548+01:00 server kernel: [121510.812406]  ffffffffa02fd7a0 ffffffff80549514 ffff880080e39db0 ffffffffa02fd7a0
2018-02-21T20:37:08.266551+01:00 server kernel: [121510.812413]  00000000000017fa ffffffff80031cbf ffff880003288000 ffff880080e39e00
2018-02-21T20:37:08.266554+01:00 server kernel: [121510.812419]  0000000000000001 ffff880002046c98 0000000000000001 ffffffff80031d37
2018-02-21T20:37:08.266557+01:00 server kernel: [121510.812426] Call Trace:
2018-02-21T20:37:08.266559+01:00 server kernel: [121510.812450]  [<ffffffff80008ab4>] dump_trace+0x74/0x1a0
2018-02-21T20:37:08.266562+01:00 server kernel: [121510.812460]  [<ffffffff80008c6f>] show_stack_log_lvl+0x8f/0x170
2018-02-21T20:37:08.266565+01:00 server kernel: [121510.812469]  [<ffffffff8000a89c>] show_stack+0x1c/0x50
2018-02-21T20:37:08.266568+01:00 server kernel: [121510.812479]  [<ffffffff80549514>] dump_stack+0x76/0xab
2018-02-21T20:37:08.266571+01:00 server kernel: [121510.812492]  [<ffffffff80031cbf>] warn_slowpath_common+0x7f/0xb0
2018-02-21T20:37:08.266574+01:00 server kernel: [121510.812502]  [<ffffffff80031d37>] warn_slowpath_fmt+0x47/0x50
2018-02-21T20:37:08.266577+01:00 server kernel: [121510.812538]  [<ffffffffa02b3932>] hsw_disable_lcpll+0x4e2/0x600 [i915]
2018-02-21T20:37:08.266579+01:00 server kernel: [121510.812645]  [<ffffffff8004c77b>] process_one_work+0x19b/0x4b0
2018-02-21T20:37:08.266582+01:00 server kernel: [121510.812656]  [<ffffffff8004d635>] worker_thread+0x115/0x420
2018-02-21T20:37:08.266585+01:00 server kernel: [121510.812667]  [<ffffffff80053bff>] kthread+0xaf/0xc0
2018-02-21T20:37:08.266588+01:00 server kernel: [121510.812676]  [<ffffffff805578a0>] ret_from_fork+0x60/0x90
2018-02-21T20:37:08.266591+01:00 server kernel: [121510.812685] ---[ end trace 81fdb04802b18338 ]---
Staro 22.02.2018., 12:08   #4
madwifi
Postovi: 61
Ak je struja nestala nekaj na root disku je off, probaj livecd distru zavrtit [knoppix, salix, systemrescuecd] i
Code:
 umount /dev/sdaX && fsck /dev/sdaX
na disku di je sdaX=root
Staro 22.02.2018., 12:11   #5
madwifi
Postovi: 61
USB-3.0 stick ako dela na istom (3.0) port-u vjerojatno nije HW problem nego FS korupcija, ak ti je root tree koruptiran najbolje napravit backup image i formatirat, Kernel 3.12.67 ti je obsolete plus kaj ima Taint, da je moj server; prvo format, novi root i kernel >>3.16.54 ili >>4.4.116
Staro 22.02.2018., 21:19   #6
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,430
Nije do diska nit je korupmiran FS. Bug u kernelu. Downgrade na 3.11 > opet sva radi kako treba. Tak da...riješeno
Staro 23.02.2018., 10:13   #7
madwifi
Postovi: 61
Je ak prije 7 dana je sve radilo na tom istom kernelu; 100% korupcija zbog struje, nekaj ti je puklo u /lib/modules kaj auto fsck nije mogo popravit.
