Staro 18.11.2005., 12:26   #1
Vjeko
V.I.P. član
Vjeko's Avatar
Lokacija: Hennef, DE
Postovi: 810
Matlab R12
Instalirao sam program na laptopu.
U potpunosti je legalan.
Kada ga pokrenem izbaci me, i ispiše grešku:
Desktop Launch Failed
Failure loading desktop class
Dali je poznato ikome šta bi moglo bit?
Hvala!
Vjeko je offline   Reply With Quote
Staro 18.11.2005., 12:47   #2
atha
atha's Avatar
Postovi: 9,068
vjerovatno je vezano uz javu.
Some of our customers have found that installing an alternate Java Virtual Machine (JVM) fixes this problem. To get the latest JVM made by Sun Microsystems go to:
http://java.sun.com/j2se/downloads.html
NOTE: MATLAB has only been tested on the JVM that we ship with MATLAB. We recommend downloading and installing the 1.3.1 version. There are components of MATLAB that may not work properly under a different version of the JVM.
In order to point MATLAB to the new JVM, you will need to set the MATLAB_JAVA environment variable to point to the path of your new JVM.
NOTE: Set variable under System Variables for Windows platforms.
For Windows NT/2000/XP:
1. Click on Settings in the Start Menu
2. Choose Control Panel
3. Double click on System
4. Choose "Environment Variable" (on the Advanced Tab).
In here you can set the MATLAB_JAVA environment variable to the path of your JVM.
___________
Just atha
x
Staro 18.11.2005., 12:49   #3
Maynard
Maynard's Avatar
Postovi: 124
A šta te natjeralo u životu da koristiš matlab
Maynard je offline   Reply With Quote
Staro 18.11.2005., 13:07   #4
Vjeko
V.I.P. član
Vjeko's Avatar
Postovi: 810
Ima instalirana Java, ali svejedno skidam novu.
Nekoristim ja taj program...ja sam glup za njega
Kolega studira račurarstvo pa mu treba.
Staro 18.11.2005., 13:44   #5
Vjeko
V.I.P. član
Vjeko's Avatar
Postovi: 810
hm...sad kada ulazi ne promjeni rezoluciju kao sto je radio do sada, ali svejedno ispise istu gresku.
atatatha, di si našo te upute?
EDIT: RIJEŠENO!!
Trebalo je ručno upisati varijable i put do nove jave!
Tataratahara, hvala ti puno!
Zadnje izmijenjeno od: Vjeko. 18.11.2005. u 13:56.
Staro 18.11.2005., 21:52   #6
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,550
A bas sam ti htio reci rjesenje.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
