Staro 16.11.2015., 18:21   #1
Chandler
Chandler's Avatar
Postovi: 225
The disk is write protected
Radi se o sticku Kingston DataTraveler 100 G3 32gb.
Nemogu ga formatirati, javlja poruku iz naslova.
Probao sam sve sa ovoga linka:
http://ccm.net/forum/affich-687538-h...usb-flash-disk
Pregledao sam ga sa malwarebyte-om,nod-om 32... Probao kroz disk managment, cmd, reg edit, format kroz windowse i ništa ne pomaže..............
Help
Chandler je offline   Reply With Quote
Staro 16.11.2015., 21:47   #2
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,541
cmd kao admin i onda
diskpart
list disk
select disk x (where x is the number of your USB flash drive – use the capacity to work out which one it is)
attributes disk clear readonly
clean
create partition primary
format fs=fat32 (you can swap fat32 for ntfs if you only need to use the drive with Windows computers)
exit
http://www.factsnfakes.in/how-to-ena...ve-in-windows/
Staro 18.11.2015., 10:13   #3
Chandler
Chandler's Avatar
Postovi: 225
Ne prolazi
Dođem do djela clean i onda mi javi:
''Disk part has encountered an error: The media is write protected''
Staro 18.11.2015., 10:59   #4
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,667
Autor Chandler Pregled postova
Ne prolazi
M...reklamacija?
Staro 18.11.2015., 12:09   #5
Chandler
Chandler's Avatar
Postovi: 225
A izgleda.....
Kad mu izlistam preko cmd-a attribute disk read only mu je u NO,ali svejedno nemogu ništa s njime.....
Probao i kroz regedit (StorageDevicePolicies) ali opet ništa.......
