Datum registracije: Apr 2015
Postovi: 705
QNAP i VPN
želio bih upost VPN i spojiti se sa QNAP-om no nešto sam čitao po forumima da qnap ima problema s openvpn-om pa me zanima ako netko ima takav setup da mi kaže jel su to glasine ili uistinu nemogu koristiit openvpn na qnap-u |
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,237
Imam to u planu upogonit u sljedecih par dana tako da cu se javiti kad to sredim (cekam nas da stigne). Koliko sam vidio po netu, nebi smjelo biti problema. Treba podesit openvpn na nas-u i napraviti port forward na ruteru. |
Postovi: 705
ubo sam nordvpn i evo uništavam se već danima kako to poriktat. slijedio sam tutorijal: https://support.nordvpn.com/hc/en-us...QNAP-NAS-setup no u log fajlu mi kaže: Code:
Sat Nov 26 18:13:03 2016 OpenVPN 2.3.6 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Nov 2 2016 Sat Nov 26 18:13:03 2016 library versions: OpenSSL 1.0.0t 3 Dec 2015, LZO 2.05 Sat Nov 26 18:13:03 2016 WARNING: file '/share/CACHEDEV1_DATA/Download/VPN/nordpass.txt' is group or others accessible Sat Nov 26 18:13:03 2016 WARNING: --ping should normally be used with --ping-restart or --ping-exit Sat Nov 26 18:13:03 2016 NOTE: --fast-io is disabled since we are not using UDP Sat Nov 26 18:13:03 2016 Control Channel Authentication: tls-auth using INLINE static key file Sat Nov 26 18:13:03 2016 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication Sat Nov 26 18:13:03 2016 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication Sat Nov 26 18:13:03 2016 Socket Buffers: R=[65536->131072] S=[65536->131072] Sat Nov 26 18:13:03 2016 Attempting to establish TCP connection with [AF_INET]95.211.224.1:443 [nonblock] Sat Nov 26 18:13:06 2016 TCP: connect to [AF_INET]95.211.224.1:443 failed, will try again in 5 seconds: No route to host Sat Nov 26 18:13:12 2016 TCP: connect to [AF_INET]95.211.224.1:443 failed, will try again in 5 seconds: No route to host Sat Nov 26 18:13:20 2016 TCP: connect to [AF_INET]95.211.224.1:443 failed, will try again in 5 seconds: No route to host ... pomoć kako da ovo riješim? |
do you speak it?
Lokacija: ::1
Postovi: 1,629
ne trebas otvarati portove, jer tvoj QNAP je OpenVPN client a ne OpenVPN Server OpenVPN Server (Provider) ti je tvoj NordVPN daj prvo probaj namjestiti vezu sa pc-a OpenVPN client software prema NordVPN-u, da budes siguran da imas sve ispravne podatke (cert, user, pass itd.) tek onda predji na troubleshooting QNAP OpenVPN-a, iako tu nema previse mudrosti, ako radi na PC-u trebalo bi raditi na NAS-u |
Postovi: 705
evo uspio sam spojiti qnap i openvpn, glupi detalj nisu naveli u setupu pa nsiam obraćao pažnju na njega. sve u svemu, spojio sam nas i qnap no... sad imam drugih problema: transmission torent client se ne želi više seedati, kaže "error: could not connect to the tracker". to mi kaže za sve trackere i to kaže instant čim pokrenem seedanje torenta (imam ih na čekanju skinute). dal je to možda do VPN-a da je blacklistan ili se mora nešto posebno podesiti na qnap-u uz VPN da bi mogao koristiti p2p kako spada? EDIT: evo sad sam ubio VPN vezu i torenti rade kako spada... dakle do VPN-a je EDIT #2: promijenio sam server, prvih minutu je sve radilo, čak i IP magnet no onda je prestao. torrenti koji su na seedanju se seedaju i dalje a koje sam stavio friško skinuti imaju error "could not connect to the tracker". Zadnje izmijenjeno od: telefunken. 28.11.2016. u 23:27. |
do you speak it?
Lokacija: ::1
Postovi: 1,629
testiraj sa https://www.dnsleaktest.com/ extended test pa vidi da nemas IP leak ili DNS leak putty, ssh, port, socks5, tako da mozes simulirati kao da ides direktno sa QNAP-a https://www.adamfowlerit.com/2013/01...a-socks-proxy/ |
#9 | ||
Postovi: 705
#10 | |
do you speak it?
Lokacija: ::1
Postovi: 1,629
onda preko SOCKS5 proxy-a (npr. Firefox) testiraj da li imas leakova na samom QNAP-u, na taj nacin ces testirati direktno NAS ako ces koristiti QNAP za nesto osjetljivo, mozda nebi bilo lose da slozis i skriptu za "kill-switch" tj. kada se prekine VPN veza da nebi doslo do leak-a (IP, DNS, itd.) testiraj sa visestrukim SSH vezama, preko jedne npr. ping 8.8.8.8 preko druge veze "ifconfig "naziv-vpn-interface-a" down" pa vidi da li ping i dalje prolazi |
